Old Dec 05, 2012, 11:06 PM
DriverRX8 is offline
Find More Posts by DriverRX8
Brain/Thumb Interlock Off
DriverRX8's Avatar
Joined Mar 2011
Originally Posted by fuzzyhead View Post
I am looking for the exact measurements of the battery hatch. I lost the one off my Dynam SR-22 and a replacement is not sold. I noticed that the one on the Grand Cruiswer looks similar and they are readily available. Might be able to trim it to fit if not the same thing. Thanks.
BTW. The Grand Cruiser is a beautiful looking plane. May add to my short list.
I have both airplanes. The battery hatch is interchangeable. So is the roof antenna and the flap hinges. For that matter...
DriverRX8 is offline Find More Posts by DriverRX8
Old Dec 06, 2012, 01:29 AM
Corky65 is offline
Find More Posts by Corky65
Gravity always wins . . .
Corky65's Avatar
USA, CA, Palmdale
Joined Dec 2010
Originally Posted by gchrisgo34 View Post
QUESTION, does it matter which motor turns counter clockwise on a plane? i was tooling around with my GC, & started thinking about it. i know the props usually rotate towards the fueselage, but what about turning away from the fues?
Hey gc, You're correct in the direction of counter rotating props. From inside the cockpit, the left engine turns clockwise and the right engine turns counter clockwise.
The reason behind the counter rotating props is that they cancel each other out when it comes to torque, P-factor, gyroscopic precession, and propeller slip stream.
At higher angles of attack, the prop blade moving in the downward direction produces more thrust than the upward moving blade. Therefore counter rotating props keep the assymetric thrust as close to the aircraft centerline as possible. This also eliminates what is known as the critical engine senario. Critical engine being the one that quits. Whereby if both engines are turning to the right, the critical engine would be the one on the left because the right engine would be producing the most amount of thrust furthest from the fuselage centerline making the aircraft harder to control.
Hope this helped.
Corky
Corky65 is offline Find More Posts by Corky65
Old Dec 06, 2012, 04:34 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
In the FWIW category, the full sized C-310 did not have counter rotating props. That was only on the modified versions.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Dec 06, 2012, 10:17 AM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Still no luck on the retract issue. Grayson did respond though. Their thought was that on initial start-up the retracts need time to synch themselves. So the prescription was to start with a new Lipo, then wait at least 30 seconds for the retracts to synch before flipping any switches
I tried that and still not working. It' 4th down... Are there compatible servoless retracts out there that work on this plane ? I mainly concerned about the steerable nose gear.
She's all dressed up, ready for the dance but...
-Hawk
dahawk47 is offline Find More Posts by dahawk47
Old Dec 06, 2012, 10:34 AM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
Making a little progress. I rebound the rx and plugged everything back in and the nose gear came down immediately. The mains were already down. So, it's not dead. Going to get her set up and try everything together.
There maybe hope for me after all!
Old Dec 06, 2012, 10:42 AM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
-Hawk
These are a drop-in fit. Only issue is the legs are 4mm, not the same diameter as stock gear leg. The nose gear is out of stock, however. But these are really good e-retracts for replacement on Grand Cruiser and Turbo Jet!
Nose.. http://www.hobbyking.com/hobbyking/s...dproduct=23481
Main pair.... http://www.hobbyking.com/hobbyking/s...dproduct=23483
bamaguy is offline Find More Posts by bamaguy
Old Dec 06, 2012, 10:43 AM
Retired Relic is offline
Find More Posts by Retired Relic
Retired Relic's Avatar
United States, AZ, Tucson
Joined Sep 2009
-Hawk
how do the decals look?
can you show a pic?
i'm still waiting for mine.
sorry i can't help with retract issue........the only problem i've had was tightening the slider swivel to tight. it doesn't
move if you do.
WOW THATS GREAT
Retired Relic is offline Find More Posts by Retired Relic
Old Dec 06, 2012, 11:28 AM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
"Martha? We've crossed the Rubicon !"
Finally got the retracts working after alot of trial and tribulation. Tried to isolate the problem 10 ways to Sunday and finally, what I can surmize is that my RX( Frysky Fasst compatible) has a bad channel 5. Never had problems with these before but have never installed them on planes with retracts. Just use them on parkjets,edf's , and other hand launchers.
So I went and bound a genuine Futaba RX and presto ! Problem solved. Back in business !
