This thread is privately moderated by Sid3ways, who may elect to delete unwanted replies.
Old Apr 30, 2012, 10:03 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
CA Applicator Fine (1pc)
[S]$0.49[/S] $0.26* (discount 47%, -$0.23)
AC Hinge L25*W20*H0.3 (10pcs)
[S]$0.61[/S] $0.46* (discount 25%, -$0.15)
JST-XH 4S Wire Extension 20cm (10pcs/bag)
[S]$3.93[/S] $3.42* (discount 13%, -$0.51)
Turnigy Pure-Silicone Wire 12AWG (1mtr) BLACK
[S]$1.99[/S] $1.50* (discount 25%, -$0.49)
5inch Ratchet Clamp Tool
[S]$0.99[/S] $0.65* (discount 34%, -$0.34)
Male XT60
[S]$1.07[/S] $0.81* (discount 24%, -$0.26)
Turnigy 3A UBEC with Low Voltage Buzzer
[S]$4.39[/S] $2.81* (discount 36%, -$1.58)
Threaded Ends M2xL20mm (10pcs/set)
[S]$1.79[/S] $0.85* (discount 53%, -$0.94)
Model Pilot L85xW42xH90
[S]$4.50[/S] $3.96* (discount 12%, -$0.54)
EC3 Male - Traxxas Female
[S]$1.71[/S] $1.02* (discount 40%, -$0.69)
EC3 Female - Traxxas Male
[S]$1.54[/S] $0.98* (discount 36%, -$0.56)
Traxxas Female - Tamiya Male
[S]$1.85[/S] $0.80* (discount 57%, -$1.05)
Turnigy Long Shaft 4pc Hex driver set
[S]$6.95[/S] $5.92* (discount 15%, -$1.03)
Male EC3
[S]$2.77[/S] $2.07* (discount 25%, -$0.7)
20CM Servo Lead (JR) 32AWG Ultra Light(10pcs/bag)
[S]$2.29[/S] $1.43* (discount 38%, -$0.86)
HXT 4MM to Banana Plug Charge Lead Adapter
[S]$3.14[/S] $2.01* (discount 36%, -$1.13)
Twisted 30CM Servo Lead Extention (JR) 22AWG (5pcs/set)
[S]$2.79[/S] $1.81* (discount 35%, -$0.98)
Charge Cable w/ Male XT60
[S]$2.49[/S] $2.04* (discount 18%, -$0.45)
Turnigy High Density R/C LED Flexible Strip-White (1mtr)
[S]$5.26[/S] $3.41* (discount 35%, -$1.85)
USB Simulator Cable Phoenix RC
[S]$7.98[/S] $5.12* (discount 36%, -$2.86)
JST-XH 3S Wire Extension 20cm (10pcs/bag)
[S]$3.31[/S] $2.84* (discount 14%, -$0.47)
Turnigy Park450 Brushless Outrunner 890kv (USA Warehouse)
[S]$16.30[/S] $14.20* (discount 13%, -$2.1)
Linkage Stopper M3x2xL11.2mm (10pcs/set)
[S]$1.52[/S] $0.97* (discount 36%, -$0.55)
Turnigy High Density R/C LED Flexible Strip-Blue (1mtr)
[S]$5.10[/S] $3.41* (discount 33%, -$1.69)
Lumifly Lighting system FAA Configurable
[S]$10.35[/S] $8.64* (discount 17%, -$1.71)
Male T-Connector
[S]$1.15[/S] $0.87* (discount 24%, -$0.28)
Turnigy High Density R/C LED Flexible Strip-Red (1mtr)
[S]$4.03[/S] $3.41* (discount 15%, -$0.62)
Turnigy nano-tech 180mAh 2S 25C Lipo Pack (E-flite micro series compatible)
[S]$4.99[/S] $2.56* (discount 49%, -$2.43)
T-Connector to XT60 Battery Adapter Lead (2pc)
[S]$2.47[/S] $1.58* (discount 36%, -$0.89)
Light Foam Wheel (Diam: 30, Width: 11mm) (5pcs/bag)
[S]$1.36[/S] $1.03* (discount 24%, -$0.33)
XT-60 to HXT 4mm Battery Adapter Lead (2pc)
[S]$3.29[/S] $2.11* (discount 36%, -$1.18)
Female Tamiya
[S]$2.63[/S] $1.96* (discount 25%, -$0.67)
XT60 to T-Connector Battery Adapter Lead (2pc)
[S]$2.32[/S] $1.48* (discount 36%, -$0.84)
Light Foam Wheel (Diam: 40, Width: 11mm) (5pcs/bag)
[S]$1.84[/S] $1.40* (discount 24%, -$0.44)
5 Spoke Wheels Shock Absorbing D75xH18mm (5pcs/bag)
[S]$4.20[/S] $2.56* (discount 39%, -$1.64)
Light Foam Wheel (Diam: 55, Width: 10mm) (5pcs/bag)
[S]$2.56[/S] $1.95* (discount 24%, -$0.61)
Light Foam Wheel Diam: 60, Width: 10mm (5pcs/bag)
[S]$3.40[/S] $2.07* (discount 39%, -$1.33)
