This thread is privately moderated by Toppers, who may elect to delete unwanted replies.
Old Sep 27, 2010, 10:34 AM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
Mount #2 - Mustang with alu plate and screws mount
This mounting plate was very kindly given to me by a friend on RCG.
The same principle applies whether you use aluminium or plywood or a hard plastic sheet.
The mounting plate holds 4mm / 1/8" screws that are secured to the place and then secure the motor at a variable distance. This mount is rock solid and allows the motor to have increased thrust angles adjusted. It is essential to get the nuts tightened nicely and then add threadlock to all the nuts to lock them.
I am using the motor X-mount to hold the motor to the screws and the supplied Turnigy bolt-on prop adapter.
This mount is holding the insane 35-30 1400 motor which is crazy fast with a 40A ESC, if you're looking for speed (9x6 MAS prop = 465W). Normal crusing at 1/3 throttle, faster than stock motor with Trojan prop at 50% throttle.
For the correct spinner clearance, the cowl needs to be carved out to allow the full motor to come out of the front.
Toppers is offline Find More Posts by Toppers
For Sale Parkzone p51d brusless alu mount alextronique Aircraft - Electric - Power Systems (FS/W) 0 Sep 05, 2010 08:07 AM
Question Motor mount screws kosch Electric Plane Talk 6 Aug 16, 2010 01:46 PM
Discussion How to mount Alu head. sungamc Electric Heli Talk 4 Jan 23, 2010 10:11 PM
Sold 2 blade cx2 with opiton alu bdugard Aircraft - Electric - Helis (FS/W) 2 Apr 21, 2009 06:35 PM
2 or 4 screws to mount Axi 2820/12? 717 Power Systems 7 Oct 18, 2004 04:11 PM
