Old Sep 19, 2010, 12:01 AM
wbrannies is offline
Find More Posts by wbrannies
"The Need 2 Flip"
wbrannies's Avatar
Westminster, Ca
Joined Jul 2009
Cool
Show off your Heli's and Heli pads!
I would like to see some trick stuff!!
wbrannies is offline Find More Posts by wbrannies
Old Sep 19, 2010, 12:43 AM
rctaz is offline
Find More Posts by rctaz
MSR, Trex 250, 450, 550
rctaz's Avatar
Massachusetts
Joined Jan 2010
41" long Trex 550 in the background for a size reference
rctaz is offline Find More Posts by rctaz
Old Sep 19, 2010, 10:19 AM
lovespicyfood is offline
Find More Posts by lovespicyfood
USA, CA, Westlake Village
Joined Sep 2004
That's the same type of heli pad I've been thinking about building for years now! Where I fly the parking lot is always dusty and grimy and I used a big piece of cardboard secured with weights. It works, but it ain't pretty.
Can you detail it's construction? I'm curious to the metal frame...
Regards,
Pete
lovespicyfood is offline Find More Posts by lovespicyfood
Old Sep 19, 2010, 02:41 PM
rctaz is offline
rctaz's Avatar
Massachusetts
Joined Jan 2010
Regards,
Pete
If you are asking me, no metal frame. It is Duct Tape to clean up the edges a bit. The base is made of 2 pieces of 2' x 4' birch plywood connected with a a 4' piano hinge. I stapled a 5 dollare piece of outdoor carpet to the boards and trimmed to size and cut at the joint. I used handles from Home depot. Finally used window locks from home depot to hold it folded when not in use.
This winter I am going to change it a bit and put a 2 x 4 frame under it to get it off the ground. and make it more rigid.
Old Sep 19, 2010, 03:19 PM
sv1000s is offline
Find More Posts by sv1000s
Throttle-Hold Expert
sv1000s's Avatar
Spokane
Joined Jan 2009
K-Nex
sv1000s is offline Find More Posts by sv1000s
Old Sep 19, 2010, 09:47 PM
"The Need 2 Flip"
wbrannies's Avatar
Westminster, Ca
Joined Jul 2009
I like urs, im gonna make a flat one also...
"The Need 2 Flip"
wbrannies's Avatar
Westminster, Ca
Joined Jul 2009
haha thats cool for the mcx
Old Sep 20, 2010, 12:32 AM
Joined Sep 2004
Thank you for the thorough explanation, much appreciated! That was along the same lines of what I've been thinking...the 2X4 makes sense too... I've been thinking about doing this for SO LONG, seeing you do it so nicely inspires me! Thanks again.
Pete
Old Sep 23, 2010, 02:00 PM
vicovaludemero is offline
Find More Posts by vicovaludemero
vicovaludemero's Avatar
USA, NY, Cedarhurst
Joined Mar 2010
Here's my pad... Made from thick foam-core and secured with plastic stakes. Its super light and very portable but not heavy enough to use in tall grass. I built it with the intention of using it on grass and clay (baseball diamonds) and with the ability to throw it under my arm and walk to the field with my heli and TX in a case.
vicovaludemero is offline Find More Posts by vicovaludemero
Old Sep 23, 2010, 08:25 PM
choppersrule is offline
Find More Posts by choppersrule
Got Helis
choppersrule's Avatar
United States, IN, Greenwood
Joined Mar 2010
Okay guys,
Now for the inexpensive stuff.
Some pressed board and black tape. Notice the custom carrying slot.
You can make it any size ya want, depending on heli size (450,500, 600)
Oh, on a side note, it easily hangs up in your garage too.
Dave
choppersrule is offline Find More Posts by choppersrule
Old Sep 23, 2010, 11:31 PM
phoenixheli is offline
Find More Posts by phoenixheli
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
Originally Posted by sv1000s View Post
K-Nex
Anyone remember konstructs?
phoenixheli is offline Find More Posts by phoenixheli
Old Sep 26, 2010, 08:34 PM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
I'm in the process of building a heli-pad with 1/4" ply. It'll be made of 4 pieces, 1'x1' that are hinged like that white foam one above. Planning to paint a yellow H with a dashed circle around it on black background. Should be just big enough for my 450.
Oh yeah I had a bunch of Construx and a couple Erector sets.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Sep 26, 2010, 08:38 PM
Got Helis
Joined Mar 2010
Don't forget Lincoln Logs..
Old Sep 26, 2010, 08:40 PM
sk8teradam2003 is offline
Find More Posts by sk8teradam2003
USA, WI, Wauwatosa
Joined Nov 2007
oh my god...lincoln logs. Haven't seen or heard of those for years.
sk8teradam2003 is offline Find More Posts by sk8teradam2003
Gallery Show off your LRF's (living room fliers) bungholio Scratchbuilt Indoor and Micro Models 7 Jan 07, 2010 07:31 PM
Discussion Small Cheap Heli's! Show yours off! Rocketright Micro Helis 3 Nov 25, 2009 08:51 AM
Discussion show off your painted HBK2 heli's here windisevil!! Micro Helis 21 Feb 08, 2008 08:10 AM
Show Off Your Hornet Heli Son House Micro Helis 34 Apr 19, 2005 09:26 PM
Show off your SIC heli pics buzzsaw 46 Electric Heli Talk 25 Jan 25, 2004 12:31 PM
