Old Jan 19, 2013, 06:53 PM
captain MoMo is online now
Find More Posts by captain MoMo
Mach One
captain MoMo's Avatar
Joined Apr 2011
Originally Posted by Fei Hu View Post
I placed the switch in the nose wheel well with extra foam and hot glue. Test to make sure it's at the right height to activate the switch without causing the gear to bind and overload. The wheel just hits the switch enough to push the lever.
This is the switch I used from Radio Shack.
http://tinyurl.com/c87qz57
There are 3 posts on the bottom. Use a multimeter to test which 2 to use for switch up=lights on, switch down=lights off.
The RC Lander unit comes with a slide on/off swtich for the landing lights which I replaced with the micro lever switch.
I received the lever switchs from Radio Shack. How did you wire these switches with your landing lights? Appreciate the technical detail. Thanks.
captain MoMo is online now Find More Posts by captain MoMo
Old Jan 19, 2013, 07:42 PM
Fei Hu is offline
Find More Posts by Fei Hu
Staying 3 mistakes high!
Fei Hu's Avatar
United States, GA, Lilburn
Joined May 2011
All you need to do is:
1) use a multimeter or other device to see which 2 of the 3 pins on the switch is on when the switch is not depressed and off when it is depressed.
2) solder extension wires to those pins long enough to reach from inside the plane to where you want to place the switch.
3) Locate the wires for the landing lights. On my system it was plug #3 and it is a Y connector from the plug out to the 2 landing lights.
4) Cut ONE of the wires before the Y split and solder the wires from the switch to the cut ends.
5) Install the switch where you want (mine is in the nose wheel well) checking to make sure it is at the correct height for the switch to activate, turning the lights off when the gear is up and you're done.
Fei Hu is offline Find More Posts by Fei Hu
Old Jan 19, 2013, 08:59 PM
Mach One
Joined Apr 2011
You are fast! Thank You - I will try to get it done tomorrow ;-)
Old Jan 21, 2013, 02:35 AM
Corky65 is offline
Find More Posts by Corky65
Gravity always wins . . .
Corky65's Avatar
USA, CA, Palmdale
Joined Dec 2010
Hey Guys, I was going to use a mini cylindrical magnetic proximity switch to activate my landing lights. It would wire the same as Fei Hu's diagram. It works like the magnetic switch on a home door or window alarm. I ended up using the NightFly 14 LED controller from RC Lights so the switch is already built in. I also replaced all the LED's with 3mm and 5mm super brights and added a few.
http://rc-lights.com/
http://www.mcmaster.com/#harsh-envir...itches/=l4me2k
Switch #4 PN-65985K15
Corky65 is offline Find More Posts by Corky65
Old Jan 21, 2013, 05:33 PM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
i flew my GC again the other day for some relatives who were visiting, and it flew SO NICE!!! its the best its ever flown, now that i have it all dialed in. im going to have to go & figure out how to operate my keychain cam again, cause i tried to capture a couple of the flights, but it didnt work. my uncle has caught the "rc flyin" bug though. says that when he gets to oklahoma, he's going to get him a plane & learn to fly. so thats a good thing. i always enjoy seeing someone else get interested in the hobby.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Jan 21, 2013, 10:18 PM
Corky65 is offline
Corky65's Avatar
USA, CA, Palmdale
Joined Dec 2010
Well guys, I finished my GC about year ago and finally got around to gettin' some pics and did some taxi runs up and down my street tonight. I still haven't maidened her yet. I think I was afraid to fly her after putting in so much work. But I am going to maiden her soon. This is a Gen I with E-Flight retracts and servo slowed flaps. You can't see all the lights that are working in a still photo. There are double flash white strobes on the wing tips that flash at a slightly faster rate than the red strobe on the tail and a red rotating beacon on the belly. Will try to get a video soon.
Old Jan 21, 2013, 10:50 PM
Cocg is online now
Find More Posts by Cocg
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
Wing tip lights look great.. (well the whole plane does, but you know...)
Cocg is online now Find More Posts by Cocg
Old Jan 21, 2013, 11:51 PM
Corky65 is offline
Corky65's Avatar
USA, CA, Palmdale
Joined Dec 2010
Originally Posted by gchrisgo34 View Post
. . . my uncle has caught the "rc flyin" bug though. says that when he gets to oklahoma, he's going to get him a plane & learn to fly. so thats a good thing. i always enjoy seeing someone else get interested in the hobby.
Way cool! Is he getting a Champ?
Old Jan 21, 2013, 11:53 PM
Corky65 is offline
Corky65's Avatar
USA, CA, Palmdale
Joined Dec 2010
Old Jan 21, 2013, 11:55 PM
Corky65 is offline
Corky65's Avatar
USA, CA, Palmdale
Joined Dec 2010
Thanks Cocg!
Old Jan 22, 2013, 09:05 AM
jamesdr is online now
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
I still haven't maidened her yet. I think I was afraid to fly her after putting in so much work. But I am going to maiden her soon..
If you are really anything more than a novice, you can fly her. Remember, it is a bigger and heavier bird than your typical foamy so you have to handle her more like a real plane. Once airborn, she is an easy plane to fly. If you haven't flown trike gear before, shoot a couple of practice approaches and remember to flair so you land on the mains first.
Jim
jamesdr is online now Find More Posts by jamesdr
Old Jan 22, 2013, 06:22 PM
sj3cub is offline
Find More Posts by sj3cub
North Carolina
Joined Sep 2003
Very nice clean light installation Corky. They look great, but I think you might blind yourself with those landing lights.
sj3cub is offline Find More Posts by sj3cub
Old Jan 22, 2013, 07:02 PM
dno264 is offline
Find More Posts by dno264
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
motor question
Hi -- Can the stock motor and esc take 4 cells? Thanks.
David
p.s. nice light installation!
dno264 is offline Find More Posts by dno264
Old Jan 22, 2013, 08:05 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
David
No, not for very long
bamaguy is offline Find More Posts by bamaguy
Old Jan 23, 2013, 01:44 AM
Corky65 is offline
Corky65's Avatar
USA, CA, Palmdale
Joined Dec 2010
Thanks for the compliments guys.
This was my second plane six months after I got my Champ. When I saw it, I fell in love with it and just went all out on her. I sinse moved on to more complex 4ch aircraft before I finished her. I guess I was a little intimidated at first and it just stuck with me.
Jim
Thanks for the tips Jim. All my models have conventional gear but all my tricycle gear experience is in FS aircraft. So I land all my models the same way as FS and it's worked out so far. If she'lI fly slow enough to stay ahead of 'er I should be ok.
Sold toyota land cruiser flynfred Cars - Trucks and Parts (FS/W) 0 Sep 27, 2010 05:48 PM
Discussion Groupner "Commodore" cabin cruiser oztruck Scale Boats 2 Sep 15, 2010 07:06 AM
Wanted controller for New Bright PT Cruiser jclush Cars - Accessories (FS/W) 0 Sep 11, 2010 12:31 PM
Sold Sea Cruiser II & Kadet Senior dls Aircraft - Fuel - Airplanes (FS/W) 3 Sep 06, 2010 04:46 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 09:41 PM
