Old Sep 25, 2010, 02:13 AM
knlever is offline
Find More Posts by knlever
Design is everything.
Sri Lanka
Joined Mar 2010
Home Made 2.5 g resolution micro scale
The use of a weighing scale is crucial for the building of a lightweight model.
There are some DIY scales at these sites
http://sci-toys.com/scitoys/scitoys/...e/balance.html
http://riceball.com/d/content/diy-postal-scale
I have developed a 'penny scale' that seems to be quite accurate. This is just a Proof of Concept and has to be developed further
What do you think? Is it accurate?
knlever is offline Find More Posts by knlever
Old Sep 25, 2010, 02:30 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
.1g resolution scales are less than $10 shipped on E-bay or from Deal extreme. That seems like a not a lot of acuracy and not a very productive use of time.
UNGN is offline Find More Posts by UNGN
Old Sep 25, 2010, 12:47 PM
Aeroengineer1 is offline
Find More Posts by Aeroengineer1
Mesa Falcon Fld, Arizona, United States
Joined Sep 2004
Might want to take a look at where he is from before making such a post. His access to some of these materials might be limited.
Aeroengineer1 is offline Find More Posts by Aeroengineer1
Old Sep 25, 2010, 12:57 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
A zillion years ago there was a balance in the Scientific American, in the Amateur Scientist column that could weigh the graphite in a pencil dot on a paper that had been weighed before and after.
I made one in my office and it would also measure air currents that were way to small to feel. The more sensitive you make something the more it has to be protected from measuring everything.
Personally I would go with a balance. Measuring in the gram range is easy with balance.
A friend made a very fine caliper that is damn near as good as one that I paid $135 for. His is made of wood and uses rubberbands to pull it closed and the scale is written on paper after measuring a few samples. Mine has a larger range but his is pretty good for something thrown together in a half an hour or so.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Sep 25, 2010, 02:08 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Same with most of Africa right... it is called doumenteries, aka TV. If you have an internet connection and build small models, it wouldn't be hard at all to just get ytt another part from the internet.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Sep 25, 2010, 04:26 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The premise that all pennies weigh the same is a faulty one. I just pulled three random pennies from my pocket. Two weighed 2.5g the other weighed 3.1g.
Old Sep 25, 2010, 05:23 PM
Joined Nov 2007
The original pennies are ~3.1, the recent one weigh ~2.5, the newest ones (shield or building with guy for tails) that just came out weigh ?. It is because the original have more copper.
Old Sep 25, 2010, 07:34 PM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
I've always used nickels as they weigh 5 grams.
Jay
Faethor is offline Find More Posts by Faethor
Old Sep 25, 2010, 11:12 PM
knlever is offline
Sri Lanka
Joined Mar 2010
I have ordered stuff from e-bay before however it always makes business sense to cut costs when you can. For example $ 10 can buy me a new Li-po or a motor, even a plane. The small scales are available here in this country at Hobby Tech for about $ 12.
I really do want to avoid spiraling costs in this hobby, I know I have spent money elsewhere and not wisely.
The other consideration is that low cost scales or models or power sources will make the hobby more accessible for more people, especially young children. Once they get into it they will anyway start spending the big money. Maybe the better thing is not to get them started at all, and price these things out of range.
Anyway the scale was a lot of fun, and is helping me build a lighter wing. I am working on an improved model.
Old Oct 27, 2010, 07:56 PM
knlever is offline
Sri Lanka
Joined Mar 2010
Improved Version gram scale
My 2.5 gram scale is working fine, used it to weigh my wing designs for the free flight plane. Needs to be calibrated often, however.
Its main disadvantage is that it is inconvenient to use, which I plan to fix with the improved model, a proof of concept which was tested in cardboard
The design is pretty simple- a stand and a long arm at the top. The secret is that at the base of the arm a springy material is fixed, this deflects under a load.
Description: Design for a gram scale
Old Nov 02, 2011, 08:09 PM
knlever is offline
Sri Lanka
Joined Mar 2010
http://www.rcgroups.com/forums/showthread.php?t=904951
Nice Harlan scale, I am building a new version of my own rubber powered one.
Old Nov 03, 2011, 08:27 AM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
knlever,
I applaud your efforts. Back in 1988 I published an article in Flying Models magazine for a beam balance that used an American nickel (5 grams) as a weight standard. The balance worked fine, but I used a wooden beam, which changed balance when the relative humidity changed.
I recommend that you avoid using wood, so you won't have a change in balance when humidity changes.
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Nov 03, 2011, 08:45 PM
knlever is offline
Sri Lanka
Joined Mar 2010
Hi Jim
Thanks!. What was the resolution of your scale? And Humidity - newer thought of that.
I would love to see your article or the gist of it.
Old Nov 03, 2011, 09:51 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Originally Posted by JRuggiero View Post
knlever,
Jim R.
Ever thought of putting a coat of dope or paint on the wood beam? Wood is a simple, cheap and durable material. Make the most of it.
356Jim is offline Find More Posts by 356Jim
Old Nov 17, 2011, 06:07 PM
knlever is offline
Sri Lanka
Joined Mar 2010
http://en.wikipedia.org/wiki/Weighing_scale
Some good stuff on scales, errors, etc
Sold Jerry Bates 1:5.5 Scale F8F-2 Bearcat Scale Builder's Bundle (Kit) Hoverup Aircraft - Fuel - Airplanes (FS/W) 0 Aug 29, 2010 01:47 AM
Cool Home-Made Micro LEDs from Printer! dylantorquerol Scratchbuilt Indoor and Micro Models 9 Jul 06, 2010 05:25 AM
Discussion 5$ home made powered glider.60"WS mattox Flying Wings 3 May 14, 2010 12:11 AM
full home made 1/5 scale bike papo Motorcycles 1 Feb 17, 2004 06:58 PM
