This thread is privately moderated by Sid3ways, who may elect to delete unwanted replies.
Old Apr 23, 2012, 01:21 PM
rabdooley is offline
Find More Posts by rabdooley
rabdooley's Avatar
USA, NH, Center Ossipee
Joined Apr 2010
Find my codes here: http://hk.rc-international.info/swarm/rabdooley (valid until May 06, 2012)
Turnigy 130A Watt Meter and Power Analyzer Save US$: 3.98
rabdooley is offline Find More Posts by rabdooley
Old Apr 24, 2012, 03:34 AM
arrior is offline
Find More Posts by arrior
Joined Feb 2010
Find my codes here: http://hk.rc-international.info/swarm/arrior (valid until May 08, 2012)
Turnigy Glow Plug Lighter Tool Save US$: 0.36
arrior is offline Find More Posts by arrior
Old Apr 25, 2012, 03:59 AM
ERIDANY is offline
Find More Posts by ERIDANY
Joined Jul 2011
http://hk.rc-international.info/swarm/ERIDANY
Alloy Motor Heastsink for 36 Size Motor eridany 09-05 2,56 3,36 3
Hobbyking Scale Car LED Light system eridany 09-05 8,66 9,95 10
Hobbyking Scale Car LED Light system Advanced eridany 09-05 8,66 14,99 15
HexTronik VA-Tester (Voltage and Current indicator) eridany 09-05 4,51 5,98 6
JST-XH 2S Wire Extension 20cm (10pcs/bag) eridany 09-05 2,45 2,86 3
450 Size Heli Main Gear Set (2pcs) eridany 09-05 0,70 1,10 1
Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec eridany 09-05 4,51 4,99 5
Solo Pro FP II Main Gear eridany 01-05 0,61 0,70 50
HK450V2 Feathering Shaft Set (41x4mmxM2) eridany 01-05 0,01 2,15 50
HK450V2 Stabilizer Bar eridany 01-05 0,01 0,64 50
HK450V2 Main Shaft eridany 01-05 0,01 2,05 50
HK450V2 Main Gear Assembly eridany 01-05 2,63 3,46 50
GT450PRO Main Rotor Thrust Bearing Set (3x8x3.5mm) eridany 01-05 1,19 1,37 6
4mm Gold Connectors 10 pairs (20pc) eridany 01-05 1,96 2,47 50
Turnigy 25mm Flywheel Removal Tool eridany 01-05 3,67 4,79 50
Solo Pro FP II Swashplate Set eridany 30-04 1,31 1,51 0
Cyanoacrylate (Super Glue) Single Pack eridany 30-04 0,47 0,59 50
HK450V2 Timing Belt eridany 30-04 0,52 0,89 50
HK450V2 Tail Support Rod eridany 30-04 0,01 1,34 50
ERIDANY is offline Find More Posts by ERIDANY
Old Apr 26, 2012, 04:17 AM
zaggy is offline
Find More Posts by zaggy
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/galad (valid until May 10, 2012)
Hot Melt Glue gun Save US$: 2.42
zaggy is offline Find More Posts by zaggy
Old Apr 26, 2012, 05:53 AM
F5D is offline
F5D
Find More Posts by F5D
F5D
F5D's Avatar
Austria
Joined Aug 2003
new code
Nylon Snap-Click style clevis 2x8x23mm (10pc)
http://www.hobbyking.com/buddy.asp?c...9-D7944B3641EE
thanks
Peter
F5D is offline Find More Posts by F5D
Old Apr 26, 2012, 06:15 AM
sarapintas is offline
Find More Posts by sarapintas
Joined Jan 2012
Find my codes here: http://hk.rc-international.info/swarm/sarapintas (valid until May 06, 2012)
FrSky Lipo Voltage Sensor FLVS-01 Save US$: 1.41
FrSky DF 2.4Ghz Combo Pack for JR w/ Module and RX (V2) Save US$: 7.26
FrSky FSH-01 Telemetry Sensor Hub Save US$: 2.07
sarapintas is offline Find More Posts by sarapintas
