This thread is privately moderated by Sid3ways, who may elect to delete unwanted replies.
Old Aug 22, 2012, 09:08 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Find my codes here: http://hk.rc-international.info/swarm/cloudflying (valid until September 04, 2012)
20CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) Save US$: 2.04
3d astronaut is offline Find More Posts by 3d astronaut
Old Aug 22, 2012, 05:16 PM
lenivec is offline
Find More Posts by lenivec
Joined Nov 2011
Hobbyking Slick 360 3D 1300mm (ARF) (DE Warehouse) Save US$: 149.33
lenivec is offline Find More Posts by lenivec
Old Aug 23, 2012, 07:30 AM
bobber is offline
Find More Posts by bobber
Flyin brick
bobber's Avatar
Joined Feb 2005
Some more
All my buddy-codes here
Pico Servo w/ Futaba Plug 5.4g/.12sec/.7kg
[S]$11.95[/S] $7.77* (buddy<br>price 35%, -$4.18)
FrSky FF-1 2.4Ghz Combo Pack for Futaba w/ Module & RX
[S]$39.26[/S] $36.84* (buddy<br>price 6%, -$2.42)
HG 202 Carbon Gear BB - 8.9g / .12s / 1.0kg
[S]$23.64[/S] $13.17* (buddy<br>price 44%, -$10.47)
Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr)
[S]$2.39[/S] $2.25* (buddy<br>price 6%, -$0.14)
4MM Banana Plug / Charge Plug (solder type) (2 pair/bag)
[S]$1.65[/S] $1.06* (buddy<br>price 36%, -$0.59)
Rhino 460mAh 2S 7.4v 20C Lipoly Pack
[S]$4.79[/S] $2.63* (buddy<br>price 45%, -$2.16)
Carbon Fiber servo arm 65mm (2pcs/bag)
[S]$2.99[/S] $2.63* (buddy<br>price 12%, -$0.36)
Rhino 360mAh 2S 7.4v 20C Lipoly Pack
[S]$4.29[/S] $1.72* (buddy<br>price 60%, -$2.57)
Glass Fiber Cloth 450x1000mm 18g/m2 (Super Thin)
[S]$0.99[/S] $0.70* (buddy<br>price 29%, -$0.29)
Peel-n-stick foam tape. 10x5inch 4mm thick
[S]$1.49[/S] $0.24* (buddy<br>price 84%, -$1.25)
bobber is offline Find More Posts by bobber
Old Aug 24, 2012, 06:22 AM
speedstep is offline
Find More Posts by speedstep
Joined Dec 2011
Turnigy nano-tech 3300mah 4S 25~50C Lipo Pac
for Zephyr or multicopter discovery or QAV500
http://www.hobbyking.com/buddy.asp?c...0-E44D4125B132
speedstep is offline Find More Posts by speedstep
Old Aug 24, 2012, 07:03 AM
FourPlay26 is offline
Find More Posts by FourPlay26
Wantabee RC Pilot
FourPlay26's Avatar
Redbank Plains Queensland
Joined Dec 2008
Hi All
Some links below
TR_P60A TURNIGY Plush 60amp Speed Controller
http://www.hobbyking.com/buddy.asp?c...1-34D50FE5A6BC
WHS25-Transpa Turnigy Heat Shrink Tube 25mm Transparent
http://www.hobbyking.com/buddy.asp?c...A-9E65B7FBCDAD
WHS14-Yelow Turnigy Heat Shrink Tube 14mm Yellow (1mtr)
http://www.hobbyking.com/buddy.asp?c...9-CB9EC531EB9C
WHS10-RED Turnigy Heat Shrink Tube 10mm RED (1mtr)
http://www.hobbyking.com/buddy.asp?c...A-9FB458BBD983
WHS10-BLACK Turnigy Heat Shrink Tube 10mm BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...1-9C3612B8EA0E
WH-6MM-BLACK Turnigy 6mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...7-858E8D4F8466
WHS-6MM-RED Turnigy 6mm Heat Shrink Tube - RED (1mtr)
http://www.hobbyking.com/buddy.asp?c...B-13FDFCEB86A0
601CC-14-30c Charge Cable w/ Male XT60 <-> 4mm Banana plug
http://www.hobbyking.com/buddy.asp?c...E-9F20CD6399C5
R10A1780-06 Turnigy Pure-Silicone Wire 10AWG (1mtr) RED
http://www.hobbyking.com/buddy.asp?c...6-7FA26E5C3F4C
B10A1780-06 Turnigy Pure-Silicone Wire 10AWG (1mtr) BLACK
http://www.hobbyking.com/buddy.asp?c...D-AA9267000D60
60A-SL Turnigy Brushless ESC 60A w/ Reverse prog.
