Old Sep 22, 2010, 02:16 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
Question
will new stuff stick to painted EPP?
I think I saw a mentioning that it would if one uses a very light coat of paint.
Question. If the paint it put on too thickly... is this what ruins the epp/laminate film bond?
thanks,
Gary
grfcon is offline Find More Posts by grfcon
Old Sep 22, 2010, 04:21 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
In my limited experience of using NS, it can stick OK. I painted portions of this EPP Fox (the smaller one!) with quite a thick few coats of acrylic paint, and so far so good.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Sep 22, 2010, 05:07 PM
garyg4rc is offline
Find More Posts by garyg4rc
garyg4rc's Avatar
Riverside CA
Joined Feb 2001
Gary,
You can paint under NS but eventually it will come up. More so, in the areas of impact like the tips, leading edge and nose. If weights not a huge issue, you can lock in the paint with thinned goop then NS over that. If you are using layers of NS you can paint between layers. Good Luck!
Gary
garyg4rc is offline Find More Posts by garyg4rc
Old Sep 23, 2010, 10:33 AM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
thanks Gents I'll give it a shot!!
Old Sep 23, 2010, 10:57 AM
dawsonh is offline
Find More Posts by dawsonh
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
Chris Klique (ritewingsrc.com) recently built a bunch of wings using NS over painted EPP. Here is his build description...
build wing with all gear installed
sand wing nicely
spray 3 m 90 over entire wing ,then let dry
now paint without going to heavy and crazy, I use cheap spray paint.
let paint dry,then do another haze of 3 m 90 over the paint so the lam fill stick reall well.
let 90 dry for 1/2 hour or more.
if you let the 90 dry for a few hrs then you can sand it again as an option to make it even more smooth,but I usually dont,lol
Cut film for top in four pieces then use iron w out a sock, start with temp low at 225 F or so and work your way up.
Use wingbeds to lay wings in to keep them strait and tru ,then over lap the lam film joints 1/4 inch.
After you do a few wings you will be able to do the wing in less pieces.
Its easier to do more at first so you dont distort the wing learning..
The overlaps will disappear and the colors will really bling out even with the haze of 90 over the paint.
You can cover the bare balsa elevons or do the same 90 method with paint ,just no need to do the first layer of 90 on the balsa , just do the last one over the paint so the lam sticks well.
dawsonh is offline Find More Posts by dawsonh
Old Sep 23, 2010, 11:24 AM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
thx Dawson...
I will get a can of the 90 and give it a try. thanks for your help.
Old Sep 23, 2010, 12:57 PM
rockbus is offline
Find More Posts by rockbus
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Originally Posted by garyg4rc View Post
Gary,
Gary
Gary do you have a picture example of this?
Thansk
Ray
Going to redo my POS moth soon. The wings are gonna get trimmed and the fuse shaved....
rockbus is offline Find More Posts by rockbus
Old Sep 23, 2010, 05:03 PM
kpeevyhouse is offline
Find More Posts by kpeevyhouse
Sane til the lift starts!
kpeevyhouse's Avatar
Laguna Beach, CA
Joined Jun 2008
Are you sure it's 3M90, and not 3M77? It's been forever since I've used 90, but I seem to recall that it comes out really stringy and lumpy, not as a mist.
kpeevyhouse is offline Find More Posts by kpeevyhouse
Old Sep 23, 2010, 06:01 PM
glasairIII is offline
Find More Posts by glasairIII
Lover of fast slope gliders!
glasairIII's Avatar
United States, AZ, Goodyear
Joined Apr 2004
3m90
I've seen the results. Impressive.
glasairIII is offline Find More Posts by glasairIII
Old Sep 23, 2010, 06:04 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Covering the bare foam with 3m90 makes sense to fill the gaps, but a "haze of 3m90" does
not, since as mentioned above, it comes out all stringy and you basically have
to smear it down smooth. I wonder if he's actually using 90 first then 77.
ian
Daemon is online now Find More Posts by Daemon
Old Sep 23, 2010, 06:17 PM
glasairIII's Avatar
Joined Apr 2004
All 3m90. When you apply the heat to the film the 3m90 goes clear. Let's the paint shine through the covering.
ian
Old Sep 23, 2010, 06:20 PM
dawsonh is offline
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
Chris mostly uses 3M-90. The 77 tends to de-lam in the heat (Phoenix).
Use an old credit card or piece of coroplast to squeegee the 3M-90 smooth. It is pretty easy to get a nice thin layer. However you have to be fast since it starts to set up quickly... and become a sticky goopy mess.
Mini-HowTo Bagging Laminating Film/New Stuff over EPP - Your next plane! AndreasMergner Slope 52 Dec 11, 2009 08:54 PM
Sold EPP SloFly -cut, painted, ready. GFBurke Aircraft - Electric - Airplanes (FS/W) 2 Dec 09, 2009 09:28 PM
Discussion Will "new stuff" stick to ultracoat grfcon Slope 2 Jan 05, 2009 05:50 AM
Help! will trade machined stuff for gooped EPP winchdoc Slope 1 Jun 08, 2004 12:44 PM
Will iron on covering stick well to painted balsa? EABiker Parkflyers 2 Dec 29, 2003 11:48 AM
