Old Sep 18, 2010, 12:25 PM
kbstingwing is offline
Find More Posts by kbstingwing
FLY OR DIE YOU MAGGOT
kbstingwing's Avatar
Vista, Ca
Joined Oct 2002
Can New Stuff be colored on a ink jet printer
Who's willing to try running new stuff through a ink jet printer to test if it will work, I would do it but I don't have any NS, from all the input on other threads it would be best to print on the backside or the glue side, mirror or reverse, I'm going to be ordering some NS next week and will try it out, it should be like printing on transparentcy sheets I would believe,
how about some tests guy's and see what works.
Kevin
kbstingwing is offline Find More Posts by kbstingwing
Old Sep 18, 2010, 01:25 PM
chip.greely is online now
Find More Posts by chip.greely
chip.greely's Avatar
Carlsbad, Ca
Joined Mar 2007
I can give that a try Kevin,
I can run a 8x14 sheet of 5mil through my printer, although 3mil might be a better choice. Just want to check the surface temperature of a printer sheet of paper first, to verify that the NS won't be bonded to the roller
chip.greely is online now Find More Posts by chip.greely
Old Sep 18, 2010, 08:14 PM
theBOZman is offline
Find More Posts by theBOZman
__Jackass Savant__
theBOZman's Avatar
United States, CA, Oxnard
Joined Feb 2005
On a designjet style printer maybe....
theBOZman is offline Find More Posts by theBOZman
Old Sep 19, 2010, 01:02 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
So....won't you be printing on the glue side and messing that up?
flydiver is offline Find More Posts by flydiver
Old Sep 19, 2010, 03:56 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
inkjet ink is water based and unless you seal it with something it smears or melts as soon as you touch it or get it moist.
TFLG is offline Find More Posts by TFLG
Old Sep 19, 2010, 10:08 PM
Alex May is offline
Find More Posts by Alex May
I'd Rather Fly
Alex May's Avatar
United States, CA, San Diego
Joined Feb 2008
That shouldn't be an issue if it is printed on the adhesive side. The only worry is the adhesive getting messed up. If you do put it on the outside, you could always put a coat of clear over it to seal it up.
Alex May is offline Find More Posts by Alex May
Old Sep 19, 2010, 11:40 PM
pchewn is online now
Find More Posts by pchewn
Pat Chewning
USA, OR, Beaverton
Joined Sep 2009
Do not do this on a laser printer
I used to work at HP designing inkjet printers (copiers actually).
They can print on mylar, no problem. Sometimes there is a setting in the printer driver to select the paper type for mylar. It prints a bit less ink and increases the dry time. (Otherwise it delivers you a piece of media with ink puddling on it and not dry).
DO NOT PUT NS THRU A LASERPRINTER! A laser printer has a "fuser" roller that basically melts the toner onto the media. I imagine that the fuser roller (or the roller against it) will get all gummed up and jammed if you put NS thru it.
Ink jet printer rollers are not heated and should not have this problem.
I don't work there anymore, otherwise I could run some "engineering experiments" on all kinds of printers with NS...
Condor-Office_Space-240.wmv (2 min 7 sec)
pchewn is online now Find More Posts by pchewn
Old Sep 20, 2010, 06:31 AM
discostu956 is offline
Find More Posts by discostu956
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
How do you reakon that ink on the mylar would go sticking to the epoxy if bagging a wing (similar to painting the mylars before bagging)?
discostu956 is offline Find More Posts by discostu956
Old Sep 21, 2010, 09:09 PM
Vista, Ca
Joined Oct 2002
OK guy's, think of it as a T-shirt transfer without the backing paper, the adhesive on T-shirt transfers allow the ink to print on it but using a lower amount of ink letting the adhesive to penetrate the ink and creating a bond to the material when ironed, basically it would be the same process on the NS material, maybe using the T-shirt transfer setting would be the best bet on the printing preferrence menu,
It's worth a try.
Kevin
Old Sep 21, 2010, 11:45 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
It didn't work for me. I tried on a Cannon 600 and the ink tends to bead up on the adhesive leving blurred edges.:-(
A10FLYR is offline Find More Posts by A10FLYR
Old Sep 22, 2010, 01:24 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The problem is both sides of NS are plastic, and the adhesive side just melts
at a lower temperature. The adhesive side is pure hot melt glue, and bonds mechanically
not chemically, so almost nothing wants to stick to it cold. Inks generally rely on solvents
or dyes to get into whatever material you're using them on, and neither will put
a dent in NS adhesive. I've soaked NS adhesive in every solvent I've got, and
nothing will dissolve it.
ian
Daemon is online now Find More Posts by Daemon
Discussion What happened to printer ink??? Ifishtoo The Builders Workshop 3 Aug 22, 2010 05:52 AM
Discussion Can multiple lipo chargers be used at the same time on a 12v battery? 22niner8juliet Batteries and Chargers 10 Aug 07, 2010 11:20 PM
Discussion Decal paper for ink jet printer? Marty C... Australia 14 May 06, 2006 05:58 AM
FS: Power plant setup for AF1 Jet (BUT can be fitted on other Jet projects) Lv2Fly Aircraft - Electric - Airplanes (FS/W) 0 Jan 30, 2005 11:44 AM
Idea Decals with Ink Jet Printer Mesnik Foamies (Kits) 0 Mar 21, 2004 02:10 PM
