This thread is privately moderated by Sid3ways, who may elect to delete unwanted replies.
Old Jul 10, 2012, 11:28 AM
Never too much detail
fredo21's Avatar
Australia, VIC, Hampton
Joined Jan 2007
Turnigy AAA LSD 900mah Low Self Discharge (ready to use)
[S]$0.99[/S] $0.69* (buddy<br>price 30%, -$0.3)
Turnigy nano-tech 180mah 3S 25~40C Lipo Pack
[S]$6.24[/S] $4.75* (buddy<br>price 24%, -$1.49)
Turnigy nano-tech 180mah 2S 25~40C Lipo Pack
[S]$4.16[/S] $3.17* (buddy<br>price 24%, -$0.99)
Turnigy nano-tech 2200mah 2S 25~50C Lipo Pack
[S]$11.84[/S] $8.56* (buddy<br>price 28%, -$3.28)
Turnigy AA LSD 2400mAh Low Self Discharge (ready to use)
[S]$1.59[/S] $1.43* (buddy<br>price 10%, -$0.16)
fredo21 is offline Find More Posts by fredo21
Old Jul 11, 2012, 07:32 PM
Gusac
Joined Dec 2010
Find my codes here: http://hk.rc-international.info/swarm/rcpilotacro (valid until July 26, 2012)
Metal Push Rods M2xL300 (10pcs/set) Save US$: 0.70
Twelve 2-56 Gold-N-Clevises Save US$: 0.72
Pull/Pull Coated Steel Wire 0.8mm (5m/Bag) Save US$: 0.64
Control Rod Window L38xH4.5mm (10pcs) Save US$: 0.97
Threaded Ends M2xL20mm (10pcs/set) Save US$: 0.94
OrangeRx Futaba FASST 2.4Ghz Receiver Case Save US$: 1.17
guslinx is offline Find More Posts by guslinx
Old Jul 12, 2012, 03:04 PM
The Netherlands, NB, Veghel
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/mh (valid until July 26, 2012)
JST-XH to JST LED Power Distribution Lead (6 JST) Save US$: 1.31
Peel-n-stick foam tape. 10x5inch 4mm thick Save US$: 1.25
Soft Ferrite Rings 16x7x10 (5pc) Save US$: 0.61
Antenna Pipe and Cap (1Pc/Bag) - A2016T Save US$: 0.18
Turnigy Battery Strap 330mm Save US$: 0.37
MarkQ is offline Find More Posts by MarkQ
Old Jul 12, 2012, 06:09 PM
Joined Jan 2012
Find my codes here: http://hk.rc-international.info/swarm/sarapintas (valid until July 23, 2012)
M4 Nylock Nut (10pcs) - A2106T Save US$: 0.18
2.4Ghz 7DB Antenna for FrSky Modules (And compatible Radios/Modules) Save US$: 4.62
Washers #3(bag of 100pc) Save US$: 0.73
FPV 12dBi 5.8GHz Antenna Save US$: 1.64
sarapintas is offline Find More Posts by sarapintas
Old Jul 13, 2012, 03:40 AM
fredo21's Avatar
Joined Jan 2007
Mr Spike! Spike wheel tool.
[S]$1.99[/S] $1.46* (buddy<br>price 27%, -$0.53)
Male Molex 1.25 to Female JR Servo Extension (1pc)
[S]$0.55[/S] $0.35* (buddy<br>price 36%, -$0.2)
Radjet 420 - Replacement Decal Set
[S]$3.36[/S] $2.56* (buddy<br>price 24%, -$0.8)
Radjet 420 - Replacement Canopy
[S]$1.76[/S] $1.34* (buddy<br>price 24%, -$0.42)
Radjet 420 - Replacement Main Wing Set
[S]$7.36[/S] $5.61* (buddy<br>price 24%, -$1.75)
Radjet 420 - Replacement Fuselage w/ Motor Mount
[S]$11.36[/S] $8.66* (buddy<br>price 24%, -$2.7)
Radjet 420 - Replacement Vertical Stabilizer
Old Jul 13, 2012, 11:53 AM
Sweden
Joined Feb 2009
Find my codes here: http://hk.rc-international.info/swarm/box414 (valid until July 27, 2012)
Turnigy nano-tech 3300mah 4S 25~50C Lipo Pack Save US$: 10.84
box414 is offline Find More Posts by box414
Old Jul 14, 2012, 02:26 PM
Platinum Member
Canada
Joined Dec 2004
FPV Diversity Reciever
58$ OFF!!! ImmersionRC DUO5800v2 5.8GHz Diversity Receiver w/TrackerLink - Dual Output
http://www.hobbyking...91-D0B1300D9B42
ImmersionRC DUO5800v2 5.8GHz Diversity Receiver w/TrackerLink, Dual Output
- A/V receiver with diversity antenna inputs
- TrackerLink for direct link to Antenna Tracker
- Sensitive receivers (-85dBm)
- SMA antenna connectors, compatible with standard 5.8GHz antennas (omni or directional)
- Frequencies: 5740, 5760, 5780, 5800, 5820, 5840, 5860MHz
- Supplied with two 5.8GHz ‘Rubber-duck’ antennas
- Not affected by 2.4GHz R/C radios!
