This thread is privately moderated by Sid3ways, who may elect to delete unwanted replies.
Old Aug 02, 2012, 10:35 AM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
NTM Prop Drive Series 28-26A 1200kv / 250w (USA Warehouse)
Glow In The Dark 8x4 Propellers (Standard and Counter Rotating)(6pc/bag)
CheckSum is offline Find More Posts by CheckSum
Old Aug 05, 2012, 08:36 PM
Virginia Jim is offline
Find More Posts by Virginia Jim
Virginia Jim's Avatar
United States, NC, Durham
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/virgjim (valid until August 17, 2012)
Pushrod Snap-On Link 144pc 1,1.4,1.6,2.0mm Save US$: 3.32
HXT500 Replacement Gear Set Save US$: 0.45
120mm Molex 1.25 Servo Extension (5pcs/bag) Save US$: 1.80
Virginia Jim is offline Find More Posts by Virginia Jim
Old Aug 07, 2012, 07:40 AM
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/virgjim (valid until August 16, 2012)
Need to anchor a control surface without gluing so you can break your plane down for travel? Check these nylon screws out!
M3x12mm Nylon Screws (10pcs/bag)
Regular=$0.93 Buddy=$0.70 Save $: 0.23
Reinforce your foamy's wings while making your plane more visible with colorful tape!
Wing Tape 45mic x 24 mm x 100m (Narrow - Red)
Regular=$1.05 Buddy=$0.67 Save $0.38
Wing Tape 45mic x 24 mm x 100m (Narrow - Orange)
Crashed your plane and need to replace the servo linkage? Anchor outer tube on both ends and use these effectively with less weight!
soft push rod (Snakes) - D3 x 1150mm (4pcs/bag)
Regular=$3.10 Buddy=$2.36 Save $: 0.74
To minimize prop damage with those embarrasing one-point landings and for easier prop changes on the field. Great for Easy-Fly Dolphin & J-3 Planes! Also fits Bixler motor shaft.
Prop Saver w/ Band 2.3mm (10pcs/bag)
Regular=$2.99 Buddy=2.68 Save $ 0.31
Old Aug 10, 2012, 01:32 AM
2jzgtevvti is offline
Find More Posts by 2jzgtevvti
2jzgtevvti's Avatar
Thailand, Bangkok
Joined Oct 2005
Turnigy FBL100 Screw Set
http://www.hobbyking.com/buddy.asp?c...E-7BE144D94ED7
Turnigy FBL100 Main Rotor Head Block
http://www.hobbyking.com/buddy.asp?c...2-62DF250226AF
Turnigy FBL100 Swashplate Linkage Set
http://www.hobbyking.com/buddy.asp?c...7-1176DA7BC45E
Turnigy FBL100 Tail Rotor Blade (2pcs/bag)
http://www.hobbyking.com/buddy.asp?c...0-2258AD7246C6
Turnigy nano-tech 160mah 1S 25~40C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...4-2541B1BD9E3E
Turnigy nano-tech 300mah 1S 35c Lipo Pack (Mcpx FBL100
http://www.hobbyking.com/buddy.asp?c...8-08E4CA9F1B52
Turnigy AA Ni-ZN 1500mAh High Voltage (ready
http://www.hobbyking.com/buddy.asp?c...C-E23657245020
Turnigy Teflon Coated Wire 36AWG (1mtr) Red
http://www.hobbyking.com/buddy.asp?c...3-C6FCB5EF50B5
Turnigy Teflon Coated Wire 36AWG (1mtr) Black
http://www.hobbyking.com/buddy.asp?c...D-E34D8C519E00
2jzgtevvti is offline Find More Posts by 2jzgtevvti
Old Aug 10, 2012, 05:09 PM
mapesk is offline
Find More Posts by mapesk
Joined Aug 2012
TURNIGY Basic 18A v3.1 Speed Controller
http://www.hobbyking.com/buddy.asp?c...4-ABA8AAFAAFBA
Zippy-K Flightmax 1200mah 3S1P 25C Lipoly
http://www.hobbyking.com/buddy.asp?c...2-B3D1AD4BED6E
HobbyKing Red Brick 20A ESC
http://www.hobbyking.com/buddy.asp?c...6-C76237216F60
FC 28-12 Brushless Outrunner 1534kv
http://www.hobbyking.com/buddy.asp?c...D-5804747B141B
18-11 2000kv Micro Brushless Outrunner (10g)
http://www.hobbyking.com/buddy.asp?c...4-6495FC64C185
Rhino 360mAh 2S 7.4v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...3-962CEB84DED4
HXT500 5g / .8kg / .10sec Micro Servo
http://www.hobbyking.com/buddy.asp?c...6-ED36D87E8228
mapesk is offline Find More Posts by mapesk
Old Aug 14, 2012, 06:17 AM
greenfeet is offline
Find More Posts by greenfeet
greenfeet's Avatar
Australia, SA, Yankalilla
Find my codes here: http://hk.rc-international.info/swarm/trippergreenfeet (valid until August 28, 2012)
Hobbyking YEP 80A (2~6S) SBEC Brushless Speed Controller Save US$: 12.25
Mount strap for 68mm Alloy DPS Fan Save US$: 0.18
Transparent PET Film-3C 1 Metre Save US$: 1.17
