Old Sep 18, 2010, 11:17 AM
Joined Aug 2009
DIY Continuous Rotating FPV Ground Station
The Ground station is not finished, i am still waiting for my 500mHz RX and EagleEyes....and i need to do some minor mods.
This Ground station rotates with out getting the wires in a mess. All the wires needed (A/v, 12v....) rotates around copper contacts inside the shaft.
I have set the trim on my remote ( still waiting for the EagleEyes) so that the patch will rotate in a direction for about
a hour ( in one direction, and then the other direction).... no problems....so far
FPV CONTINUOUS ROTATING GROUND STATION Phase 1 (1 min 24 sec)
Moosthegoose is offline Find More Posts by Moosthegoose
Old Sep 18, 2010, 12:48 PM
Netherlands
Joined Sep 2007
nice.
marco899 is offline Find More Posts by marco899
Old Sep 18, 2010, 01:24 PM
ashdec87's Avatar
Chicago suburbanite
Joined Feb 2004
now the million $ question. Howd you make it
ashdec87 is offline Find More Posts by ashdec87
Latest blog entry: SS FPV Maiden
Old Sep 18, 2010, 01:53 PM
Carlyle Harper's Avatar
Joined Feb 2007
Remember the old power wheels toy cars and the electric two lane track you put together. You could make the track any way you wanted.
Anyway, after it sat for a while, the track would get this crud on it and you'd have to use some emory cloth to clean the grid before the car would make contact all the way around.
What's to say this won't happen to the copper tracks you made?
Carlyle Harper is offline Find More Posts by Carlyle Harper
Old Sep 18, 2010, 02:01 PM
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Not if he used a high quality slip ring (mil spec)
http://www.moog.com/products/slip-rings/
galaxiex is offline Find More Posts by galaxiex
Old Sep 18, 2010, 02:30 PM
Joined Aug 2009
Tnx
Here are some pix of what i did.
The copper tracks i am talking about is "de-soldering copper braided wire" , this is on the main shaft and the
contacts running on them are normal electric wire from an extension cord .
The main shaft just fits in to the lower part ( if i can call it that ).
I have drilled holes through the lower part and, fed the bare electric cable (Cm bare) through the wholes.... this
bare cable makes contact with the de-solder Wire on the main shaft.
There is no chance for a short what so ever
because the groofs in the main shaft are 4 mm deep, and the main shaft and the lower part just fits in
to each other.... meaning that the cables wont slip out of the rail / groofs.
Yea, i did not think of the "crud" factor.... This only means that i have to fly more to keep the copper clean
I am sure there are something one can put on the copper to protect it from "crud"... i will do some searching... and experimenting
Thanks aney way for the eye opener
Old Sep 18, 2010, 05:45 PM
SW England
Joined Aug 2009
Good effort.
Two better ways to make a DIY slip ring...
http://letsmakerobots.com/node/9883
even better
http://www.carlpisaturo.com/_ElNo_SLIP.html
Now you need to think about feedback for panning position - think old style 'roller ball' computer mouse or shaft encoder
Why does nobody think about putting only audio and video over the slip ring by placing the battery above the slip ring?
This way, you only need 3 tracks, 1 for video, 1 for audio and 1 for ground.
Then, there is less chance of making wideband RF from the arcing DC on the slip ring !
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Sep 18, 2010, 07:46 PM
BushmanLA's Avatar
Joined Dec 2005
The crud you should fear is oxidation of the copper.
Each ring should have two brushes to make sure one bad spot doesn't ruin your day. Also just make sure to use it often to knock all the nasty crud off.
BushmanLA is offline Find More Posts by BushmanLA
Old Sep 19, 2010, 01:00 AM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Nigel.
Why not get an 3-4 pole ear phone jack and use that? They can spin and not cause any problems...
man2000me is offline Find More Posts by man2000me
Old Sep 19, 2010, 01:31 AM
jsullivan05's Avatar
Near Saint Louis MO. (IL Side)
Joined Aug 2009
Idea=Awesome... However my friend, in execution, I think I would had revealed my plan to the fine ppl on rcg first, man2000me had a great idea with the phone jack spinners... but it looks like it works all good anyway, great job... now just watch out for the formation of corrosion and you'll be set
jsullivan05 is offline Find More Posts by jsullivan05
Old Sep 19, 2010, 01:34 AM
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
I'd use separate RXs and batteries on top and bottom instead of slip rings (unreliable and expensive). Look at at robotic snakes and such - each part has its supply and radio.
fmkit is offline Find More Posts by fmkit
Old Sep 19, 2010, 03:05 AM
Joined May 2005
I have never used a antenna tracker.
But how does the antenna know where the air plane is ?
liteglow is offline Find More Posts by liteglow
Old Sep 19, 2010, 05:59 PM
Joined Aug 2009
Good effort.
even better
Nigel.
Thank You and Thanx for the links.
""Now you need to think about feedback for panning position"" ........Mmmmm did't think of that
I dont know if i got it rite, but lets say when you use a 180* pan servo, you must program the EagleEyes to stop rotating the servo before it strip the gears, for my system woun't it work if i just don't tell the EagleEyes where to stop rotating the sevo ?
Old Sep 19, 2010, 06:10 PM
Joined Aug 2009
Maybe one can use some other material or method, that does not need to be maintained....... if only i could get my EagleEyes (backorder), then i will start knocking the crud off.
Old Sep 19, 2010, 06:12 PM
Joined Aug 2009
I did not think of that.
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot Video Piloting (FPV/RPV) 3091 Today 05:56 PM
For Sale Complete FPV ground station for sale... replayreb Aircraft - Electric - Miscellaneous (FS/W) 19 Oct 18, 2010 03:28 PM
Cool DIY Ground station with 17" TFT screen AXI Motor Models Video Piloting (FPV/RPV) 14 Sep 26, 2007 01:41 AM
Link FPV and Ground Station Recording camship Video Piloting (FPV/RPV) 10 Mar 15, 2007 06:22 PM
