This thread is privately moderated by Sid3ways, who may elect to delete unwanted replies.
Old May 22, 2012, 11:54 AM
abroadhurst94 is offline
Find More Posts by abroadhurst94
abroadhurst94's Avatar
United Kingdom, England, Lincoln
Joined Jun 2011
Originally Posted by Chevycruizer View Post
Guys,
I am in the US military (Air Force) and currently deployed in Afghanistan. The server block the web site to upload the buddy codes. Can someone hook me up and upload my codes from the order I placed yesterday? Most of the stuff is for multi rotor and there are some good deals in there. Thanks a ton in advance!
Thanks, John
Done But it says the codes are valid for different lengths of time, some only till tomorrow, others until June 4th.
Find my codes here: http://hk.rc-international.info/swarm/chevycruizer (valid until May 22, 2012)
Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK Save US$: 0.61
Turnigy Pure-Silicone Wire 16AWG (1mtr) Red Save US$: 0.61
Front Wheel Steering Arm and Mount Set 40mm (5sets) Save US$: 0.34
Turnigy Heat Shrink Tube 25mm Transparent (1mtr) Save US$: 0.18
Hex locknuts M3 10pc Save US$: 0.45
TURNIGY Plush 10amp 9gram Speed Controller Save US$: 2.49
NTM Prop Drive 2826 Series Replacement Shaft Save US$: 0.41
HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) Save US$: 0.47
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Save US$: 0.20
USBasp AVR Programming Device for ATMEL proccessors Save US$: 0.80
Hobby King Quadcopter Power Distribution Board Save US$: 1.71
10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) Save US$: 1.72
NTM Prop Drive 28-26 1000KV / 315W Save US$: 2.55
NTM Prop Drive 28 Series Accessory Pack Save US$: 0.74
abroadhurst94 is offline Find More Posts by abroadhurst94
Old May 23, 2012, 07:39 AM
guslinx is offline
Find More Posts by guslinx
Gusac
Joined Dec 2010
Find my codes here: http://hk.rc-international.info/swarm/rcpilotaero (valid until June 06, 2012)
Resin Dick Dastardly Pilot 85mmx87mmx47mm Save US$: 1.26
Male XT60 connectors (5pcs/bag) GENUINE Save US$: 0.20
HobbyKing 2824 Brushless Outrunner 1300KV Save US$: 1.11
Light Plane Plastic Part set (10pcs) Save US$: 0.06
guslinx is offline Find More Posts by guslinx
Old May 24, 2012, 04:03 AM
Halford is offline
Find More Posts by Halford
Belgium, Brussels
Joined Jul 2010
Find my codes here: http://hk.rc-international.info/swarm/halford (valid until June 07, 2012)
Prop adapter w/ Alu Cone M8x5mm shaft (Grub Screw Type) Save US$: 0.46
Halford is offline Find More Posts by Halford
Old May 26, 2012, 02:06 PM
Night.Fury is offline
Find More Posts by Night.Fury
Joined Jan 2012
  • HK-250GT Main Gear
  • HK-250GT Main Shaft (3pcs/set)
Night.Fury
Night.Fury is offline Find More Posts by Night.Fury
Old May 29, 2012, 04:48 PM
folke190d is offline
Find More Posts by folke190d
Scratch build warbirds
Canada, NB, Beresford
Joined Mar 2011
Buddy codes good till june 12
Hobbyking DC-4S Balance Charger & Cell Check
http://www.hobbyking.com/buddy.asp?c...5-A6B4ACA8F35F
Turnigy 3mm Heat Shrink Tube Yellow (1mtr)
http://www.hobbyking.com/buddy.asp?c...3-E0FF7DE51E78
Turnigy 3mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...9-630F7D18323E
Turnigy 3mm Heat Shrink Tube - RED (1
http://www.hobbyking.com/buddy.asp?c...9-76CE220CA9AD
APC style propeller 8x6-E
http://www.hobbyking.com/buddy.asp?c...C-3EAA7818814A
HobbyKing Glow Plug No.3 (HOT)
http://www.hobbyking.com/buddy.asp?c...3-22E54CA35477
Silicon fuel pipe (1 mtr) White for Nitro En
http://www.hobbyking.com/buddy.asp?code=4CC69FSilicon fuel pipe (1 mtr) White for Nitro EnB5-9A5F-4895-98C8-A2A758853376
Turnigy 9X 2.4GHz 8Ch Receiver (V2)
http://www.hobbyking.com/buddy.asp?c...E-C57C10BA69BC
folke190d is offline Find More Posts by folke190d
Old May 30, 2012, 05:21 AM
F5D is offline
F5D
Find More Posts by F5D
F5D
F5D's Avatar
Austria
Joined Aug 2003
new codes!