TRX plug battery harness for 2 packs in series
[S]$1.48[/S] $1.24* (discount 16%, -$0.24)
Scale alloy hub rubber wheel 2.0inch
[S]$3.45[/S] $1.95* (discount 43%, -$1.5)
T-Connector - JST Male in-line power adapter
[S]$1.31[/S] $0.84* (discount 36%, -$0.47)
EC5 Battery Harness 12AWG for 2 Packs in Series
[S]$3.99[/S] $2.56* (discount 36%, -$1.43)
T-Connector Harness for 2 Packs in Parallel (1pc)
[S]$1.97[/S] $0.97* (discount 51%, -$1)
Multi-Adapter All-in-One Balance Board (TP/HP/XH/EH)
[S]$2.95[/S] $1.89* (discount 36%, -$1.06)
EC3 Female - Tamiya Male
[S]$1.18[/S] $0.65* (discount 45%, -$0.53)
5 Spoke Wheels Shock Absorbing D70xH18mm (5pcs/bag)
Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo (USA Warehouse)
[S]$8.29[/S] $6.52* (discount 21%, -$1.77)
All my buddy-codes here
3drcparts is offline Find More Posts by 3drcparts
Old Apr 30, 2012, 11:38 PM
AirSick is offline
Find More Posts by AirSick
United States, WA, Sumner
Joined Sep 2003
Find my codes here: http://hk.rc-international.info/swarm/airsick (valid until May 13, 2012)
Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo (USA Warehouse) Save US$: 1.82
Turnigy nano-tech 350mah 3S 65~130C Lipo Pack (USA Warehouse) Save US$: 0.93
Find my codes here: http://hk.rc-international.info/swarm/airsick (valid until May 04, 2012)
Hobbyking 50mm Alloy EDF 4200kv (4s Version) Save US$: 2.65
Wire Mesh Guard Blue 10mm (1mtr) Save US$: 0.19
Wire Mesh Guard Orange 10mm (1mtr) Save US$: 0.19
Turnigy Teflon Coated Wire 36AWG (1mtr) Black Save US$: 0.36
Turnigy Teflon Coated Wire 36AWG (1mtr) Red Save US$: 0.36
XT-60 to JST Charging Adapter (2pc) Save US$: 0.61
HXT 4mm Connector to T-plug conversion charge lead Save US$: 0.15
Hobbyking Parallel charging Board for 6 packs 2~6S (XT60) Save US$: 3.61
AirSick is offline Find More Posts by AirSick
Old May 01, 2012, 12:03 AM
howsigoin is offline
Find More Posts by howsigoin
United States, WA, King
Joined Oct 2005
Turnigy Plush 60 $27.41 $4.70 off
http://www.hobbyking.com/buddy.asp?c...0-5E98E802C727
howsigoin is offline Find More Posts by howsigoin
Old May 01, 2012, 02:23 PM
Halford is offline
Find More Posts by Halford
Belgium, Brussels
Joined Jul 2010
Find my codes here: http://hk.rc-international.info/swarm/halford (valid until May 15, 2012)
HXT4mm Battery Harness 14AWG for 2 Packs in Parallel Save US$: 1.02
Steel Horn L31 x H30mm (5 Pairs/bag) Save US$: 0.89
De-soldering Braid 2.5mm/1.5m Save US$: 0.23
Halford is offline Find More Posts by Halford
Old May 02, 2012, 04:00 PM
ibrahimkent is offline
Find More Posts by ibrahimkent
Joined Aug 2007
Servo Terminals (Futaba) Gold Plated (10pairs/set)
[S]$1.99[/S] $1.22* (discount 39%, -$0.77)
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
[S]$1.59[/S] $1.40* (discount 12%, -$0.19)
Evotite CA460 Foam Safe Super Glue (Medium)
[S]$4.96[/S] $3.78* (discount 24%, -$1.18)
Clear Foam Glue (Medium Cure) - Large 100ml
[S]$2.49[/S] $2.37* (discount 5%, -$0.12)
TURNIGY Plush 40amp Speed Controller
[S]$21.99[/S] $18.14* (discount 18%, -$3.85)
Twisted 80CM Servo Lead Extention (Futaba) 22AWG (5pcs/set)
[S]$3.79[/S] $2.72* (discount 28%, -$1.07)
HXT Lipo Monitor 3S. A must have for all lipo users!