http://www.hobbyking.com/buddy.asp?c...A-877540C5A9B1
FourPlay26 is offline Find More Posts by FourPlay26
Old Aug 24, 2012, 03:56 PM
Ciast3k is offline
Find More Posts by Ciast3k
UAV Constructor
Poland, Dolnoslaskie, Wroclaw
Joined Aug 2012
325mm Fiber Glass Main Blades
[S]$3.43[/S] $2.98* (buddy<br>price 13%, -$0.45)
Mystery 30A BEC Brushless Speed Controller (Blue Series)
[S]$12.69[/S] $11.59* (buddy<br>price 9%, -$1.1)
68mm Carbon Fiber Tail Blade
[S]$2.20[/S] $1.73* (buddy<br>price 21%, -$0.47)
Ciast3k is offline Find More Posts by Ciast3k
Old Aug 25, 2012, 10:23 PM
helicopter_new is offline
Find More Posts by helicopter_new
Austria
Joined Sep 2008
Almost all the Turnigy FBL100 3D Micro Helicopter PARTS
http://hk.rc-international.info/swarm/happy
A lot of the 1/16 Brushless 4WD Racing Buggy w/25A System PARTS
helicopter_new is offline Find More Posts by helicopter_new
Old Aug 25, 2012, 10:24 PM
Austria
Joined Sep 2008
DETAILS
Find my codes here: http://hk.rc-international.info/swarm/happy (valid until September 09, 2012)
Turnigy FBL100 Swashplate Linkage Set Save US$: 0.64
Turnigy FBL100 Feathering Shaft (2pcs/bag) Save US$: 0.98
Turnigy FBL100 Main Gear (2pcs/bag) Save US$: 1.89
Turnigy FBL100 Tail Rotor Blade (2pcs/bag) Save US$: 1.14
Turnigy FBL100 Main Shaft (2pcs/bag) Save US$: 1.04
Turnigy FBL100 Main Blades Save US$: 2.99
Turnigy FBL100 Vertical Tail Fin Save US$: 0.89
Turnigy FBL100 Tail Boom (2pcs/bag) Save US$: 0.83
Turnigy FBL100 Head Linkages (4pcs/bag) Save US$: 0.36
Turnigy FBL100 Main Rotor Head Block Save US$: 0.37
Turnigy FBL100 Main Blade Grips (2pcs/bag) Save US$: 0.83
Turnigy FBL100 Tail Case (2pcs/bag) Save US$: 1.29
Turnigy FBL100 Main Frame Save US$: 1.90
Spur Gear - 110BS, A2029 and A2035 Save US$: 0.34
2pc Motor Pinion (15T) - 110BS, A2029 and A2035 Save US$: 0.86
Front Upper Suspension arms (left/right) - 110BS, A2029 and A2035 Save US$: 0.18
Front Shock Tower - 110BS Save US$: 0.18
Rear Bearing Holder (left/right) - 110BS, A2029 and A2035 Save US$: 0.18
Body clips A (10pc) - 110BS, A2029 and A2035 Save US$: 0.14
Front Lower Suspension Arms L/R (2pcs) - A2029 and A2035 Save US$: 0.24
10pc E-clip (2.3*0.4) 110BS, A2016T, A2029 and A2035 Save US$: 0.14
Servo Tie Rod - 110BS, A2003T, A2029 and A2035 Save US$: 0.14
Front Upper Sus.arm Sleeve Spacer (4pc) - 110BS, A2029 and A2035 Save US$: 0.14
Rear Ball End and Tie Rod - 110BS, A2003 and A2029 Save US$: 0.24
Front Linkage Rod/Ball End Set (2pcs) Save US$: 0.18