Old Apr 26, 2012, 09:06 AM
Virginia Jim is offline
Find More Posts by Virginia Jim
Virginia Jim's Avatar
United States, NC, Durham
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/virginia-jim (valid until May 05, 2012)
HXT 3.5mm Gold Connector w/ Protector (10pcs/set)
Regular Price: $2.59 Your cost: $2.35 Save US$: 0.23
Male Molex 1.25 to Female JR Servo Extension (1pc)
Regular Price: $0.46 Your cost: $0.35 Save US$: 0.20
Female Molex 1.25 to Male JR Servo Extension (1pc)
SF E-Prop 10x4.7 / 254x119.5mm w/ Adapters Black (5pcs/bag)
Regular Price: $2.99 Your cost: $2.54 Save US$: 0.43
6inch Quick Release Bar Clamp Tool
Regular Price: $0.99 Your cost: $0.64 Save US$: 0.35
TURNIGY V-Tail Mixer. Ultra-small PRODUCT ID: TR-V-tail
Regular Price: $2.95 Your cost: $1.96
http://www.hobbyking.com/buddy.asp?c...5-2C34672269E6
Virginia Jim is offline Find More Posts by Virginia Jim
Last edited by Virginia Jim; Apr 26, 2012 at 09:17 AM. Reason: add your cost, regular price
Old Apr 26, 2012, 01:42 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Linkage Stopper M3x2xL11.2mm (10pcs/set)
[S]$1.52[/S] $0.97* (discount 36%, -$0.55)
Male XT60
[S]$1.07[/S] $0.81* (discount 24%, -$0.26)
JST-XH 3S Wire Extension 20cm (10pcs/bag)
[S]$3.31[/S] $2.84* (discount 14%, -$0.47)
Turnigy nano-tech 180mAh 2S 25C Lipo Pack (E-flite micro series compatible)
[S]$4.99[/S] $2.56* (discount 49%, -$2.43)
Turnigy High Density R/C LED Flexible Strip-White (1mtr)
[S]$5.26[/S] $3.41* (discount 35%, -$1.85)
Turnigy High Density R/C LED Flexible Strip-Red (1mtr)
[S]$4.03[/S] $3.41* (discount 15%, -$0.62)
T-Connector to XT60 Battery Adapter Lead (2pc)
[S]$2.47[/S] $1.58* (discount 36%, -$0.89)
Male T-Connector
[S]$1.15[/S] $0.87* (discount 24%, -$0.28)
JST-XH 4S Wire Extension 20cm (10pcs/bag)
[S]$3.93[/S] $3.42* (discount 13%, -$0.51)
Turnigy High Density R/C LED Flexible Strip-Blue (1mtr)
[S]$5.10[/S] $3.41* (discount 33%, -$1.69)
Light Foam Wheel (Diam: 30, Width: 11mm) (5pcs/bag)
[S]$1.36[/S] $1.03* (discount 24%, -$0.33)
XT-60 to HXT 4mm Battery Adapter Lead (2pc)
[S]$3.29[/S] $2.11* (discount 36%, -$1.18)
Female Tamiya
[S]$2.63[/S] $1.96* (discount 25%, -$0.67)
Male EC3
[S]$2.77[/S] $2.07* (discount 25%, -$0.7)
XT60 to T-Connector Battery Adapter Lead (2pc)
[S]$2.32[/S] $1.48* (discount 36%, -$0.84)
Lumifly Lighting system FAA Configurable
[S]$10.35[/S] $8.64* (discount 17%, -$1.71)
Light Foam Wheel (Diam: 40, Width: 11mm) (5pcs/bag)
[S]$1.84[/S] $1.40* (discount 24%, -$0.44)
USB Simulator Cable Phoenix RC
[S]$7.98[/S] $5.12* (discount 36%, -$2.86)
5 Spoke Wheels Shock Absorbing D75xH18mm (5pcs/bag)
[S]$4.20[/S] $2.56* (discount 39%, -$1.64)
Light Foam Wheel (Diam: 55, Width: 10mm) (5pcs/bag)
[S]$2.56[/S] $1.95* (discount 24%, -$0.61)
Light Foam Wheel Diam: 60, Width: 10mm (5pcs/bag)
[S]$3.40[/S] $2.07* (discount 39%, -$1.33)
TRX plug battery harness for 2 packs in series
[S]$1.48[/S] $1.24* (discount 16%, -$0.24)
Scale alloy hub rubber wheel 2.0inch