[S]$2.10[/S] $1.91* (discount 9%, -$0.19)
HobbyKing Glow Plug No.3 (HOT)
[S]$2.59[/S] $2.25* (discount 13%, -$0.34)
ibrahimkent is offline Find More Posts by ibrahimkent
Old May 02, 2012, 05:16 PM
realbob is online now
Find More Posts by realbob
Crash and crash!
realbob's Avatar
Canada, QC, Montreal
Joined Oct 2010
Find my codes here: http://hk.rc-international.info/swarm/realbob ()
2 in 1 Magnetizer and Demagnetizer Tool Save US$: 0.40
TURNIGY BESC Programming Card Save US$: 2.79
TGS Sport 11x7E Precision propeller Save US$: 1.50
Receiver Switch Save US$: 1.13
JST-XH 3S Wire Extension 20cm (10pcs/bag) Save US$: 0.47
TURNIGY Voltage Protector Save US$: 1.38
NTM Prop Drive 35 Series Accessory Pack Save US$: 0.62
HobbyKing Cutting Mat (USA Warehouse) Save US$: 0.27
realbob is online now Find More Posts by realbob
Old May 02, 2012, 11:27 PM
fly_right is offline
Find More Posts by fly_right
fly_right's Avatar
USA, NC, Stanley
Joined Sep 2008
Find my codes here: http://hk.rc-international.info/swarm/fly_right (valid until May 14, 2012)
Turnigy nano-tech 160mah 1S 25~40C Lipo Pack (Kyosho, E-flite, Parkzone Etc) Save US$: 0.42
Turnigy 9X LCD Backlight Kit - Blue (DIY) Save US$: 1.33
Turnigy 30A BRUSHED ESC Save US$: 2.53
fly_right is offline Find More Posts by fly_right
Old May 03, 2012, 03:43 AM
icarustheflier1 is offline
Find More Posts by icarustheflier1
Italia, Umbria, Perugia
Joined Dec 2011
Find my codes here: http://hk.rc-international.info/swarm/lillo64 (valid until May 17, 2012)
Silicon fuel pipe (1 mtr) White for Nitro Engines 4x2.5mm Save US$: 0.41
JM 14x7 / 356x178mm propeller Save US$: 0.20
Turnigy 8mm Hex Socket Screwdriver Save US$: 0.85
icarustheflier1 is offline Find More Posts by icarustheflier1
Old May 03, 2012, 12:20 PM
IndiaHobby is offline
Find More Posts by IndiaHobby
Fly and Drive RC
IndiaHobby's Avatar
United States, MD, Laurel
Joined Mar 2010
APC style propeller 8x4-E (USA Warehouse)
APC style propeller 8x4-E With this Code only 73 cents ...