Front Upper Suspension Arm Pins - 110BS Save US$: 0.14
Front Lower Suspension Arm Pins - 110BS, A2029 and A2035 Save US$: 0.14
Bumper - 110BS Save US$: 0.18
Front Aluminum Shocks (1pair/bag) - 110BS, A2003T, A2029 and A2035 Save US$: 1.94
Rear Wing Mount Set (complete) - A2003T Save US$: 0.32
Rear Lower Suspension Arm Mount - A2003T (1pc) Save US$: 0.10
Rear Lower Suspension Arms L/R - A2003T (2pcs) Save US$: 0.32
Rear Aluminum Shocks (2pcs/bag) - 110BS, A2003T, A2029 and A2035 Save US$: 1.94
Rear Suspension Arm Pins - A2003T (2pcs) Save US$: 0.21
Steering Linkage Set Ball Cups w/Rods(2pcs) - A2003T and A2029 Save US$: 0.28
Diff.Pinion Gear S (3pc) - 110BS, A2003T, A2029 and A2035 Save US$: 0.38
Pinion Gear B 1(Short) and Outdrive - 110BS, A2003T, A2029 and A2035 Save US$: 0.38
Drive gear w/outdrive - 110BS, A2003T, A2029 and A2035 Save US$: 0.38
Diff.Pinion Gear B 2(long) and Outdrive - 110BS, A2003T, A2029 and A2035 Save US$: 0.38
Metal Drive Gear w/Shaft - A2003T, A2029 and A2035 Save US$: 0.38
Old Aug 26, 2012, 04:07 PM
Beau0090_99 is offline
Find More Posts by Beau0090_99
Eden Prairie, MN
Joined May 2008
Here are some of mine
Female XT60 connectors (5pcs/bag) GENUINE
http://www.hobbyking.com/buddy.asp?c...1-8B67BDCE6EBA
Turnigy 4mm Heat Shrink Tube - RED (1mtr)
http://www.hobbyking.com/buddy.asp?c...B-984AE3F08002
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...D-E347C9274691
Servo Terminals (Futaba) Gold Plated (10pairs/set)
http://www.hobbyking.com/buddy.asp?c...F-DE5C35B02068
Turnigy AA LSD 2400mAh Low Self Discharge (ready to use)
http://www.hobbyking.com/buddy.asp?c...F-C25A7FB723D9
Beau0090_99 is offline Find More Posts by Beau0090_99
Old Aug 27, 2012, 02:07 AM
jharlidg is offline
Find More Posts by jharlidg
Joined Aug 2012
New Codes
Find my codes here: http://hk.rc-international.info/swarm/jharlidge (valid until September 10, 2012)
Nylon T-Connectors 10 Pairs (20pc) Save US$: 0.19
Alloy servo arm for car 46mmxM3 (Futaba) Save US$: 0.61
On-Board Lipoly Low Voltage Alarm 2s~3s Save US$: 0.28
High Density Waterproof LED Flexible Strip - Blue (1mtr) Save US$: 2.59
High Density Waterproof LED Flexible Strip - White (1mtr) Save US$: 2.59
jharlidg is offline Find More Posts by jharlidg
Old Aug 27, 2012, 10:05 AM
gutman is offline
Find More Posts by gutman
Joined Nov 2010
Extra Codes, You can save -8.03% for all of this products with:http://rc-buddy.com/user/gutman! Codes from RC-Buddy.com
TrackStar Silicone Shock Oil 3000cSt (60ml)
Savings: 7.59 % / $0.28
Price after: $3.41