- Audible Low-battery alarm
- Weight: 200 grams
- Size: 80 x 100 x 23mm
- Input voltage range: 6 – 12V at 500 mA (3s Lipo Ideal)
- NEW: 2011 version uses switching regulators for lower power consumption, and runs much cooler.
Quote
MultiQuote
Edit
Blog This
Report
astelz is offline Find More Posts by astelz
Old Jul 15, 2012, 03:34 AM
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Find my codes here: http://hk.rc-international.info/swarm/eagle34 (valid until July 28, 2012)
3.17mm Prop Saver w/ Adapter and 3 bands Save US$: 1.06
KD 36-16M Brushless Outrunner 1050Kv Save US$: 10.09
Eagle34 is offline Find More Posts by Eagle34
Latest blog entry: Landing by Ben Fisher
Old Jul 18, 2012, 07:26 PM
130 mph :)
3d astronaut's Avatar
Joined Sep 2011
Find my codes here: http://hk.rc-international.info/swarm/cloudflying (valid until July 30, 2012)
Turnigy 9X LCD Backlight Kit - Blue (DIY) Save US$: 1.36
4mm Gold Connectors 10 pairs (20pc) Save US$: 0.51
Hobbyking SS Series 40-50A ESC Save US$: 1.47
3d astronaut is offline Find More Posts by 3d astronaut
Old Jul 20, 2012, 08:59 AM
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Find my codes here: http://hk.rc-international.info/swarm/aero-andy (valid until August 03, 2012)
ZIPPY Compact 1500mAh 3S 25C Lipo Pack Save US$: 2.22 Now only $7.11
Aero Andy is offline Find More Posts by Aero Andy
Old Jul 20, 2012, 09:06 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Clear Foam Glue (Medium Cure) - Small 20g Save US$: 0.09 Now only $0.61
Old Jul 20, 2012, 12:38 PM
abroadhurst94's Avatar
United Kingdom, England, Lincoln
Joined Jun 2011
Find my codes here: http://hk.rc-international.info/swarm/abroadhurst94 (valid until August 3, 2012)
USBasp AVR Programming Device for ATMEL proccessors Save US$: 0.80
abroadhurst94 is offline Find More Posts by abroadhurst94
Old Jul 20, 2012, 04:22 PM
United States, IL, Rantoul
Joined Mar 2010
Find my codes here: http://hk.rc-international.info/swarm/joercee (valid until Aug 2, 2012)
hexTronik 16gram Brushless Outrunner 1700kv Save US$: 1.26
Hobby King 401B AVCS Digital Head Lock Gyro Save US$: 2.29
Reinforced Plastic Undercarriage (Pair) STRONG Save US$: 0.14
Hatch Hinge 33x9mm (10pcs) Save US$: 0.70
TGS Sport 6x4E Precision propeller Save US$: 0.28
45CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag) Save US$: 0.78
JoeRCee is offline Find More Posts by JoeRCee
Old Jul 21, 2012, 09:26 AM
fredo21's Avatar
Joined Jan 2007
Ex-Long CA Ex-Tips (1pc)
[S]$0.23[/S] $0.14* (buddy<br>price 39%, -$0.09)
CA Applicator Fine (1pc)
[S]$0.49[/S] $0.26* (buddy<br>price 47%, -$0.23)
Hobbyking Self Adhesive Centre of Gravity Marker (3pc)
[S]$0.89[/S] $0.36* (buddy<br>price 60%, -$0.53)
Master Airscrew - Balsa Stripper
[S]$4.99[/S] $4.13* (buddy<br>price 17%, -$0.86)
All my buddy-codes here
Discussion Hobby King "SWARM" Sales mattyhawk HobbyKing 37 May 24, 2012 02:37 PM
Cool Official Banana Hobby LIVECHAT Conversation Thread dgbuggy Banana Hobby 82 Mar 01, 2010 06:02 PM
FAQ Honeybee King II official Q&A thread my c210 Micro Helis 9 Jan 14, 2010 04:00 PM
Discussion The Official 2009 Hobby Lobby Thanksgiving Sale Thread! Flyboone Hobby Lobby 2242 Dec 08, 2009 05:33 PM
Discussion Official Hobby Lobby Thanksgiving Sale Thread Flyboone Hot Online Deals 2927 Jan 06, 2008 06:19 AM
