Old Sep 23, 2010, 03:10 PM
tanner331 is offline
Find More Posts by tanner331
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Build Log
Herr Cloud ranger build
I have just started construction on my Herr Cloud Ranger. Here are the first pictures.I did this work in about an hour.
tanner331 is offline Find More Posts by tanner331
Old Sep 23, 2010, 05:54 PM
teeceeveecee is online now
Find More Posts by teeceeveecee
Old Submariner
United States, WI, Milton
Joined Dec 2007
Cloud Ranger
Hi Tanner:
They are great little kits and just "fall" together, yours looks good.
In the pic I sent of mine, I didn't mention it but I modified mine for a bolt on wing. I just like it better. The only problem I had at that time was finding 8/32 nylon bolts. They are now readily available from ACE or True Value or MicroMax.
Tom
teeceeveecee is online now Find More Posts by teeceeveecee
Old Sep 23, 2010, 11:52 PM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
What power system did you use?I am going to use a nitro but I am not sure what engine.
Old Sep 24, 2010, 06:19 AM
Old Submariner
Joined Dec 2007
Power Plant
Hi Tanner:
I had EP first, I believe a Multiplex inrunner w/planetary gear drive, 3.87/1.00. It flew fine with that combination, but I have many years experience with glow and gassers and just really prefer IC engines. I converted to a Norvel .074 which was great. Of course it is no longer available (to my knowlege) but any engine in that size range, .061 to a .07 should be fine. I have a Thunder Tiger .07 I am going to use in my new Herr J3 (48" version) which will make very nice combination, not as powerful as the Norvel but plenty for the the
J3.
Attached is a pic of the TT .07 for reference.
Tom
Old Sep 24, 2010, 12:28 PM
init4fun is offline
Find More Posts by init4fun
Joined Mar 2008
That TT07 is a great little engine , ive got one on my house of balsa "Stealthsport" that runs really great
init4fun is offline Find More Posts by init4fun
Reply With Quote  (Disabled)
Old Sep 24, 2010, 12:38 PM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Ok.I found a .09 engine from Enya would that work?
I am going to use floats on it once I learn how it flies.
Tanner
Old Sep 24, 2010, 01:28 PM
Old Submariner
Joined Dec 2007
Enya .09
Tanner
Hi Tanner:
Well the .09 is getting a little big for the CR, however the fact that you want to float fly it would probably be ok with throttle management. I think the larger issue would be the weight of the Enya. I have a feeling it might make the CR a lead sled.
There are really two classes (in my opinion) of RC flyers, those that fly on the wing and those that fly on the prop. I fly on the wing, I like more scale speed. Not to say there is anything wrong with prop flyers, we just prefer different regimes.
Tom
Old Sep 24, 2010, 04:37 PM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Ok.Do you know of any other engines.My favorite is a norvel 0.061.do you know where to find one?
Old Sep 24, 2010, 05:00 PM
Old Submariner
Joined Dec 2007
Source Norvel
Hi Tanner:
There is a guy advertising here in fuel engines and at RC Universe that he has new Norvel engines. Don't know anything about him but maybe worth a look.
"http:/www.rcuniverse.com/market/item/cfm?itemId=668823"
If no luck you can't go wrong with Thunder Tiger at Tower Hobbies.
Tom
Old Sep 24, 2010, 05:44 PM
ww1nut is offline
Find More Posts by ww1nut
ww1nut's Avatar
NY
Joined Oct 2006
+1 on the TT .07 engine. I have one in my Sig Nitro Rascal and it fits perfectly. Just a gental toss when the grass at the field is to high and it flys strait out. Plenty of power.
ww1nut is offline Find More Posts by ww1nut
Old Sep 24, 2010, 08:05 PM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Norvel engine
I emailed him on details and he sounds like a good sorce.
Old Sep 25, 2010, 02:21 PM
Old Submariner
Joined Dec 2007
Engine Mounting
Hi Tanner:
Hope the Norvel guy has what you want. Another consideration I didn't mention earlier, is the engine mounting.
If you should go with a Thunder Tiger there is no engine mount required, it has a radial mount vs the beam mount of the Norvel.
More food for thought.
By the way I started my "Herr J3 Build" thread, some of it might prove useful.
Tom
Old Sep 26, 2010, 11:36 AM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
I looked at the TT.07 and it weighs about the same as a OS.10 would that work.My dad says it should work.but I am not sure.
Old Sep 26, 2010, 11:54 AM
Old Submariner
Joined Dec 2007
OS .10 vs TT .07
Hi Tanner:
Yes the OS .10 compares favorably with the TT .07 in all dimensional areas of concern. So it really just comes down to which one you prefer.
Tom
Old Sep 26, 2010, 02:31 PM
surfer_kris is offline
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
I have no idea what that is supposed to mean, is weight not included in that?
To me these two engines are completely different and the OS .10 is a heavy weight to carry. Here is a little comparison;
OS 10 FSR, prop 7x4-7x5; weight incl. muffler about 160g (5.6 oz) power; 7x4 at about 14500rpm, static thrust; about 700g (≈25oz)
TT 07GP, prop 6x3-6x4, weight incl. muffler; 102g (about 3.6 oz), power 6x3 at about 16500rpm, static trust; about 450g (≈15.8oz)
I don't have the Cloud ranger myself but an OS.10 should pull that thing vertically out of sight, I suggest to keep the weight down and go with a Norvel .061 or the TT 07GP. The Norvel has both a weight and a power advantage over the TT.
surfer_kris is offline Find More Posts by surfer_kris
Discussion Seacrh building plan from Herr cloud ranger kit plane frans32 Scale Kit/Scratch Built 4 Sep 24, 2010 01:18 AM
Sold Herr Cloud Ranger Kit & Floats Kit tblount70 Aircraft - Electric - Airplanes (FS/W) 4 Jul 12, 2010 02:16 PM
Discussion Herr Cloud Ranger Jason_WI 1/2A Planes 3 Sep 26, 2009 11:34 PM
