Old Sep 28, 2010, 02:49 PM
JHeuler is offline
Find More Posts by JHeuler
Joined Apr 2009
A123 Battery Pack Load Testing
Can anyone help me with determining a way to load test a two cell A123 battery pack that is used in a flight pack?
JHeuler is offline Find More Posts by JHeuler
Old Sep 29, 2010, 09:18 AM
JuanRodriguez is offline
Find More Posts by JuanRodriguez
The Villages, Florida
Joined May 2003
The general consensus is that you can't...... The battery chemistry does not lend itself to load testing like NiCad, NiMH and Lipos......
For the A123's, you need to "see" what capacity has been put back into the battery after a flight or two and then go from there.....
JuanRodriguez is offline Find More Posts by JuanRodriguez
Old Sep 30, 2010, 01:36 PM
JHeuler is offline
Joined Apr 2009
Thanks for response.
It seems to me that as the A123 batteries can provide advantages, they can also provide disadvantages.
Old Sep 30, 2010, 04:11 PM
Joined May 2003
No problem.....
To me , the advantages overwhelmingly outweigh the disadvantages......
A fully "dead" A123 can be fully charged in as little as 15 minutes at 10 amps.....if you have a charger and power supply capable of charging at those rates......
So, even charging at a lower rate of 3-4 amps, you can top off the battery after taking a couple of flights in less than 1/2 hr....
Old Nov 20, 2010, 11:18 AM
stick08 is offline
Find More Posts by stick08
nothing new under the sun
stick08's Avatar
Joined Jun 2006
A123 Nanophosphate 2300 mAh Rx pack
just bought a A123 Pack as per Jim's recommandation to use withe the 8 and 10 XPS Rx
is it possible to charge with Accucell-6 charger ( Hobbyking) position I have is Life
3.3 volts ?
on the technical notice it is said "Life for e.g A123M1" ( M1 is it different from Nanophosphate ? )
thanks for your help, want to be sure to use the right charger.
stick08 is offline Find More Posts by stick08
Old Nov 20, 2010, 01:20 PM
cgblues is offline
Find More Posts by cgblues
Joined Nov 2004
Maximum charge voltage of A123 is 3.6 volts. Hobby king lists the Accucell-6 as being able to charge Life. check your manual to make sure. Here is the home page for A123 http://www.a123systems.com/a123/products, the first two on the left are the cells we use.
I don't balance the batteries when I'm at the field, I just quick charge them. However I don't charge them after the last flight but when I get home I charge and balance them. If you have a bad battery it will show up, the battery will not hold the same voltage charge as the good battery.
I use A123 as main battery packs (6S and up) as well as receiver packs in all my airplanes. I've only replaced 2 of the 2300 cells and one 1100 ma cell out of 40 or so cells I'm actively using after 3 seasons of flying and two of those were because I drained the packs to zero and they wouldn't take a charge.. the 3rd had a low voltage readout after charging. I hope that helps
cgblues is offline Find More Posts by cgblues
Old Nov 20, 2010, 01:46 PM
stick08 is offline
stick08's Avatar
Joined Jun 2006
cgblues,
yes, thank's your informations are very clear, on the user manual I have frm Enerland they said max voltage is up to 4.2 V without hazard , my charger stop at 3.6 V so I will be always under the maximum charging capacity ( it will be use as Rx pack ) and the minimum is 2 Volt ,
Is this batterie can be destroyed if voltage goes under 2 Volts ?
if I want full charging capacity can I use the Lipo ( 4.2V ) or Lilo ( 4.10 V) instead the Life ( 3.6 V) position of the charger ?
Old Nov 20, 2010, 01:50 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Use the LiFe setting.
The voltage rises very fast past 3.6 volts, so there is little additional energy put into them by going higher.
They are quite tolerant of over-discharge, just don't take them right down to zero.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Nov 20, 2010, 05:51 PM
cgblues is offline
Joined Nov 2004
My chargers are set at 3.6 volts for A123, and 4.2 volts for Lipo.
