Espritmodel.com Heli Air
Old Sep 25, 2010, 03:07 PM
Crash it first, Then fly it
Griffindor's Avatar
The Big Apple
Joined Jul 2008
Molding plastic canopies
I am planning on making a secret jet that I will post about later on, but I want to make a plastic canopy. How??
I would use those plastic clear trasnperancies that teachers use.
Griffindor is offline Find More Posts by Griffindor
Old Sep 26, 2010, 11:07 AM
Joined Feb 2009
I had the same question some time ago and this was the link someone sent me to.
For some reason i had it in my head that building a vaccuform system would be hard but it was childs play almost.
Unless you are planning on really small canopies I doubt the overhead transparency sheets will work, too thin.
This is the canopy I made for my Super Corsair. Took 2 tries to get it decent. You need to practice quite a bit to get them really good.
Willja67 is offline Find More Posts by Willja67
Old Sep 26, 2010, 01:00 PM
klausi0's Avatar
Germany
Joined Dec 2009
Another method to make canopies is to use PET bottles.
I made a plaster mold, put it into a 2L Cola bottle and tighten it with battens.
Then use a dryer to shrink the bottle.
You can also use balsa for the molds.
klausi0 is offline Find More Posts by klausi0
Old Sep 26, 2010, 01:14 PM
Medicinal Foam User
Wilfor's Avatar
150 mile house B.C. Canada
Joined Jan 2010
Looks like im going to have to start drinking pop
Wilfor is offline Find More Posts by Wilfor
Old Sep 26, 2010, 01:26 PM
Griffindor's Avatar
The Big Apple
Joined Jul 2008
yup. my dad is not drinking it nowadays because of his ''addiction''
Old Sep 28, 2010, 03:16 PM
treefinder
springer's Avatar
SE MI
two for one!
Griff: another idea for the pop bottle shrink canopies: You can make two at a time by making two molds, and stuffing them into the bottle, then shrinking it over them. relative to the general shrink method, You will probably have to go though a couple to get the idea, but it works very well once you get the hang of it!
In the pix, I was doing a P40 and a p51 canopy. The Warhawk one was made from pink foam (2" Owens Corning Foamular board) carved and sanded. The "frames" were just masking tape I was trying to see if I could get them to look like raised framing. That didn't work too well, as they are on the outside of curve and get washed out. The Mustang canopy was carved and sanded from a 2x4. Just goes to show that you can use almost any fairly stiff material for the forms. 'Course I only get one good canopy from the foam forms, as the heat starts shrinking the foam too. The wood ones work the best for me. Making a clay mold and casting a form sounds like a good idea too for a more permanent form.
springer is offline Find More Posts by springer
Latest blog entry: OSE One Sheet Edge 540 Video
Old Sep 29, 2010, 07:50 AM
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
I made a vacuum forming box and I've got a lot of use out of it, making cowlings as well as canopies.
I often use the clear plastic covers that are used for spiral bound reports. I had a bunch of A3 reports at work that I was throwing out, so I ripped the covers off them. The plastic is only about 0.25mm thick, so its only good for small canopies, say 4" max. I searched all the plastic suppliers in my city and eventually found some 0.5mm sheet which I use for bigger planes.
I only use balsa for plugs. Foam ones always melted. You need to get a super smooth finish on the plug because the slightest grain shows in the plastic. High-build automotive primer works well.
Scaledown is offline Find More Posts by Scaledown
Old Sep 29, 2010, 08:12 AM
Joined Sep 2010
just do it! that is good idea![img]/sig/31/smile.gif[/img]
FranklinWalker is offline Find More Posts by FranklinWalker
Old Sep 29, 2010, 12:31 PM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
you can get very large smooth 3 liter bottles at the dollar store
here is my old how-2 thread for making small canopies: http://www.rcgroups.com/forums/showthread.php?t=597824
derk is offline Find More Posts by derk
Which plastic for canopies Sail 'n Soar Scale Electric Planes 13 Nov 04, 2004 09:49 PM
How are you guys making canopies out of plastic bottles?! Silverstreak328 Micro Helis 7 Sep 06, 2004 06:51 PM
PLASTIC CANOPIES - Footnotes Popa Joe Scale Electric Planes 7 Feb 22, 2003 03:41 PM
Plastic thickness for pulling clear canopies Scott C Electric Plane Talk 6 Apr 09, 2002 02:54 PM
Plastic Sheets For Canopies, Where To Buy? RCFlybry Parkflyers 8 Mar 16, 2002 09:22 AM
