Old Sep 27, 2010, 08:55 AM
jwalker590 is offline
Find More Posts by jwalker590
Joined Sep 2010
cox 049 for rcpowers extra 300?
hey everyone im new to 1/2a rc and was wondering if i made a balsa wood rcpowers extra 300, will a cox 049 (has the throttle ring) have enough "power" to fly the plane? if so what type of electronics will i be needing? im planning on buying a spektrum dx6i but im not sure if i need a speed controller?
thanks any comment will be much appreciated! and any help full advice will also be appreciated!
jwalker590 is offline Find More Posts by jwalker590
Old Sep 27, 2010, 10:57 AM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
It depend on the size and weight of that Extra 300. You don't need a speed controller for IC power, only a small servo to control the trottle but you need to provide proper voltage to the Rx and servos. Spektrum Rx's needs 4.8V at all time or will suffer brown-out and reboot, so a 5 Ni-cad/Nimh with good mA capacity is in order.
coriolan is offline Find More Posts by coriolan
Old Sep 27, 2010, 07:48 PM
Joined Sep 2010
http://cgi.ebay.com.au/4-8V-2300mAh-...item1e5e35bb71 would this battery be ideal for powering the receiver? if not what battery should i use and can i plug the battery in any slot of the reciever?
Old Sep 27, 2010, 07:59 PM
Joined Sep 2010
oh and what would be the ideal weight of the planw for the 049? and if balsa is to heavy could i use depron foam? i would film cover the foam of course.
Old Sep 28, 2010, 07:52 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
That pack is WAY too big for a 1/2A model.
I get my packs from www.cheapbatterypacks.com
FOr 1/2A 500 mAH is plenty
Pinecone is offline Find More Posts by Pinecone
Old Sep 28, 2010, 03:06 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
If about 200 square inches, 18<20 Oz would be a maximum for good flight with 1/2A power. And even that would be rather zippy, a 4.8V Rx pack might be a problem with Spektrum system(most uses 5 cells/6V pack). A 500mA pack is gross overkill for 1/2A were weight is always a concern, a same capacity 2 Lipo pack and UBEC would weight a lot less and give same servo power as Nicad/Nimh with less risk of "brown-out" even with a 5 servos set-up.
Old Sep 29, 2010, 02:21 AM
Joined Sep 2010
does anyone have begginer plans for a 1/2a? i beggining to doubt my skills at this topic :P
Old Sep 29, 2010, 02:38 AM
surfer_kris is offline
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
I haven't built any of these myself but here are plans for a trainer style plane; LST 1/2a Trainer
surfer_kris is offline Find More Posts by surfer_kris
Old Sep 29, 2010, 03:30 AM
Joined Sep 2010
thanks kris ill probably make this one now but im still very tempted to make the extra :P any suggestions anyone? its my first scratch build btw
Old Sep 29, 2010, 07:31 PM
alcarafa is offline
Find More Posts by alcarafa
Joined Apr 2006
If you have no previous experience in RC Extra is not a first airplane you'll crash in a blink, better start with a trainer like LST, dont run before walking.
alcarafa is offline Find More Posts by alcarafa
Old Sep 29, 2010, 07:59 PM
Joined Sep 2010
ive already been simulating the extra for about 1 month and the only concern i have for it is the weight and the fact that the 049 wont have enough power for it?
Old Sep 30, 2010, 12:41 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
"Simulating" is not the real thing! 1/2A planes tend to fly very fast,specialy when heavy and a sedate trainer would give you a better chance to survive the first flight. Simple trainer are also easier to repair and less prone to damage than a scale job, nothing worst than crash a plane on which you spend lot of detailing time because of a slightly off CG,wrong incidence or wing warp. As alcarafa said its better to learn walking before trying to run
Old Oct 02, 2010, 08:10 PM
Joined Sep 2010
is 750mh too much for the receiver?
Old Oct 03, 2010, 05:24 AM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
It is more about size and weight.
Old Oct 04, 2010, 02:15 AM
alcarafa is offline
Joined Apr 2006
You can use a 2 cell 450 mah lipo for your reciever , it's lighter than any NIcad or Nickel metal batteries.
But your first concern should be size , power plant and weight of plane.
Discussion RCPowers.com Extra 300- Free plans wmcneal Foamies (Scratchbuilt) 693 Nov 29, 2014 03:24 PM
Discussion cox 049 rc on a rcpowers extra 300 balsa wood 3d? jwalker590 3D Foamies 1 Oct 01, 2010 10:56 AM
Help! rcpowers.com extra 300 Gringostr 3D Foamies 17 Apr 08, 2010 08:15 PM
Discussion Rcpowers.com extra 300 Gringostr 3D Foamies 26 Feb 13, 2010 09:50 PM
Help! rcpowers extra 300 Gringostr 3D Foamies 12 Jan 25, 2010 03:17 PM
