This thread is privately moderated by Sid3ways, who may elect to delete unwanted replies.
Old May 15, 2012, 03:08 AM
F5D is offline
F5D
Find More Posts by F5D
F5D
F5D's Avatar
Austria
Joined Aug 2003
new codes!
X-BLADE Spare SK-5 Steel blades (10pcs/set)
http://www.hobbyking.com/buddy.asp?c...6-E2D143DB5B11
Turnigy nano-tech 1200mah 1S 15C Round Lipo
http://www.hobbyking.com/buddy.asp?c...2-C42BFA7C3F59
Hobbyking DC-4S Balance Charger & Cell Checker 30w 2s~4s
http://www.hobbyking.com/buddy.asp?c...9-35CD06D1609B
thanks
Peter
F5D is offline Find More Posts by F5D
Old May 15, 2012, 03:34 AM
davidvm3 is offline
Find More Posts by davidvm3
United States, CA, Huntington Beach
Joined Feb 2012
Find my codes here: http://hk.rc-international.info/swarm/davidvm3 (valid until May 29, 2012)
4MM Banana Plug / Charge Plug (solder type) (2 pair/bag) Save US$: 0.59
TurboThumbs Super Big Futaba Rocker (1pair) Red Save US$: 2.69
PLUG-KING Multi-19 Mega Charge Plug Adapter Set Save US$: 1.00
EC5 5mm Connector (Pair) Save US$: 0.08
2 Pin JST to 6 x E-Flight Ultra Micro plug Charging Harness Save US$: 0.50
JR and Spektrum Trainer Cable (Buddy box Cable) 2.1m Save US$: 0.56
Servo Terminals (JR) Gold Plated (10pairs/set) Save US$: 0.58
Woven Carbon Fiber Sheet 300x100 (1.5MM Thick) Save US$: 1.32
Flat 26AWG servo wire 1mtr (R/B/W) Save US$: 0.15
Balance Plug Savers (JST-XH 6s) (5pc Per Bag) Save US$: 1.06
Sorry for the duplicate, I just put two orders in. Anyway, I was wondering if you have to spend over $100 to get buddy codes. Is this true? Thanks!
davidvm3 is offline Find More Posts by davidvm3
Old May 15, 2012, 12:21 PM
IndiaHobby is offline
Find More Posts by IndiaHobby
Fly and Drive RC
IndiaHobby's Avatar
United States, MD, Laurel
Joined Mar 2010
2mm Gold Connectors (20pc) : Save 55 cents !
Gold Plated For Smooth Current Flow.
Each connector weighs less than 1 gm.
IndiaHobby is offline Find More Posts by IndiaHobby
Old May 15, 2012, 03:06 PM
folke190d is offline
Find More Posts by folke190d
Scratch build warbirds
Canada, NB, Beresford
Joined Mar 2011
Items i just purchased with buddy codes valid untill may 29th
Turnigy 2650mAh 3S 1C LLF Tx Pack (Futaba/JR)
http://www.hobbyking.com/buddy.asp?c...8-92D5C767EF27
Rhino 460mAh 2S 7.4v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...1-7E2BE9D76847
TURNIGY Voltage Protector
http://www.hobbyking.com/buddy.asp?c...5-1E9A9A52238B
Nose Art - "Pacific Princess" (L/R sided)
http://www.hobbyking.com/buddy.asp?c...A-40BB35BE6B07
CNC Alloy Servo Arm Long (JR)
http://www.hobbyking.com/buddy.asp?c...1-EB826826D817
CNC Alloy Servo Arm Short (JR)
http://www.hobbyking.com/buddy.asp?c...D-4D31B69611B8
http://www.hobbyking.com/buddy.asp?c...0-7BF205554AF6
folke190d is offline Find More Posts by folke190d
Old May 16, 2012, 11:56 AM
zaggy is offline
Find More Posts by zaggy
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/galad (valid until May 30, 2012)
Turnigy Heat Shrink Tube 16mm Transparent (1mtr) Save US$: 0.12
Clear Foam Glue (Medium Cure) - Small 20g Save US$: 0.09
Propeller Adapter (colet type) 3mm Save US$: 0.91
10X6 Propellers (Standard and Counter Rotating) (6pc) Save US$: 1.27
JM 6x4 /152.5x102mm propeller (2pc/bag) Save US$: 0.56
zaggy is offline Find More Posts by zaggy
Old May 20, 2012, 01:06 AM
Chriscool is offline
Find More Posts by Chriscool
Chriscool's Avatar
Suisse, VS, Vouvry
Joined Apr 2009
Hello everybody, find my codes here: http://hk.rc-international.info/swarm/chriscool (valid until June 03, 2012)
Hobby King Quadcopter Power Distribution Board Save US$: 1.71
10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) Save US$: 1.72
Spiral wrap tube ID 5mm / OD 6mm (Black - 2 Metre) Save US$: 0.10
Hatch Hinge 33x9mm (10pcs) Save US$: 0.70
Turnigy Imperial Hex Driver Set (050, 1/16, 5/64 & 3/32) 4pc Save US$: 0.60
Cable/Wire Holder (10pc) Save US$: 0.16
Chriscool is offline Find More Posts by Chriscool
Old May 21, 2012, 07:58 AM
Virginia Jim is offline
Find More Posts by Virginia Jim
Virginia Jim's Avatar
United States, NC, Durham
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/virgjim (valid until June 01, 2012)
Bixler/SkySurfer owners: Finally back in stock! Canopy covers!