Daryl
Old Nov 20, 2010, 05:57 PM
tande is offline
Find More Posts by tande
Joined Feb 2004
FWIW.... http://electrodynam.com/rc/EDR-207/index.shtml
tande is offline Find More Posts by tande
Old Nov 21, 2010, 12:31 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
As one of the largest distributors of A123 products in the U.S. I can tell you that the device linked to above can be purchased from Hobby City for around $25 and was not designed to load test A123 batteries. It is commonly used to balance charge or discharge Lipos and other cells. You can load test A123 batteries, but the results will be meaningless for you. If you are seeing a drop in voltage during this type of load test, it would likely already be too late!
We recommend that you put a few flights on a pack and then charge it to see what is put back into it. This can be determined either by time or milliamp hour with chargers that have a dedicated LiFe mode.
JimDrew is offline Find More Posts by JimDrew
Old Nov 21, 2010, 08:59 AM
stick08 is offline
stick08's Avatar
Joined Jun 2006
Pat MacKenzie
thank you Pat !
Old Nov 21, 2010, 09:13 AM
stick08 is offline
stick08's Avatar
Joined Jun 2006
Jim I make a charge @ 2xC ( 4.6 A ) and discharge @ 1A, and I had a drop in voltage on one cell under 2 V ( 1.5 V or less ) the charger was suppose to cut off @ 4 Volts but as one cell was about 3.3 volt it didnt stop even the other cell was under 2 V know I charged again @ 6.6 volts what can I do to
know if my A123 is still good ? hoping its not too late for my first purchase of A123 battery....
Old Nov 21, 2010, 09:26 AM
rscarawa is online now
Find More Posts by rscarawa
Closet 'Air Supply' Fan!
rscarawa's Avatar
United States, NC, Salisbury
Joined Jan 2005
I am curious how you get the fast 5c charge rates with A123. I have a top end Hyperion charger that charges lipo, lilo, and A123. If I charge in A123 mode, I can specify a 5c charge but it will not sustain a charge that fast long enough to charge 90% in 15 min. The charge rate comes down to 1c or less in a minute or two once the 3.6v operating voltage is reached. Do you charge as lilo or lipo to get the quick charge rates?
Scot
rscarawa is online now Find More Posts by rscarawa
Old Nov 21, 2010, 09:56 AM
Joined May 2003
Originally Posted by rscarawa View Post
I am curious how you get the fast 5c charge rates with A123. I have a top end Hyperion charger that charges lipo, lilo, and A123. If I charge in A123 mode, I can specify a 5c charge but it will not sustain a charge that fast long enough to charge 90% in 15 min. The charge rate comes down to 1c or less in a minute or two once the 3.6v operating voltage is reached. Do you charge as lilo or lipo to get the quick charge rates?Scot
My "guess" is that your charger (or perhaps, power supply) is not capable of providing what you're after.....
That's only a guess and I would be interested in hearing from the "experts" regarding the issue....
My other "guess" is that your charger (any charger?) will not provide that continuous high rate from beginning to end...... I would think that at some point during the charge, the charger will taper off the rate until the battery is completely charged.....
Discussion load testing rx pack ? hotdog1 Fuel Plane Talk 10 Jan 21, 2014 03:55 PM
Discussion M1 receiver pack load testing real basic tgt Batteries and Chargers 4 Dec 24, 2009 07:44 PM
Discussion A123 M1 battery pack configuration twilkers Batteries and Chargers 6 Dec 24, 2009 12:29 PM
For Sale A123 Battery Pack 4600ma 6.6v Hypersonic Li-Ion helichuck Cars - Cars and Parts (FS/W) 0 Oct 01, 2009 07:25 AM
Sold NIP Dewalt 36V battery pack (A123) horton Aircraft - Electric - Batteries & Chargers (FS/W) 8 Sep 29, 2009 10:11 AM
