Old Sep 24, 2010, 01:47 PM
fltekdiver is offline
Find More Posts by fltekdiver
United States, FL, Melbourne
Joined Jan 2010
Help!
Do you use a on/off switch on battery planes?
Im building my first 51" Slick, and on Nitro planes, I used a on/off battery swtich to turn everything on.
So you still use one on Lipo batterys?
fltekdiver is offline Find More Posts by fltekdiver
Old Sep 24, 2010, 02:03 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
No ,one more source of resistence and another potencial failur point. Some use shorting (make contact) plugs which are better,IMO. I just use a Throttle Lock on my transmitters and stay clear of the prop while a battery is connected.
Charles
Old Sep 24, 2010, 02:05 PM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I never use an on/off switch with electric power. Inserting and removing the power battery is my switch.
Sometimes the ESC comes with an on/off switch, but even then I usually just cut it off and solder the two wires together permenently. The reason is that, even if the throttle signal from the receiver to the ESC is cut (which is what that switch does), the ESC still has power from the main battery so, in theory, might be triggered by interference or some other spurious signal to start the motor.
If I'm using a separate receiver battery (which I don't in any of my current models) I would use a regular on/off switch on it, just so that I can power it down while the model is resting with the motor battery disconnected. But, to avoid the ESC being triggered by stray signals, the switch should only be switched off after the motor battery is disconnected, and it should be switched on before the motor battery is reconnected.
abenn is online now Find More Posts by abenn
Old Sep 24, 2010, 02:23 PM
Joined Jan 2010
10/4, thanks, whats the throttle cut for?
I have a DX-7,. should I use it?
Old Sep 24, 2010, 02:35 PM
Southern Pride
Throttle cut ,Throttle lock different terms used by different Transmitter / users to mean the same thing is a setting that Locks Throttle position to a point where moving Throttle Stick has Zero effect. Mine is set for -5% and while ESC will arm motor will not start until Throttle Lock is switched off.
Charles
Old Sep 24, 2010, 02:40 PM
Joined Jan 2010
Thanks so the plane will not start at full throttle then huh?
Old Sep 24, 2010, 02:50 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I use switches on my RX pack on my bigger planes if I can't access the pack easily.
All of my new built planes will have a shorting plug as Charles mentiones above.
To anyone that uses a switch, be sure to mount the switch so the "on" is towards the tail. I have a FB that lost a plane when his canopy blew off and turned the switch off on its way off the fuse and towards the tail. *eek*
Rick
rampman is offline Find More Posts by rampman
Old Sep 24, 2010, 02:52 PM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
fltekdiver - it helps in case you accidently bump the throttle stick when you bend over to do something to the plane....
I have another FB with a 6" long scar on his left leg from a prop. About 30 staples later... *eek* again.
Rick
Old Sep 24, 2010, 02:55 PM
Joined Jan 2010
Rick
Hmm, thanks for all your help!
So how and where is the throttle cut, it's a swtich on the DX-7?
Old Sep 24, 2010, 03:00 PM
mexico is offline
Find More Posts by mexico
mexico's Avatar
NJ
Joined Aug 2003
Rick
I just installed a switch harness this week and put on - forward. I had not thought of that.
I programmed a throttle cut last year. First time I accidentally hit it during a blender was the day I removed it from my radio.
mexico is offline Find More Posts by mexico
Old Sep 24, 2010, 03:04 PM
RobC(UK) is offline
Find More Posts by RobC(UK)
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
I don't know about Spektrum but on Futaba pushing the Throttle Cut button simply moves the servo to the end of its travel to completely close the throttle on the carburettor and will return to the idle position once released.
RobC(UK) is offline Find More Posts by RobC(UK)
Old Sep 24, 2010, 03:10 PM
mexico is offline
mexico's Avatar
NJ
Joined Aug 2003
The function is throttle cut but on an electric plane it is a mix programmed in so that a switch will turn the motor off and make the throttle stick dead. Mine was programmed on a Fut 7C.
Old Sep 24, 2010, 07:31 PM
Bongo Fury is offline
Find More Posts by Bongo Fury
Rochester Hills, Michigan
Joined Jun 2010
.... To anyone that uses a switch, be sure to mount the switch so the "on" is towards the tail. I have a FB that lost a plane when his canopy blew off and turned the switch off on its way off the fuse and towards the tail. *eek*
Rick
Good point +2. For anyone interested, suggest the opposite for a ground RC. Most hard impacts are head on, sometimes this will move the switch forward from inertia.
Dave
Bongo Fury is offline Find More Posts by Bongo Fury
Old Sep 24, 2010, 09:20 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
I use switch between pack and UBEC along with a arming plug to the ESC -- see diagram:
This scheme also allows me to charge w/o removing packs -- mostly A123s.
Also on is aft -- won't go off if bumped on a hand launch!
A shunt can be used for arming to make an installed measure of amp; loop of wire and clamp-on meter too.
Also, volts under load can be measured via charging port.
jrb is offline Find More Posts by jrb
Old Sep 24, 2010, 09:29 PM
Southern Pride
Well that depends. Around 18 years ago the father of one of my students pushed the switch off on his son's trainer during a hand launch and that swith was aft to arm. It was otherwise a perfect launch however and the plane climbed out circled into the clouds and was never seen again by us. I just set the Transmitter down and watched it fly away.
Charles
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 07:10 PM
Poll what prop do you use on the micro site? bolibruch1 Scratchbuilt Indoor and Micro Models 0 Aug 09, 2010 11:50 AM
Discussion How do you tell if you should use a Lipo battery that has been in a crash??? greenmonsta79 Batteries and Chargers 4 May 31, 2010 07:56 AM
Discussion Do you use a an on/off switch in your sailplane? ClayH Sailplane Talk 90 Mar 02, 2010 03:27 AM
Discussion DX7,How do you program throttle off switch? marcwv Radios 4 Feb 11, 2010 10:22 PM