IndiaHobby is offline Find More Posts by IndiaHobby
Old May 05, 2012, 04:12 AM
floke is offline
Find More Posts by floke
Joined Oct 2010
Find my codes here: http://hk.rc-international.info/swarm/flokai (valid until April 28, 2012)
Hobby King 4.3g / .5kg / .10sec Micro Servo Save US$: 0.59
floke is offline Find More Posts by floke
Old May 05, 2012, 06:56 AM
fly_right's Avatar
USA, NC, Stanley
Joined Sep 2008
Find my codes here: http://hk.rc-international.info/swarm/fly_right (valid until May 17, 2012)
Hobby King GT-2 2.4Ghz Receiver 3Ch Save US$: 0.37
Turnigy Receiver Controlled Switch Save US$: 0.97
Old May 06, 2012, 09:18 AM
Emoto is offline
Find More Posts by Emoto
Emoto's Avatar
Australia, NT, Anmatjere
Joined Oct 2010
At under 9$ !!! great cheap charger/ also field cell checker, i couldnt help myself
http://www.hobbyking.com/buddy.asp?c...2-3C72C130DFD9
Edit ; sadly after testing this against celllog8 , and a accurate calibrated multimetre, it over charges so dont wast your money, put it towards a better charger
Emoto is offline Find More Posts by Emoto
Old May 06, 2012, 01:55 PM
sarapintas is offline
Find More Posts by sarapintas
Joined Jan 2012
Find my codes here: http://hk.rc-international.info/swarm/sarapintas (valid until May 15, 2012)
Grub Screw set Save US$: 0.02
JST-XH to JST LED Power Distribution Lead Save US$: 1.25
Strong Rare-Earth Button Magnets (10pcs/set) Save US$: 0.90
Hobbyking X525 V3 Glass Fiber Main Frame Bottom Plate (1pcs/bag) Save US$: 0.39
GWS HD8040 3 Blade Prop Counter Rotate (2pc) Save US$: 0.99
sarapintas is offline Find More Posts by sarapintas
Old May 07, 2012, 09:48 AM
Virginia Jim is offline
Find More Posts by Virginia Jim
Virginia Jim's Avatar
United States, NC, Durham
Joined Mar 2011
Teach Kids about Planes with Free Flight Models or convert to RC!
Find my codes here: http://hk.rc-international.info/swarm/virginiajim (valid until May 17, 2012)
Electric Rubber Band Winder for Freeflight Series Models
Regular Price: $3.84 Your Cost: $3.59 Save US$: 0.25
Skylark L-9 Rubber Powered Freeflight Model 2 in 1 Monoplane or Bi-plane
Regular Price: $2.45 Your Cost: $2.13 Save US$: 0.32
Beaver Seaplane Rubber Band Powered Freeflight Model 468mm Span
Regular Price: $4.81 Your Cost: $4.51 Save US$: $0.30
18-11 2000kv Micro Brushless Outrunner (10g)
Regular Price: $7.99 Your Cost: $7.61 Save US$: 0.38
Nylon Clevis 1.8x27mm (10pcs/set)
Regular Price: $0.56 Your Cost: $0.48 Save US$: 0.16
Virginia Jim is offline Find More Posts by Virginia Jim
Last edited by Virginia Jim; May 07, 2012 at 10:20 AM. Reason: add reg price, your cost
Old May 07, 2012, 10:29 AM
mssmison is offline
Find More Posts by mssmison
Canada, BC, Campbell River
Joined Feb 2012
Here are some updated codes.
Find my codes here: http://hk.rc-international.info/swarm/mssmison (valid until May 14, 2012)
SF E-Prop 10x4.7 / 254x119.5mm w/ Adapters Black (5pcs/bag) Save US$: 0.43
Turnigy 5mm Heat Shrink Tube - Save US$: 0.29
Wire Mesh Guard Orange 8mm (1mtr) Save US$: 0.21
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Save US$: 0.20
Battery Tape (5pcs/bag) Save US$: 0.78
Male XT60 Save US$: 0.26
hexTronik DT750 Brushless Outrunner 750kv Save US$: 0.72
mssmison is offline Find More Posts by mssmison
Discussion Hobby King "SWARM" Sales mattyhawk HobbyKing 39 Feb 16, 2015 02:53 PM
Cool Official Banana Hobby LIVECHAT Conversation Thread dgbuggy Banana Hobby 82 Mar 01, 2010 06:02 PM
FAQ Honeybee King II official Q&A thread my c210 Micro Helis 9 Jan 14, 2010 04:00 PM
Discussion The Official 2009 Hobby Lobby Thanksgiving Sale Thread! Jason Cole Hobby Express (Formerly Hobby Lobby) 2242 Dec 08, 2009 05:33 PM
Discussion Official Hobby Lobby Thanksgiving Sale Thread Jason Cole Hot Online Deals 2927 Jan 06, 2008 06:19 AM