Transparent PET Film-2C 1 Metre Save US$: 0.99
Hobby King 3.7g / .4kg / .10sec Micro Servo Save US$: 0.78
Large-ring Blue Body Clips 10Pcs Save US$: 0.57
Master Airscrew - Balsa Stripper Save US$: 0.86
Master Airscrew - Razor Plane Save US$: 0.89
X-BLADE Spare SK-5 Steel blades (10pcs/set) Save US$: 0.63
greenfeet is offline Find More Posts by greenfeet
Old Aug 14, 2012, 01:22 PM
Chriscool is offline
Find More Posts by Chriscool
Chriscool's Avatar
Suisse, VS, Vouvry
Joined Apr 2009
Find my codes here: http://hk.rc-international.info/swarm/chriscool (valid until August 28, 2012)
USBasp AVR Programming Device for ATMEL proccessors Save US$: 0.80
Hobby King Quadcopter Power Distribution Board Save US$: 1.71
Metal Push Rods M2xL300 (10pcs/set) Save US$: 0.70
Control Rod/ABS Sleeve (1pc/bag) Save US$: 0.27
Chriscool is offline Find More Posts by Chriscool
Old Aug 15, 2012, 10:17 AM
sarapintas is offline
Find More Posts by sarapintas
Joined Jan 2012
Find my codes here: http://hk.rc-international.info/swarm/sarapintas (valid until August 28, 2012)
ZIPPY Compact 5000mAh 3S 25C Lipo Pack Save US$: 3.57
sarapintas is offline Find More Posts by sarapintas
Old Aug 15, 2012, 04:18 PM
3DMON is offline
Find More Posts by 3DMON
KK4EHM--FPV Mon!
3DMON's Avatar
United States, FL, Sebastian
Joined May 2005
Find my codes here: http://hk.rc-international.info/swarm/3dmon (valid until August 28, 2012)
2213N 800Kv Brushless Motor (USA Warehouse) Save US$: 0.63
3DMON is offline Find More Posts by 3DMON
Old Aug 16, 2012, 01:26 PM
guslinx is offline
Find More Posts by guslinx
Gusac
Joined Dec 2010
Find my codes here: http://hk.rc-international.info/swarm/rcpilotacro (valid until August 30, 2012)
Hobbyking X666 Glass Fiber Quadcopter Frame 666mm Save US$: 3.42
Hobbyking 60w Power Supply                         Save US$: 0.60
Hobbyking X550 Glass Fiber Tilt Camera Mount       Save US$: 1.99
guslinx is offline Find More Posts by guslinx
Old Aug 19, 2012, 05:02 PM
sinemaci is offline
Find More Posts by sinemaci
Joined Aug 2012
hobbyking swarm
hi...
http://hk.rc-international.info/swarm/suleyman-özcan (valid until September 02, 2012)
NTM Prop Drive Series 28-30A 750kv / 140w Save US$: 2.79
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Save US$: 0.19
sinemaci is offline Find More Posts by sinemaci
Old Aug 20, 2012, 09:15 AM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
I have created an Android App with which you can browse the latest additions to the Hobbyking catalogue, product arrivals for the international and regional warehouses and browse buddy codes.
The application is available from Google Play (link below). If you are happy with the App, then I would like to see that in the Google Play reviews or reply.
If there is enough interest, I will make it available for the iPhone too. Post a reply if you are interested.
Download the App here: CrashingDutchmans Hobbyking App
In the mean time, keep your buddy codes posted at http://hk.rc-international.info/swarm to have them shown in my application.
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Aug 21, 2012, 10:11 PM
greenfeet's Avatar
Find my codes here: http://hk.rc-international.info/swarm/trippergreenfeet (valid until September 05, 2012)
Quanum 2.4Ghz Telemetry System (Volt/Amp/Temp/mAh) V2 Save US$: 3.63
ZIPPY 70mAh 20C single cell Save US$: 1.19
2 Pin 6 x Pico Plug Charging Set Eflite compatible. Save US$: 0.88
Mini Plug Extention for Micro Battery 10cm (5pcs/bag) Save US$: 1.47
Discussion Hobby King "SWARM" Sales mattyhawk HobbyKing 39 Feb 16, 2015 02:53 PM
Cool Official Banana Hobby LIVECHAT Conversation Thread dgbuggy Banana Hobby 82 Mar 01, 2010 06:02 PM
FAQ Honeybee King II official Q&A thread my c210 Micro Helis 9 Jan 14, 2010 04:00 PM
Discussion The Official 2009 Hobby Lobby Thanksgiving Sale Thread! Jason Cole Hobby Express (Formerly Hobby Lobby) 2242 Dec 08, 2009 05:33 PM
Discussion Official Hobby Lobby Thanksgiving Sale Thread Jason Cole Hot Online Deals 2927 Jan 06, 2008 06:19 AM