Now I have to find the little Spinner screws. Man, these Spinners are the weak point in this model as I can see thus far. Way out of balance.
Jim,
I'll take a pic wiith the graphics from Callie. We had a little miscommunication at first but she's really supportive and wants to get it right.. I tried to get creative with what she gave me. A little different to say the least. So, what you'll see is not the final version. In fact, she's sending me a few more to finish her up.
-Hawk
Old Dec 06, 2012, 02:02 PM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
Jim,
Here's what I have so far. I'm going to making a few changes, getting rid of the stripes on the nacelles and changing the look of the nose. Because Dynam paints the v-stab in the baby blue, I re-painted it royal blue to go along with the decals from Callie. There really was a Triple five Sierra Lima in my past,ergo, the ID.
-Hawk
[IMG][/IMG]
[IMG][/IMG]
Old Dec 06, 2012, 04:41 PM
rcflyinff is offline
Find More Posts by rcflyinff
rcflyinff's Avatar
United States, FL, Titusville
Joined Mar 2012
Sweet dahawk! I like it! Glad to hear you got the retracts working. Gonna be able to post any video when you get her airborn?
rcflyinff is offline Find More Posts by rcflyinff
Old Dec 06, 2012, 05:01 PM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
Rcflyin,
Thanks. I'm still making some improvements. Graphics will get better. Callie is a joy to work with and she's providing more to sharpen her up a little. We'll, she'll look good anyway. Was thinking about applying a coat of minwax like I do with all my foamies. Helps with hangar rash( Me bumping into things) Not sure yet.
If I get the chance, and I don't auger her into the ground, I'm already thinking about a motor upgrade so I can go to aluminum spinners. These little plastic jobs are a joke.
One new feature I did include is a velco set-up for the little antenna. Pretty slick. I can now remove the antenna when I want to flip her over on her back so it doesn't break off. Yes to a vid when I maiden if I can get someone to use my i-phone whilst I'm at the sticks.
We've been under siege here in N. Texas with high winds lately. Cold front coming through. So, first good day and I'm at the field. The other challenge will be our field. Might have to take-off from the ramp area where it's practically barren with dead grass. Earlier this year I had a bad time with the DH-88 Comet. Grass on runway was too thick and it kept nosing over. These retracts look a little stiffer than the Comet's so I'll try. Wish she had struts for shock absorbsion and wish the wheels were slightly bigger. We'll see.
Nice looking plane. Glad I got one.
-Hawk
Old Dec 06, 2012, 05:25 PM
rcflyinff's Avatar
Joined Mar 2012
I tried the brush on semi-gloss minwax on the SR22 prior to painting cause I read that I could use any paint after treating it. Are you using gloss, semi? Also, are you putting it right over the decals? Have you ever put minwax on a plane that came factory painted? Just curious if it would enhance the color. My son is hoping for one of these for xmas
Old Dec 06, 2012, 06:34 PM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
I use Minwax Polycrylic clear gloss. Now the decals I have on there are vinyl so I don't really know what will happen. I'll test an unused decal I have left over and see if there's any negative affect. Callie is sending me more decals so I'll really
" pimp my ride" - LOL
Here's the antenna velcroed for easy removal. Seems pretty sturdy. If it blows off, I have more from Cessna 182 that kept breaking off .
[IMG][/IMG]
-Hawk
Old Dec 06, 2012, 06:47 PM
Joined Sep 2009
looking good
looking good guy
standing by for more
and
good luck
Old Dec 06, 2012, 09:48 PM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
that looks good hawk, i also like what you did with the antenna, i might have to try that. i was wondering why they gave us an antenna, when the first time we flipped it over to put the battery in, the stupid thing would break. looking forward to the maiden.
gchrisgo34 is offline Find More Posts by gchrisgo34
Sold toyota land cruiser flynfred Cars - Trucks and Parts (FS/W) 0 Sep 27, 2010 05:48 PM
Discussion Groupner "Commodore" cabin cruiser oztruck Scale Boats 2 Sep 15, 2010 07:06 AM
Wanted controller for New Bright PT Cruiser jclush Cars - Accessories (FS/W) 0 Sep 11, 2010 12:31 PM
Sold Sea Cruiser II & Kadet Senior dls Aircraft - Fuel - Airplanes (FS/W) 3 Sep 06, 2010 04:46 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 09:41 PM
