Old Dec 01, 2012, 09:51 AM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
none of those spinners will fit the stock GC motors. the GC has those threads & nuts mounted to the shaft, which makes it impossible to use these spinners im going to be changing the motors out, thats why they're going to fit on mine. i "believe" i saw some somewhere that might fit the stock shafts, but dont remember where, "or if" i saw some. but ill see if i can find some.http://www.rcgroups.com/forums/showthread.php?t=1759358 heres my build on the HK ys-11
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Dec 01, 2012, 10:19 AM
gchrisgo34's Avatar
Joined Nov 2010
http://www.pw-rc.com/product_info.ph...77c719cd478bf8 this one should work on the stock GC motor shafts
Old Dec 01, 2012, 10:34 AM
Retired Relic is offline
Find More Posts by Retired Relic
Retired Relic's Avatar
United States, AZ, Tucson
Joined Sep 2009
graphics
hey hawk
glad the tail fix was easy
have ordered N6817T set from calllie i think its the one for the 310D
the other one is for the T-50
later
chuck
Retired Relic is offline Find More Posts by Retired Relic
Old Dec 02, 2012, 10:16 AM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Been putzing with the 310 getting her ready for the graphics department.C'mon Callie ! I did notice on mine that the esc's provided are only 30amp though the manual does indicate they should be 40 amp. Did they change from 40 to 30 ? . The 30 amp'ers are fine for the 1300 kv motors but if I ever wanted to upgrade later to 4S, they will burn out. Of course, the manual also states the motors are 3300kv- LOL So, not sure what to make of it.
-Hawk
dahawk47 is offline Find More Posts by dahawk47
Old Dec 02, 2012, 12:26 PM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
-Hawk
My GC is over a year old and has the 30 amp esc, my guess is the manual is a misprint. I don't know why you would want to run this plane on 4s, it flies plenty scale on 3s.
Herman Munster is offline Find More Posts by Herman Munster
Old Dec 02, 2012, 01:39 PM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
Thanks Herman,
My Motto is: " go faster and do more damage"
Just kidding. I'll fly her scale. I usually do hop-ups well into the life cycle. Running my PZ
T-28 on 4S now. She boogies.
Can't wait to get this bird in the air !
Hawk
Old Dec 02, 2012, 07:55 PM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
So I can hit the ground running and without having to search the entire thread, I have a couple of set-up questions: 1). Is CG in the manual correct? If not? what do you recommend? 2) What are you programming for expos? If all goes well and the wind cooperates, I'll try to maiden this week. Would like to get her in the air by Wednesday as I have to travel Thurs-Sat.
If Callie's graphics arrive tomorrow I'll bring her to the club meeting Tuesday night.
Hawk
Old Dec 02, 2012, 08:02 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Hawk;
I use 40% Expo and the book CG. Works for me.....fly's great and lands like a pussycat
bamaguy is offline Find More Posts by bamaguy
Old Dec 03, 2012, 01:19 AM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
Thanks Bama !
Roll Tide !
Old Dec 03, 2012, 02:17 AM
NOTAR 600 is offline
Find More Posts by NOTAR 600
ohio usa
NOTAR 600's Avatar
Joined Nov 2007
I don't have this plane yet.......but I really want it.
I noticed Grayson Hobby recommends a slightly different measurement for the center of gravity than the manual. My main point is that if the CG is a little bit off........it is much better to be a little nose heavy than tail heavy. A nose heavy plane will fly....and a tail heavy plane will crash. You likely have learned this in your experience flying the T-28 and others.
Best of luck and have fun with your beautiful grand cruiser 310!
NOTAR 600 is offline Find More Posts by NOTAR 600
Old Dec 03, 2012, 05:31 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Truthfully, I just put in a 2200 mAh 3 cell pack and called it good. I use 50% expo high and low on ailerons and elevator, and 80% low on rudder. I use a real high expo for ground handling so that on takeoff run, any sloppy thumb movements won't send the model tearing off the centerline.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Dec 03, 2012, 06:42 PM
gchrisgo34's Avatar
Joined Nov 2010
i recieved my motors & spinners from HK today. these are the nicest spinners ive ever seen. the larger spinner in the back is a $35 eflite spinner. and the other 2 spinners cost $8 combined. the turnigy 35-36 1000kv is going to fit perfectly within the nacelle. ive also got counter rotating props for the GC. cant wait to see the difference with this setup.
Old Dec 03, 2012, 07:13 PM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
Looks great. I have to get some ! Haven't even maidened mine yet and am already itching to upgrade. Did you also upgrade the esc's from the 30's? Figure you'll need to if you're thinking 4S.
Graphics came but I think there's been a disconnect on my part. I didn't describe what I wanted well enough. Not Caliie's fault . She provided quality decals . Just missed the mark. My own fault. So, I might just go with the Dynam graphics.
I'll get her up in the air and since she's really intended for scale type flying, I won't push her too hard.
Old Dec 03, 2012, 08:32 PM
Norm62 is offline
Find More Posts by Norm62
United States, SC, Greenville
Joined Jun 2011
Jim
+1
Norm
Norm62 is offline Find More Posts by Norm62
Old Dec 03, 2012, 08:33 PM
Norm62 is offline
Joined Jun 2011
looking forward to seeing the results...
Norm
Sold toyota land cruiser flynfred Cars - Trucks and Parts (FS/W) 0 Sep 27, 2010 06:48 PM
Discussion Groupner "Commodore" cabin cruiser oztruck Scale Boats 2 Sep 15, 2010 08:06 AM
Wanted controller for New Bright PT Cruiser jclush Cars - Accessories (FS/W) 0 Sep 11, 2010 01:31 PM
Sold Sea Cruiser II & Kadet Senior dls Aircraft - Fuel - Airplanes (FS/W) 3 Sep 06, 2010 05:46 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 10:41 PM
