Old Jul 06, 2003, 04:00 AM
Bruce Moore
Bruce Moore
Guest
n/a Posts
FMA DIRECT CO-PILOT
Dear Heli Fans...
I bought the product above, with hopes that it would keep my helicopter
parallel to the ground (as advertised). All it did was wreck a servo
(stripped the gear, and detroyed the motor). Have any of you guys tried
this unit with any success?? I shipped it back to them, and they sent it
back and said nothing was wrong. I KNOW I'm hooking it up right... they
offer no solutions or concessions...???
pls help if you can
Bruce-NJ
Philip Martin
Philip Martin
Guest
n/a Posts
Re: FMA DIRECT CO-PILOT
"Bruce Moore" <bruce.r.moore@verizon.net> wrote in message
news:4PMNa.7807$Ha.7413@nwrdny02.gnilink.net...
> Dear Heli Fans...
The probability is that you did somat wrong! I use two of them, one on a
X-Cell SE and one on a Hawk with no problems at all.
What heli was it on and what servo did you wreck?
Phil Martin.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.493 / Virus Database: 292 - Release Date: 25/06/2003
Old Jul 09, 2003, 04:02 AM
SRS
SRS
Guest
n/a Posts
Bruce,
It is _very_ important that you trim you heli before activating this
device. Otherwise it will go into a pendulum type swaying motion as it
is attempting to steady the crooked beast. Actually it can keep the heli
up for quite a while like this, but I suspect it would be very hard on
the servos.
I have one on a small electric heli that used to be near impossible to
keep from crashing because of its flighty instabilities. It has never
crashed since co-pilot was installed.
Steve w8an
Bruce Moore wrote:
> Dear Heli Fans...
> pls help if you can
> Bruce-NJ
Old Jul 11, 2003, 04:02 AM
elossam
elossam
Guest
n/a Posts
The last time I made the calibration test was 06january03 . This day I
achieved a 10 points reading level. I use a Futaba fc28 and the
co-pilot gain was assigned to the same switch used to go from normal
mode to iddle1. The transmitter has the possibility to set a different
offset for each flight mode so I use it to correct the trim
differences with the co-pilot on and off. The system holds the same
amount of trim difference (letīs say relative trim possition and not a
fixed trim possition) so if I need to retrim the heli due to load
changes (itīs a camera ship) the flight mode 1 will be affected too
but holding the offset difference selected before. If the current
flight day gives less temperature reading the unit will be less
sensitive but thatīs all; Iīwill never overstress the heli like flying
in a 10 points level day with the co-pilot programmed at a 7 point
level.
The unit is very sensitive to the leveling you achieve during the
calibration procedure and I want not to start retrimming it each time.
Hope it helps anyone
Elossam
Old Aug 04, 2003, 04:01 AM
Bill Wolff
Bill Wolff
Guest
n/a Posts
Hi Steve... I have a small electric heli called a Feda Dragonfly which =
is just like the Century Hummingbird. And it uses those micro servos and =
plugs. And I can't see me hooking up the FMA Co-pilot to this thing at =
all. As any extra weight alone (even just the training gear) is enough =
to stop it from lifting up. So what kind of electric heli do you have? =
Just curious.
Bill
"SRS" <sstuart@NOSPAM.glasscity.net> wrote in message =
news:vgnagdtlv0i8fd@corp.supernews.com...
> Bruce,
>=20
> It is _very_ important that you trim you heli before activating this=20
> device. Otherwise it will go into a pendulum type swaying motion as it =
> is attempting to steady the crooked beast. Actually it can keep the =
heli=20
> up for quite a while like this, but I suspect it would be very hard on =
> the servos.
>=20
> I have one on a small electric heli that used to be near impossible to =
> keep from crashing because of its flighty instabilities. It has never=20
>=20
> Steve w8an
>=20
>=20
> Bruce Moore wrote:
> > Dear Heli Fans...
> >=20
> > I bought the product above, with hopes that it would keep my =
helicopter
> > parallel to the ground (as advertised). All it did was wreck a =
servo
> > (stripped the gear, and detroyed the motor). Have any of you guys =
tried
> > this unit with any success?? I shipped it back to them, and they =
sent it
> > back and said nothing was wrong. I KNOW I'm hooking it up right... =
they
> >=20
> > pls help if you can
> >=20
> >=20
> > Bruce-NJ
Version: 6.0.506 / Virus Database: 303 - Release Date: 8/1/2003
Old Aug 05, 2003, 04:01 AM
PC
PC
Guest
n/a Posts
In article <AT7Xa.32$jq.25@fe01.atl2.webusenet.com>,
wolffsoft@nospamnetzero.net says...
> Just curious.
You need a better motor, then it will lift off. Training gear?? Shouldn't
be a problem lifting that like. Is the blade pitch correct?
Question about FMA Direct Co-Pilot jhearn Electric Heli Talk 11 Jun 08, 2004 02:52 PM
a question about fma direct co-pilot adam_jorgensen Power Systems 1 Apr 02, 2002 06:00 PM
FMA direct co-pilot for hornet? Phoenix-IT Electric Heli Talk 4 Mar 28, 2002 08:57 PM
FMA Direct Co-Pilot - anyone use it? Pierce Electric Heli Talk 4 Mar 08, 2002 10:46 AM
