Go back to flaperon, activate it and set the ailerons to 100 and flaps to zero and you should have what you need. |
Latest blog entry: Polaris Aileron Pushrods
Joined Sep 2009
Aileron works 100 % on CH 6 OK (without any mix for weeks), until I first time use flaperon mix. Now I can't use aileron in CH6 without flaperon mix. How to recover original setting to use aileron on CH6 without flaperon mix ? |
The only other way to get any action from channel 6 is to use a mix, either flaperon or a programmable mix (or maybe AILDIFF would do it if you entered numbers for both AIL1 and AIL2). The point is that it's not designed to give any output on CH6 unless you take specific action to make it so -- i.e., apply a mix or turn on flaperon or assign it to a switch or knob. |
I am having difficulty with this as well. I can get flaperons to work with pit trim, but if I set them to a switch (gear. etc..) one way I get spoilerons and the other way I get flaps no middle position. I don't suppose you can get just flaps on a switch. I have to use CH6 because with flaperons active I only see CH1 and CH6 moving. I read where someone used futaba instructions to program flaperons, so I checked a futaba manual and it stated that you have to live with spoilers if you want flaps.??? Also if I use airbrake or flap trim it disables one of my ailerons.???
One more question what are ID1 and ID2? |
Finland
Joined Sep 2010
I have used the radio about one year now for helis. There aeroplane mixes are all new to me. I am building a warmliner and I am going to use spoilerons on gear switch. It does the same thing as yours, spoiler or flap, no middle. Is the only option to mechanically set the switch down position to neutral and switch up to spoiler? I tried additional programmable mix from gear to flap with uprate 100 and downrate 0 but it does not seem to do anything. N, ID1 and ID2 are positions of the three way F mode switch. |
Joined Mar 2010
Turnigy 9x Flaperons on 3 pos switch
hi all. this bugged me for a while. i came up with a decent way to do flaperons using the 3 position switch. its all programming, no adjusting of the servo linkages. I made a video here:
United Kingdom, Yeovil
Joined Sep 2009
Great video thanks alot! I`ve only just received My 9x and I`m currently converting all My planes to 2.4 .I`ve spent some time trying to understand how to asign flapperons and elevator mix to a switch with no luck,I thought it was a bug to which there was no flapperon switch and just the turn knob.
Panorama City, CA
Joined Sep 2004
Don't use flaperon for flaps.
No need to complicate the issue.
Flaperon program is mainly to use dual ailerons. If you are seriously considering flaps to slow speed, don't even think of using flaperon. Flaperon is ineffective as flap as flap travel is limited to only 50%, the rest reserved for aileron action. Build separate flaps. The use of independent flaps and control of it is quite simple. For proportional control of flaps, buterfly (crow) program is recommended in glider mode. |
Panorama City, CA
Joined Sep 2004
If you lack previous knowledge of computer programming, it is difficult to use it without understanding of its programs. |
Joined Sep 2010
| Thread Tools | |
| Discussion Please help! I can't figure out which way my plane is going | jaizon | Sailplane Talk | 5 | Jul 15, 2010 04:03 PM |
| Discussion Posting feedback URL can't figure out! help | THREEWING | Trader Talk | 3 | Nov 30, 2009 12:29 AM |
| Discussion It's been awhile - can't figure out my DX7 and AR7000??? Help please. | Valid8r | Radios | 1 | Nov 14, 2009 11:55 AM |
| Help! AXI 2212-20 Cutting out...Can't figure it out... | millerhill | Power Systems | 1 | Jul 30, 2005 09:46 PM |
| Can't figure out plan | JamesD | Beginner Training Area (Aircraft-Electric) | 4 | Mar 19, 2002 03:33 AM |
