Did you have a weight issue with these motors? And what size battery did they run on? I am planing to use a 2200 30 c battery but am contemplating increasing it if the weight isn't a problem. |
Beaverton, Oregon
Joined Jul 2003
The extra weight greatly stabilizes the plane, especially in gusty conditions. (I've also reinforced the wing with a carbon-fiber arrow shaft.) It's quite fast and will do very high, long, full-powered loops. Good luck, -- Rod |
Red Baron,
Do you have the actual link to the Park 480 1300kv turnigy? I'm going to try the stock set-up for a while but I agree, these shafts are a weak point. Prop vibration on a twin is not good. The spinners are also a weak point. Chrisgo found some nice aluminum spinners that looked promising. -Hawk |
http://www.hobbyking.com/hobbyking/s...r_1320kv_.html and this is the 3 blade spinner http://www.hobbyking.com/hobbyking/s...dProduct=14761 |
![]() ![]() I flew the GC again this morning and am getting better on the landings. Trying to establish the sweet point in the flaps and aproach speed. Bit of a perfectionist here as nothing is good unless she greases down the run way. It is under powered and find pulling out of a sharp turn is rather weak. She is great for the fly bys and must admit she is a wanderful scale model and does looks apart too. |
I tried the flaps but ended up removing the servos as you can get the GC to slow down to a crawl without the flaps. And I normally really enjoy using flaps on my planes. |
Its hard when what you want is never in stock and what you need is never available. ![]() Here is a quick clip of the GC and the turbine a mate made of me a couple of weeks ago..
Baron,
Stephen Speilberg would be impressed ! I almost threw a bag of popcorn in the Micro. Keep them coming ! I took mine to the field yesterday but again too windy for a maiden, at least for me. 10-15. Chickened-out. I did practice ground taxiing and found I need to make a couple of adjustments. One of the plastic spinners is way out of round/balance and I need to better align the nose steering rod to the rudder servo. I also had to lower the EP's on the throws to 85%. The aileron servos were bottoming out. No biggie. I definately want to go with aluminum spinners and will closely study this upgrade . I saw the link for the Park 450 1320kv turnigy's. What dimension will fit? length / dia. I've been having good luck lately at Leaders Hobby for motors and of course in the US, Headsuprc and Grayson. Happy Holidays ! Hawk |
The 310 doesn't need flaps to land well. Unless you have a very short field, 20 degrees of flap is all you want. That flap setting will give you nice easy flair to landing. More flap gives a steeper approach and more skill required to arrest the descent and make a soft landing.
The things we do ....but I love the challenge, hope I'm not the only one here. Cheers. |
| Thread Tools | |
| Sold toyota land cruiser | flynfred | Cars - Trucks and Parts (FS/W) | 0 | Sep 27, 2010 05:48 PM |
| Discussion Groupner "Commodore" cabin cruiser | oztruck | Scale Boats | 2 | Sep 15, 2010 07:06 AM |
| Wanted controller for New Bright PT Cruiser | jclush | Cars - Accessories (FS/W) | 0 | Sep 11, 2010 12:31 PM |
| Sold Sea Cruiser II & Kadet Senior | dls | Aircraft - Fuel - Airplanes (FS/W) | 3 | Sep 06, 2010 04:46 PM |
| Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser | RussellTate | Scale Boats | 15 | Oct 26, 2009 09:41 PM |
