| Thread Tools |
| This thread is privately moderated by propjobbill, who may elect to delete unwanted replies. |
One of four new planes I built in September
For the month of September I built 4 more new planes. They were all built from sheet foam some Were Dollartree Rediboard and one was of FFF.
I enjoy building and trying new things. I like to build in less conventional methods. The plane I am showing here is make from Rediboard. It has a 30" span and an 8" cord to the wing. The wing is flat on the bottom and my own version of fold over wing. This plane will fly very nicely in 10mph wind it can fly as slow as about 12mph it flies almost the same upright as it does inverted. The foam board used was a poster before being converted to a plane. So I will consider it as a free plane rather than costing $1.00 I find it amazing that for $1.00 worth of foam a little latex paint and some hobby craft glue you can build such great flying planes. I posted a few tips about things I do along with each picture. The plane has no name it was just what I felt like building from scratch. When I say scratch I mean scratch. The Glider below has a foam wing made from Rediboard foamcore. But the fuselages and everything except the wing is balsa. It has a 70" span with 536" wing area and the total AUW including battery is 23 oz. The glider was also built in September I made a video of the green airplane that keeps coming out blue in flight. It's not the best video it was my first attempt the next one will be better. This was the maiden flight the wind was about 5 = 7 mph very calm for our flying field. Foamboard Electric plane (2 min 36 sec) (2 min 36 sec) Videos of the last plane I built in September http://www.youtube.com/user/propjobb.../2/f94n-xGlxvQ http://www.youtube.com/user/propjobb.../1/JoQGqywVFfg http://www.youtube.com/user/propjobb.../0/t98PWD7XTBY
Many of them are from plans off the scratch build section. I simply make a bulkhead about 2" wide and the height of the fuselage one at each end of the servo compartment. I use a piece of plywood glued to the front for mounting the motor. I've uploaded some more pictures of the green plane. I cut out to sides for the fuselage spaced them where T wanted them glues a plant to the bottom to make up the bottom of the fuselage. After it dried I cut of the excess with a razor knife then sanded.
As you can see it looks ruff but I build them to fly not for looks. Between the battery compartment and servo compartment I used wood blocks to reinforce the landing gear and beef up the sides of the fuselage. The strip across the top is 1/4" plywood. The Popsicle sticks slide under to hold the front of the wing down the back is held by a nylon screw into a blind nut mounted at the back The battery compartment cover is held at the back with Popsicle sticks with a magnet at the front. The plane took about 2 hours to cutout and glue. with all the time waiting for paint to dry and glue everything takes about 6 =8 hours but actual working time is only about 2 hours or less. I build dirt cheap to fly not for looks. If I do crash all I am out is my building time which I enjoyed. The cost of the planes is almost always less than $2.00 Yes you could say I taught myself. But it is things I have learned from building over the past 30 plus years.
| Thread Tools | |
| For Sale four new standard servos, one S148 and three CS-67's | justplainold | Aircraft - General - Radio Equipment (FS/W) | 0 | Sep 01, 2010 07:57 PM |
| Discussion So I built one - PZ new UM T-28 Trojan (with video) | Slider2732 | Indoor and Micro Models | 39 | Aug 06, 2010 09:22 PM |
| For Sale 50 Scale mechanics one new in box- one built body | PaulGT3 | Aircraft - Fuel - Helis (FS/W) | 0 | Jul 25, 2010 10:29 PM |
| For Sale one new Scale .50 mechanics in box and one built | PaulGT3 | Aircraft - Fuel - Helis (FS/W) | 1 | Jul 13, 2010 08:18 PM |
| Sold Sold!!!!One new alula, one built, sell either one! | TommyB | Aircraft - Electric - Airplanes (FS/W) | 5 | Jan 13, 2009 07:49 PM |
