sometimes when i first plug the battery into the plane, i have to cycle the switch a couple times to get them to sequence with the tx signal. but im sure you've probably cycled them several times by now. go through & make sure all the wires are plugged up correct. proper signal wires. maybe try a different 3 way plug. try putting the switch in the right position before plugging the battery in. if the retracts are up, then put the switch in the up position before plugging the battery up. hope you get it figured out.
The reality is the consumer it the "QC" check on many of the cheap components. It costs time and money to test each widget - and that is reflected in the price you pay. Sounds like your nose gear is DOA. I had one ESC in my GC that was wonky (would surge at anything over 70% or so). You replace it and drive on...the odds are on your side that you won't get two bad units in a row. Hopefully NP will replace it for you gratis.
Jim |
Thanks Jim,
I actually bought mine from Grayson and have sent Basil a message. I suspect infant mortality but maybe there's something I'm not doing right. Don't think that is the case because through testing, I've isolated the rx, using two diffrent bound rx's, the y-connectors, etc. I've even hooked up the rx's to another plane with similar Chinese servoless retracts and they work fine. It was strange when I was finally able to get the mains to cycle by changing the plug connections in the 3 way Y cable. But later, I could not get this to repeat. Tested all the other servos and they work fine. Throttled her up . Check. Very wonky. |
Shock,
I thought about that. I have a UBEC available from my airliner. Of course, I'd have to unplug one of the red wires from one of the esc's. But in this case I'm only hooking up the esc and one servo, so, there should be no load tp speak of. Apparently, they work for everyone else out of the box without using a seperate BEC. My thought is that I simply received a defective set of LG. -Hawk |
Check vid at 1:36
From sitting in the cockpit I believe my port side engine(#1) rotates right and the starboard(#2) rotates left both inward. -Hawk |
I am looking for the exact measurements of the battery hatch. I lost the one off my Dynam SR-22 and a replacement is not sold. I noticed that the one on the Grand Cruiswer looks similar and they are readily available. Might be able to trim it to fit if not the same thing. Thanks.
BTW. The Grand Cruiser is a beautiful looking plane. May add to my short list. |
| Thread Tools | |
| Sold toyota land cruiser | flynfred | Cars - Trucks and Parts (FS/W) | 0 | Sep 27, 2010 05:48 PM |
| Discussion Groupner "Commodore" cabin cruiser | oztruck | Scale Boats | 2 | Sep 15, 2010 07:06 AM |
| Wanted controller for New Bright PT Cruiser | jclush | Cars - Accessories (FS/W) | 0 | Sep 11, 2010 12:31 PM |
| Sold Sea Cruiser II & Kadet Senior | dls | Aircraft - Fuel - Airplanes (FS/W) | 3 | Sep 06, 2010 04:46 PM |
| Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser | RussellTate | Scale Boats | 15 | Oct 26, 2009 09:41 PM |