Alloy Anti-Slip TX Control Sticks Long (Futaba TX Blue)
http://www.hobbyking.com/buddy.asp?c...D-C5FA00C86935
Turnigy nano-tech 180mAh 15c Round Lipo
http://www.hobbyking.com/buddy.asp?c...3-3AC340CD00B7
Turnigy nano-tech 130mAh 1s 15c Round Lipo
http://www.hobbyking.com/buddy.asp?c...3-021F5CB506AC
Turnigy nano-tech 1800mah 2S 65~130C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...8-8C6C4204AD0C
http://www.hobbyking.com/buddy.asp?c...8-18C1E54CE6F9
20CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
http://www.hobbyking.com/buddy.asp?c...A-B0722676E0D9
thanks
Peter
F5D is offline Find More Posts by F5D
Old May 31, 2012, 06:50 AM
Virginia Jim is offline
Find More Posts by Virginia Jim
Virginia Jim's Avatar
United States, NC, Durham
Joined Mar 2011
Stock up on previously out of stock parts!
My codes are valid until June 13, 2012
I've got to try this tiny alarm for my favorite park flyer!
On-Board Lipoly Low Voltage Alarm 2s~3s
Reg price: $1.93 Swarm Price: $1.75 Save US$: 0.18
Anybody else tired of buying motor mounts that don't supply the right sized bolts?
Hex Screw M2x10 (20pcs)
Reg price: $ Swarm Price: $ Save US$: 0.28
Same pitch for nuts here!
Hex locknuts M2 50pc
Reg price: $ 3.95 Swarm Price: $1.86 Save US$: 2.09
This is the part that breaks most often on the HK190/9958 Helis! Get 'em while they last!
HK190 Main Blade Set
Reg price: $2.28 Swarm Price: $1.45 Save US$: 0.83
Inherit a crashed plane like I did? Get new control rods for damaged parts!
Control Rod/ABS Sleeve (1pc/bag)
Reg price: $1.12 Swarm Price: $0.85 Save US$: 0.27
Don't bother with those other branded slow fly props. These will take a hit!
SF E-Prop 9x4.7 / 229x119.5mm w/ Adapters Black (5pcs/bag)
Reg price: $2.69 Swarm Price: $2.25 Save US$: 0.44
Great for those ultra cheap, but fast ParkJets!
TGS Sport 4.1x4.1E Precision propeller
Reg price: $1.14 Swarm Price: $0.73 Save US$: 0.41
Everybody needs JST plugs for Speed controller and accessory connections!
JST Male 2 pin connector set (10pcs/set)
Reg price: $0.89 Swarm Price: $0.51 Save US$: 0.38
JST Female 2 pin connector set (10pcs/set)
Reg price: $0.75 Swarm Price: $0.51 Save US$: 0.24
This is the coolest battery checker around! Does 1, yes ONE to 8 cells. YOU adjust the alarm voltage!
Hurry. These little gems don't last!
Click the link to see the cool new case they come in. Perfect to protect your pocket from those prongs!
Hobbyking 2-8S Cell Checker with Low Voltage Alarm
Reg price: $3.64 Swarm Price: $3.15 Save US$: 0.49
Great replacement wheels for park fliers to allow landing on grass fields!
Super Light Multi Spoke Wheel D40x11mm (5pcs/bag)
Reg price: $1.60 Swarm Price: $1.22 Save US$: 0.38
You can also find my codes at: http://hk.rc-international.info/swarm/virjim (valid until June 13, 2012)
Happy Flying!
