Old Sep 21, 2010, 06:50 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Whats your favorite small Wing set up?
I have tons of lower KV motors for all my 3d models that use large props which I have been using on my home made wings and jets. I am limited to what jets I can build because I have to swing a large prop to compensate for the low KV.
I am going to be making a purchase from HobbyKing and was wondering if anyone has any suggestions for a motor. It will be used on home made EPP and Blucore jets and wings.
What are your favorite set ups for this kind of application.
I want speed and power!!! lol
Thanks in advance for the advice.
airbagit13 is offline Find More Posts by airbagit13
Old Sep 21, 2010, 07:43 PM
matyou is offline
Find More Posts by matyou
matyou's Avatar
Bay Area California
Joined Dec 2009
get the hxt 2300kv motor on 3S
matyou is offline Find More Posts by matyou
Old Sep 21, 2010, 10:25 PM
airbagit13's Avatar
Miami, FL
Joined May 2009
What size prop do you swing on that so I can pick some up as well.
Old Sep 21, 2010, 11:02 PM
matyou is offline
matyou's Avatar
Bay Area California
Joined Dec 2009
Get a 5x4.3 prop with a 10amp SS esc. I would also get a 610mah 3 cell and something in the same capacity range 2 cell. I used that setup on a 24in wing and it went straight up on 3cell. Dont go WOT with the 3cell for to long cause the motor does heat up. Also on 2 cell the 5x4.3 prop does really well so you dont have to change props.
Old Sep 22, 2010, 09:22 AM
airbagit13's Avatar
Miami, FL
Joined May 2009
That motor is out of stock, any other suggestions?
Old Sep 22, 2010, 10:22 AM
matyou is offline
matyou's Avatar
Bay Area California
Joined Dec 2009
here is the link, unfortunately its not in stock.
http://hobbyking.com/hobbyking/store...idProduct=8478
Old Sep 22, 2010, 12:07 PM
martian2121 is offline
Find More Posts by martian2121
Joined Mar 2009
Another nice one
Check this out http://hobbyking.com/hobbyking/store...idProduct=5453
Edwin
martian2121 is offline Find More Posts by martian2121
Old Sep 22, 2010, 01:37 PM
matyou is offline
matyou's Avatar
Bay Area California
Joined Dec 2009
I also have the 3000KV motor but still prefer the 2300kv because the 3000KV requires a bigger battery and lots of amps. This means that the wingloading of my 24inch wing went so high that it was hard to control. Besides, the glide rate went down as well.
Old Sep 22, 2010, 02:50 PM
airbagit13's Avatar
Miami, FL
Joined May 2009
I went ahead and ordered that 3000 kv one to try out.I ordered the small 2300 kv turnigy motor as well just to mess with.
I will pair that Turnigy with the HK 10a esc and the Hextronic Motor with a 30a ESC.
I will be using either 800 mah 3s or 800 mah 2s with it so I picked up 5x4.3 props and 4x4 or something like that.
Old Sep 22, 2010, 04:23 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
I have a couple of these. The 2100Kv will do 6x3 on 3s or 7x3.5 on 2s. Noisy, but tough.
http://hobbyking.com/hobbyking/store...cro_Motor_(19g)
tymbrewolf is offline Find More Posts by tymbrewolf
Old Sep 23, 2010, 01:29 AM
gjalbert is offline
Find More Posts by gjalbert
gjalbert's Avatar
Tualatin, OR
Joined Oct 2009
This is essentially the same motor and is in stock.
http://www.hobbyking.com/hobbyking/s...idproduct=8140
Gary
gjalbert is offline Find More Posts by gjalbert
Old Sep 23, 2010, 01:20 PM
airbagit13's Avatar
Miami, FL
Joined May 2009
Yeah I ordered that one, I like Turnigy to.
I have quite a few Turnigy motors and none of them give me any problems. I actually think my Axi 2212/26 equivalent is even better then my Axi 2212/26.
Old Sep 23, 2010, 02:37 PM
Ace12GA is offline
Find More Posts by Ace12GA
Ace12GA's Avatar
Canada, ON, Peterborough
Joined Oct 2009
This is my fave on both 2s and 3s: http://www.hobbyking.com/hobbyking/s...idProduct=5208
Ace12GA is offline Find More Posts by Ace12GA
Discussion Whats your favorite windy weather plane? Captain Bravo Foamies (Scratchbuilt) 34 Apr 12, 2010 04:54 PM
Discussion Whats your favorite plane? joshuablume Electric Plane Talk 28 Mar 04, 2010 04:22 PM
Discussion Opinions needed, whats your favorite plane for learning LT stick rudder? Jimmy JFlyer Foamies (Scratchbuilt) 22 Jan 21, 2010 08:07 AM
Discussion Whats your favorite brushless motor? adbradley Power Systems 36 Nov 14, 2009 08:50 AM
Discussion what's your favorite 3D foamie and set-up? rednote Foamies (Kits) 1 Oct 30, 2007 11:37 AM