Weight: 90 g
TrackStar Silicone Shock Oil 550cSt (60ml)
Price after: $3.41
Weight: 90 g
TrackStar Silicone Shock Oil 350cSt (60ml)
Price after: $3.41
Weight: 90 g
TrackStar Silicone Diff Oil (High Viscosity) 30000cSt (50ml)
Savings: 42.11 % / $2.48
Price after: $3.41
Weight: 80 g
TL-262 Thread Locker & Sealant High Strength
Savings: -244.44 % / $-2.42
Price after: $3.41
Weight: 85 g
TL-680 Thread Locker & Sealant Ultra High Strength
Price after: $3.41
Weight: 85 g
gutman is offline Find More Posts by gutman
Old Aug 27, 2012, 02:26 PM
imyohero is offline
Find More Posts by imyohero
F-OFF
imyohero's Avatar
Joined Mar 2007
Turnigy nano-tech 2250mah 4S 65~130C Lipo Pack save $2.22
http://www.hobbyking.com/buddy.asp?c...1-CBEE5F507455
TURNIGY Plush 60amp Speed Controller save $4.70
http://www.hobbyking.com/buddy.asp?c...6-6A48CF7897B4
imyohero is offline Find More Posts by imyohero
Old Aug 27, 2012, 03:39 PM
IndiaHobby is offline
Find More Posts by IndiaHobby
Fly and Drive RC
IndiaHobby's Avatar
United States, MD, Laurel
Joined Mar 2010
Folding Prop Now In Stock !
6 x 4 Folding Prop for Gliders for $1.56
IndiaHobby is offline Find More Posts by IndiaHobby
Old Aug 28, 2012, 07:27 AM
fredo21 is offline
Find More Posts by fredo21
Never too much detail
fredo21's Avatar
Australia, VIC, Hampton
Joined Jan 2007
Tail Wheel System. w/ Steering & Spring 60-120 Size
[S]$5.95[/S] $5.12* (buddy<br>price 14%, -$0.83)
Turnigy Type A Beech wood 14x7 propeller
[S]$2.78[/S] $2.15* (buddy<br>price 23%, -$0.63)
Turnigy EasyMatch G46 Series - Replacement Shaft
[S]$2.19[/S] $1.67* (buddy<br>price 24%, -$0.52)
[S]$1.59[/S] $1.43* (buddy<br>price 10%, -$0.16)
Turnigy nano-tech 1800mah 3S 25~50C Lipo Pack (AUS Warehouse)
[S]$16.71[/S] $11.99* (buddy<br>price 28%, -$4.72)
Z-bend Pliers. Heavy Duty 90deg up to 1/16
[S]$6.49[/S] $5.35* (buddy<br>price 18%, -$1.14)
Beech wood 18x12 propeller
[S]$5.45[/S] $3.22* (buddy<br>price 41%, -$2.23)
fredo21 is offline Find More Posts by fredo21
Discussion Hobby King "SWARM" Sales mattyhawk HobbyKing 39 Feb 16, 2015 03:53 PM
Cool Official Banana Hobby LIVECHAT Conversation Thread dgbuggy Banana Hobby 82 Mar 01, 2010 07:02 PM
FAQ Honeybee King II official Q&A thread my c210 Micro Helis 9 Jan 14, 2010 05:00 PM
Discussion The Official 2009 Hobby Lobby Thanksgiving Sale Thread! Jason Cole Hobby Express (Formerly Hobby Lobby) 2242 Dec 08, 2009 06:33 PM
Discussion Official Hobby Lobby Thanksgiving Sale Thread Jason Cole Hot Online Deals 2927 Jan 06, 2008 07:19 AM