VJ
Virginia Jim is offline Find More Posts by Virginia Jim
Old May 31, 2012, 08:16 AM
DonQ8401 is offline
Find More Posts by DonQ8401
Why am I addicted!!!
DonQ8401's Avatar
United States, IL, Columbia
Guys I am new to this. I don't know where to put the codes to get the discount with HK. Can someone help me?
DonQ8401 is offline Find More Posts by DonQ8401
Old May 31, 2012, 08:28 PM
realbob is offline
Find More Posts by realbob
Crash and crash!
realbob's Avatar
Canada, QC, Montreal
Joined Oct 2010
@ DonQ8401, first, logon into HK website, then come back here and click on the link, you will have access to buddy price. But you can only put 1 or 2 per order.
realbob is offline Find More Posts by realbob
Old May 31, 2012, 10:03 PM
FiveZigen is offline
Find More Posts by FiveZigen
Canada, BC, Terrace
Joined Feb 2010
Find my codes here: http://hk.rc-international.info/swarm/fivezigen (valid until June 05, 2012)
Grub Screw Set M3x4 10 Pack Save US$: 0.84
Hex-nuts M2 10pc Save US$: 0.44
HK-500GT Landing Skid Pipe (Align part # H50090) Save US$: 1.03
HK-500GT Landing Skid (Align part # H50122) Save US$: 1.22
425mm Plastic Main Blades Save US$: 2.95
Twin pack charge lead (2 x 3S)6S w/ XT60 Save US$: 0.65
HK600GT landing skid (H60039) Save US$: 0.23
440mm Flybar HK-550GT Save US$: 1.49
Turnigy Glow Plug Lighter Tool Save US$: 0.36
Blind Nut M2 size (10pcs) Save US$: 0.30
FiveZigen is offline Find More Posts by FiveZigen
Old May 31, 2012, 10:53 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Find my codes here: http://hk.rc-international.info/swarm/cloudflying (valid until June 13, 2012)
F86 Sabre 35mm EDF Micro Jet Cockpit Canopy Save US$: 0.31
Female Molex 1.25 to Male JR Servo Extension (1pc) Save US$: 0.20
3d astronaut is offline Find More Posts by 3d astronaut
Old Jun 01, 2012, 07:29 AM
ardo is offline
Find More Posts by ardo
Joined Dec 2008
Quadcopter
Find my codes here: http://hk.rc-international.info/swarm/ardo (valid until June 15, 2012)
Hobbyking X666 Glass Fiber Quadcopter Frame 666mm Save US$: 3.42
ardo is offline Find More Posts by ardo
Old Jun 01, 2012, 11:42 AM
freedomflight is offline
Find More Posts by freedomflight
Joined Dec 2011
Find my codes here: http://hk.rc-international.info/swarm/freedomflight (valid until June 15, 2012)
Turnigy nano-tech 160mah 1S 25~40C Lipo Pack (Kyosho, E-flite, Parkzone Etc) Save US$: 0.42
2mm Gold Connectors 10 pairs (20pc) Save US$: 0.66
Solo Pro FP II Main Shaft Set Save US$: 0.23
APC style propeller 10x5-E Save US$: 0.13
freedomflight is offline Find More Posts by freedomflight
Discussion Hobby King "SWARM" Sales mattyhawk HobbyKing 39 Feb 16, 2015 02:53 PM
Cool Official Banana Hobby LIVECHAT Conversation Thread dgbuggy Banana Hobby 82 Mar 01, 2010 06:02 PM
FAQ Honeybee King II official Q&A thread my c210 Micro Helis 9 Jan 14, 2010 04:00 PM
Discussion The Official 2009 Hobby Lobby Thanksgiving Sale Thread! Jason Cole Hobby Express (Formerly Hobby Lobby) 2242 Dec 08, 2009 05:33 PM
Discussion Official Hobby Lobby Thanksgiving Sale Thread Jason Cole Hot Online Deals 2927 Jan 06, 2008 06:19 AM