Hobbyking Bixler Replacement Canopy Save US$: 0.80
Hex-nuts M2 10pc Save US$: 0.44
Prop adapter w/ Alu Cone 2mm shaft (Grub Screw Type) Save US$: 0.29
Get 'em while they're hot!
VJ
Virginia Jim is offline Find More Posts by Virginia Jim
Old May 22, 2012, 12:31 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
[S]$1.37[/S] $0.87* (buddy<br>price 36%, -$0.5)
T-Connector to MPX Connector Battery Adapter Lead(2pcs)
[S]$2.70[/S] $1.73* (buddy<br>price 36%, -$0.97)
EC5 Battery Harness 12AWG for 2 Packs in Parallel
[S]$4.54[/S] $2.91* (buddy<br>price 36%, -$1.63)
15CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag)
[S]$1.65[/S] $1.06* (buddy<br>price 36%, -$0.59)
45CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag)
[S]$2.17[/S] $1.39* (buddy<br>price 36%, -$0.78)
30CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag)
[S]$1.92[/S] $1.23* (buddy<br>price 36%, -$0.69)
60CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag)
[S]$2.51[/S] $1.61* (buddy<br>price 36%, -$0.9)
Carbon Fiber Tube (hollow) 3x2x750mm
[S]$1.25[/S] $0.52* (buddy<br>price 58%, -$0.73)
Carbon Fiber Rod (solid) 2.5x750mm
[S]$1.35[/S] $0.48* (buddy<br>price 64%, -$0.87)
Turnigy 760LV-HV Dual Pulse Width Selectable Servo Tester
[S]$7.95[/S] $3.66* (buddy<br>price 54%, -$4.29)
Carbon Fiber Rod (solid) 1x750mm
[S]$0.99[/S] $0.24* (buddy<br>price 76%, -$0.75)
Carbon Fiber Rod (solid) 2.0x750mm
[S]$1.15[/S] $0.42* (buddy<br>price 63%, -$0.73)
Turnigy 3A UBEC with Low Voltage Buzzer
[S]$4.39[/S] $2.81* (buddy<br>price 36%, -$1.58)
JST-XH to JST LED Power Distribution Lead
[S]$1.99[/S] $0.68* (buddy<br>price 66%, -$1.31)
Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo (USA Warehouse)
[S]$8.29[/S] $6.52* (buddy<br>price 21%, -$1.77)
Carbon Strip 1x6x750mm (5pcs/set)
[S]$5.98[/S] $3.84* (buddy<br>price 36%, -$2.14)
Carbon Fiber Rod (solid) 1.8x750mm
Micro JST Parallel Charge Lead (6 plugs)
[S]$3.42[/S] $2.19* (buddy<br>price 36%, -$1.23)
Carbon Fiber Square Tube 750x3mm
[S]$1.49[/S] $0.65* (buddy<br>price 56%, -$0.84)
Male JST-XH
[S]$1.99[/S] $1.32* (buddy<br>price 34%, -$0.67)
Hobbyking Model Aircraft Stand (small)
[S]$4.95[/S] $3.86* (buddy<br>price 22%, -$1.09)
Mr JIG - Soldering Aid
[S]$7.95[/S] $3.50* (buddy<br>price 56%, -$4.45)
All my buddy-codes here
3drcparts is offline Find More Posts by 3drcparts
Old May 22, 2012, 06:00 AM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Turnigy receiver controlled switch. Save $0.46
http://www.hobbyking.com/buddy.asp?c...B-F23854B086B5
Peel-n-stick foam. Save $1.05 and ONLY PAY $0.24
http://www.hobbyking.com/buddy.asp?c...7-661DF05D28A5
Codes good June 3rd.
healthyfatboy is offline Find More Posts by healthyfatboy
Old May 22, 2012, 08:34 AM
Flying V is offline
Find More Posts by Flying V
Porro et Sursum
Flying V's Avatar
Australia, New South Wales, Lismore
Joined Oct 2010
Flying V is offline Find More Posts by Flying V
Old May 22, 2012, 08:40 AM
Flying V is offline
Porro et Sursum
Flying V's Avatar
Joined Oct 2010
Fresh codes
MG14s
http://www.hobbyking.com/buddy.asp?c...7-3D203F7D1B42
APC 7x6
http://www.hobbyking.com/buddy.asp?c...F-628CE8110866
BLUE LEDs
http://www.hobbyking.com/buddy.asp?c...2-50063D21CAD8
WHITE LEDs
http://www.hobbyking.com/buddy.asp?c...1-CDA3609B7969
Aussie warehouse codes.
Discussion Hobby King "SWARM" Sales mattyhawk HobbyKing 39 Feb 16, 2015 02:53 PM
Cool Official Banana Hobby LIVECHAT Conversation Thread dgbuggy Banana Hobby 82 Mar 01, 2010 06:02 PM
FAQ Honeybee King II official Q&A thread my c210 Micro Helis 9 Jan 14, 2010 04:00 PM
Discussion The Official 2009 Hobby Lobby Thanksgiving Sale Thread! Jason Cole Hobby Express (Formerly Hobby Lobby) 2242 Dec 08, 2009 05:33 PM
Discussion Official Hobby Lobby Thanksgiving Sale Thread Jason Cole Hot Online Deals 2927 Jan 06, 2008 06:19 AM
