Old Sep 17, 2010, 10:27 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Is there a way to test an engine without an ESC?
Hi all
My plane had sever water damage. I lost the ESC. Can I test the engine somehow without it?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Sep 17, 2010, 10:30 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
You cannot run a brushless motor without the ESC.... but if it is a brushed motor you can simply connect it directly to a battery.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 18, 2010, 02:14 AM
Expat
Japan
Joined Apr 2010
ya it's brushless. Looks ok, can't imagine it would be broken.
Old Sep 18, 2010, 04:22 AM
Finnspeed is online now
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
You could always test for short circuits with a multimeter. Check the connectors as well and clean if there's any signs of oxidation.
If you have a really good multimeter, you could measure the winding resistances too. They are normally from few tens of milliohms to couple of hundred milliohms, all three should be identical. In any case, there is a remote chance that the ESC took the motor with it when it broke. This would result in shorted winding that is usually evident from color changes and such.
Most likely the motor is OK.
Finnspeed is online now Find More Posts by Finnspeed
Old Sep 18, 2010, 07:13 AM
Expat
Japan
Joined Apr 2010
Thanks a lot.
Old Feb 23, 2011, 10:45 AM
Arielf22 is offline
Find More Posts by Arielf22
Joined Feb 2011
Banana hobby took my money!!!!!!!
BE CAREFULL WITH BANANA HOBBY !!!!!!!!!! WHO CAN HELP ME I PAYED IN ADVANCE ,THEY TOOK MY MONEY AND NEVER RECEIVE AN ANSWER SINCE THEN.I AM FROM ARGENTINA FAR AWAY !!!!
I AM STILL WAITING FOR THE MISSING PARTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
IT IS NOT SERIOUS ,
YOU ARE NOT SERIOUS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!
SOMEHOW I WILL RECOVER MY PARTS.
THREE MONTHS WAITING FOR NOTHING
order bh18-120779 from bananahobby.com
Arielf22 is offline Find More Posts by Arielf22
Old Feb 23, 2011, 11:58 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
You should post this in the proper section along with all the other complaints.
http://www.rcgroups.com/banana-hobby-560/
freechip is offline Find More Posts by freechip
Old Feb 23, 2011, 03:17 PM
crypto666 is offline
Find More Posts by crypto666
USA, NV, Caliente
Joined Mar 2009
Acutally you could do a sort of test with just a single alkaline battery (1.5v). By connecting it to two of the leads it should move a few degrees. By connecting all combination of leads two at a time you could confirm that you have continuity in all windings. I haven't done it, it was just an idea.
crypto666 is offline Find More Posts by crypto666
Discussion Is there a cheap way to test receiver batterys ? Ldm Fuel Warbirds 15 Aug 23, 2010 04:48 AM
Discussion How to have fun with a RC gas engine without the need of an RC aircraft Tekko Engines 28 Dec 23, 2009 05:44 PM
Discussion is there an easy way to balance a prop? grfcon Beginner Training Area (Aircraft-Electric) 9 Sep 23, 2009 11:51 AM
Is there a way to determine the draw of a prop/motor combo without hooking it up? steve crewdog Batteries and Chargers 6 Aug 14, 2005 10:43 PM
Rave Is there a way to tell amps used without wattmeter? taekwondo Batteries and Chargers 20 Nov 02, 2004 05:27 PM