[S]$3.45[/S] $1.95* (discount 43%, -$1.5)
T-Connector - JST Male in-line power adapter
[S]$1.31[/S] $0.84* (discount 36%, -$0.47)
EC5 Battery Harness 12AWG for 2 Packs in Series
[S]$3.99[/S] $2.56* (discount 36%, -$1.43)
T-Connector Harness for 2 Packs in Parallel (1pc)
[S]$1.97[/S] $0.97* (discount 51%, -$1)
Multi-Adapter All-in-One Balance Board (TP/HP/XH/EH)
[S]$2.95[/S] $1.89* (discount 36%, -$1.06)
EC3 Female - Tamiya Male
[S]$1.18[/S] $0.65* (discount 45%, -$0.53)
5 Spoke Wheels Shock Absorbing D70xH18mm (5pcs/bag)
Turnigy Park450 Brushless Outrunner 890kv (USA Warehouse)
[S]$16.30[/S] $14.20* (discount 13%, -$2.1)
Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo (USA Warehouse)
[S]$8.29[/S] $6.52* (discount 21%, -$1.77)
All my buddy-codes here
3drcparts is offline Find More Posts by 3drcparts
Old Apr 27, 2012, 06:14 AM
arrior is offline
Joined Feb 2010
Find my codes here: http://hk.rc-international.info/swarm/arrior (valid until May 11, 2012)
Counter Rotating combo 1147 (1147*1 and R1147*1) (2 x 3pc Each) Save US$: 2.78
1047SF Combo (1047SF and R1047SF) (3 Standard and 3 Counter Rotating Per Bag) Save US$: 2.81
Old Apr 28, 2012, 12:53 AM
mark168 is offline
Find More Posts by mark168
Love *****istrator
mark168's Avatar
Joined Apr 2012
Yes, this is a good idea
mark168 is offline Find More Posts by mark168
Old Apr 30, 2012, 04:48 AM
Timewarp is offline
Find More Posts by Timewarp
Life is simple Eat, Sleep, Fly
Timewarp's Avatar
Germany, RP, Kaiserslautern
Joined Oct 2011
Codes valid until 13 May 2012
Codes valid until 13 May 2012.
Turnigy Servo Signal Reverser
http://www.hobbyking.com/buddy.asp?c...3-2A99F9C1D7DE
Z-bend Pliers. Heavy Duty 90deg up to 1/16
http://www.hobbyking.com/buddy.asp?c...D-BBA78DEEF0E8
HXT UBEC 5/6v output, 5.5~23v Input
http://www.hobbyking.com/buddy.asp?c...0-2207E2E69501
Hobby King T-Shirt Navy Blue (X-Large)
http://www.hobbyking.com/buddy.asp?c...F-EFEF1BEA4F4D
Light Foam Wheel (Diam: 110, Width: 30mm)
http://www.hobbyking.com/buddy.asp?c...E-69DB79F7F197
Self-Tapping Screws 2.5x8 (bag of 100pc)
http://www.hobbyking.com/buddy.asp?c...4-EE51BFD8132A
Self-Tapping Screws 3x12 (bag of 100pc)
http://www.hobbyking.com/buddy.asp?c...6-F74D373B41F3
Grub Screw Set M3x4 10 Pack
http://www.hobbyking.com/buddy.asp?c...A-DB9822675E05
http://www.hobbyking.com/buddy.asp?c...A-286F181343DE
http://www.hobbyking.com/buddy.asp?c...3-CB064B37608C
Futaba Y Servo Lead 30cm Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?c...5-3E02024398DD
JR Y Servo Lead 15CM Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?c...4-2536714FDEA5
4 Blade EP Propeller 10x8.25/254x209.6mm
http://www.hobbyking.com/buddy.asp?c...F-2AAA4DB26495
Turnigy Ultra-light wood propeller 10x6
http://www.hobbyking.com/buddy.asp?c...B-23D7CED2F820
Timewarp is offline Find More Posts by Timewarp
Old Apr 30, 2012, 06:59 AM
Boofhead is offline
Find More Posts by Boofhead
That will simply buff out
Boofhead's Avatar
Australia, NSW, Kareela
Joined Jul 2001
Some 35mm MIG29 spares
Extra Codes, You can save 11.9% for all of this products with:http://rc-buddy.com/user/boofhead! Codes from RC-Buddy.com
HK F4U Corsair 1160x3 Replacement Propeller Set
Savings: 23.75 % / $2.09
Price after: $6.71
Weight: 71 g
MIG-29 twin 35mm EDF Micro Jet - Replacement Cockpit Canopy
Savings: -60.91 % / $-2.54
Price after: $6.71
Weight: 18 g
MIG-29 twin 35mm EDF Micro Jet - Replacement Fuselage
Savings: 12.98 % / $0.85
Price after: $5.70
Weight: 60 g
MIG-29 twin 35mm EDF Micro Jet - Replacement Vertical Tail Set
Savings: 13.02 % / $0.41
Price after: $2.74
Weight: 18 g
TURNIGY Plush 10amp 9gram Speed Controller
Savings: 26.95 % / $2.49
Price after: $6.75
Weight: 20 g
Solder Wire 1mm/3m
Savings: 14.09 % / $0.21
Price after: $1.28
Weight: 32 g
Insta-Set CA Accelerator 2. oz
Savings: 23.85 % / $0.93
Price after: $2.97
Weight: 63 g
Boofhead is offline Find More Posts by Boofhead
Old Apr 30, 2012, 08:44 AM
zaggy is offline
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/zaggy (valid until May 14, 2012)
Wire Mesh Guard Yellow 10mm (1mtr) Save US$: 0.19
Wire Mesh Guard Yellow 3mm (1mtr) Save US$: 0.30
Wire Mesh Guard Orange 10mm (1mtr) Save US$: 0.19
Wire Mesh Guard Blue 3mm (1mtr) Save US$: 0.30
Wire Mesh Guard Orange 3mm (1mtr) Save US$: 0.30
Wire Mesh Guard Yellow 8mm (1mtr) Save US$: 0.21
Wire Mesh Guard Red 10mm (1mtr) Save US$: 0.19
Wire Mesh Guard Blue 10mm (1mtr) Save US$: 0.19
Wire Mesh Guard Blue 8mm (1mtr) Save US$: 0.21
Wire Mesh Guard Black 6mm (1mtr) Save US$: 0.28
Wire Mesh Guard Yellow 6mm (1mtr) Save US$: 0.26
Cable/Wire Holder (10pc) Save US$: 0.16
Turnigy Pure-Silicone Wire 14AWG (1mtr) BLACK Save US$: 0.54
Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK Save US$: 0.61
Turnigy Pure-Silicone Wire 14AWG (1mtr) RED Save US$: 0.54
Turnigy Pure-Silicone Wire 16AWG (1mtr) Red Save US$: 0.61
Turnigy Pure-Silicone Wire 20AWG (1mtr) Black Save US$: 0.31
Turnigy Pure-Silicone Wire 18AWG (1mtr) Black Save US$: 0.59
Turnigy Pure-Silicone Wire 20AWG (1mtr) RED Save US$: 0.31
Turnigy Pure-Silicone Wire 24AWG (1mtr) Red Save US$: 0.37
Turnigy Pure-Silicone Wire 24AWG (1mtr) Black Save US$: 0.37
Turnigy Pure-Silicone Wire 18AWG (1mtr) Red Save US$: 0.79
Spiral wrap tube ID 9mm / OD 10mm (Clear - 2 Metre) Save US$: 0.49
Spiral wrap tube ID 7mm / OD 8mm (Clear - 2 Metre) Save US$: 0.15
Turnigy Pure-Silicone Wire 24AWG (1mtr) Yellow Save US$: 0.38
Discussion Hobby King "SWARM" Sales mattyhawk HobbyKing 39 Feb 16, 2015 03:53 PM
Cool Official Banana Hobby LIVECHAT Conversation Thread dgbuggy Banana Hobby 82 Mar 01, 2010 07:02 PM
FAQ Honeybee King II official Q&A thread my c210 Micro Helis 9 Jan 14, 2010 05:00 PM
Discussion The Official 2009 Hobby Lobby Thanksgiving Sale Thread! Jason Cole Hobby Express (Formerly Hobby Lobby) 2242 Dec 08, 2009 06:33 PM
Discussion Official Hobby Lobby Thanksgiving Sale Thread Jason Cole Hot Online Deals 2927 Jan 06, 2008 07:19 AM
