n/a Posts
[EFLT] Lithium Polymer Cell Discharge Graphs
This message from Don Kimball <dkimball@pacbell.net> brought to you by EFLIGHT!
I have am trying to find voltage versus time graphs for E-Tech, Kokam, and Thunder Power lithium polymer cells. I have found one high rate discharge graph (6A, 8A, 10A) at Bishop Power Products http://www.b-p-p.com/i/etec1200tests.jpg for E-Tech 1200mAh cells. I am seeing a lot of bold claims about the power output of lithium polymer cells, but there seems to be a suspicious lack of high rate discharge graphs. Note, the E-Tech 1200mAh graph shows the voltage of a 2 cell series battery is equivalent to a 6 to 7 cell NiCd or NiMH battery under high rate discharge. Thunder Power claims that their 2 cell series pack is equivalent to a 7 to 8 cell NiCd pack under high rate discharge, but there are not graphs to back up their claim. E-Tech, Kokam, and Thunder Power all claim 5C continuous discharge, and 8C 10second peak discharge for many of their cells. Can someone please point me to the voltage versus time graphs to support these bold claims? I am trying to determine if the power to weight ratio of lithium polymer cells are higher than NiMH or NiCd cells. It appears that power to weight ratio of the improved KAN950 NiMH cell is still higher than the lithium polymer cells. Don Kimball *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
n/a Posts
RE: [EFLT] Lithium Polymer Cell Discharge Graphs
This message from "Samuel M. Kennard" <sam@kennardind.com> brought to you by EFLIGHT!
<< E-Tech, Kokam, and Thunder Power all claim 5C continuous discharge, and 8C 10second peak discharge for many of their cells. Can someone please point me to the voltage versus time graphs to support these bold claims? >> I found this. http://www.allerc.com/lipoly.htm Sam Kennard *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
n/a Posts
This message from "Joe Minton" <jminton@adelphia.net> brought to you by EFLIGHT!
Don: I (and others) have found that the peak Ampere output claims of most of the LiPoly suppliers are exaggerated. I (and others) find that the original Kokams are good for a constant 2.4C and sag noticeably after less than one minute at 3C. They'll deliver 5 or 6C for 15 seconds or so before their output falls off. The E-Tec cells are fine at a constant 5C and much more for short periods. Mind you these "C" ratings are for static conditions. The 'real' current drain is less in flight. The numbers given above reflect the load measurements taken statically while the performance was judged in flight where the actual loads are less. Because the LiPolys are so power dense (light), I recommend that you use plenty of cells instead of asking them to produce the kind of Power-To-Weight ratio of the best NiCads - which they simply cannot do. The main practical advantage, at this time, of LiPolys is time-in-the-air. Weight savings is the second and shall become more important as the maximum constant "C" rating (real) goes up. I may get some heat for saying this. So be it. I stand by what I've said and invite those with differing opinions to make the same tests I have ---- try these batteries in the air and see how they do. BTW: I shall never buy another NiCad or NiMH cell. I firmly believe that LiPolys, together with brushless motors, are the most significant advance in powered modelling since the advent of the glow plug ----- and I am old enough to judge this matter. Best Regards and Best of Luck --- Joe Minton I have am trying to find voltage versus time graphs ---- . Don Kimball *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
n/a Posts
This message from Rick Page <rick-page@shaw.ca> brought to you by EFLIGHT!
There are plenty of graphs in RCGroups but there is no easy way to find them. http://www.rcgroups.com/forums/forum...s=&forumid=129 https://www.fmadirect.com/site/Detai...726§ion=28 For Kokam http://www.aircraft-world.com/prod_d...ets/lipoly.htm ETec http://www.flightenergy.com/ Thunder Power still not providing data The cells are changing every few months anyway, so we can't keep up. Rick. *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
n/a Posts
>http://www.flightenergy.com/ Thunder Power still not providing data but http://www.rcgroups.com/forums/showt...threadid=92664 *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
n/a Posts
Re: [EFLT] Lithium Polymer Cell Discharge Graphs
This message from LVRCFlyer@aol.com brought to you by EFLIGHT!
Discharge curves will be published for the Thunder Power cells/packs in most of the major RC publications worldwide over the next few months. Packs and cells were just released a few weeks back for this testing. Ive seen the in house curves direct from the manufacturer, but he has yet to publiush them until others have a chance to test for themselves. The new Thunder Power 2100 mah packs were designed for for factor and performance to replace Kan/HeCell/Sanyo 2/3 sub A cells. A few weeks back at SEFF in GA, I had a chance to fly a number of models back to back using the KAN 950s (10 cell pack) and the 3s Thunder Power 2100s. Using the same motor/prop and a whattmeter, the TP packs delivered a tad more voltage under a 20 amp load than the 10 cell KANs - this also meant a few more watts at a few less amps. In flight, the 3s LiPo packs only weighed 4.5 ounces vs the 10 cell KANs at 7.8 ounces so there was a noticeable increase in performance on the 20 ounce airplane. This was the case in a number of airplanes this size I flew that weekend. Less weight, the same or even a tad more power with twice the duration - it excited everyone who flew em! Even the manufacturer was suprised by the results as he had conservatively rated the 2100s for 10 amps continuous and 16 amps burst. This has now changed to 12.6 amps continuous and 22 amps short term burst! Im flying these same packs in a Mini Laser 3D with a Hacker B20-15L motor. Many guys saw me fly this airplane at SEFF. Full throttle current draw with a 9x6 prop on the 3s packs was 23 amps - needless to say with 250 watts the vertical on this airplane was unlimited! With throttle managment, flights averaged 20 minutes...so no, I did not abuse them at 23 amps for a large part of the flight - only in vertical. Still, the performance boost over 10 cell HeCells was amazing! Performance curves for these new cells should be published sooner as they have received so much praise and attention since SEFF. Watch the Thunder Power thread on the EZone, and keep an eye out in the magazines coming up! Jason *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
n/a Posts
At 11:56 PM 7/3/2003 -0400, you wrote: >This message from LVRCFlyer@aol.com brought to you by EFLIGHT! > >Discharge curves will be published for the Thunder Power cells/packs in >most of the major RC publications worldwide over the next few months. Good news. With this data I can optimize my aircraft set-up around the battery. I believe that the battery is the weakest link in electric flight, so I like to set up my aircraft around the optimum use of the battery. >The new Thunder Power 2100 mah packs were designed for for factor and >performance to replace Kan/HeCell/Sanyo 2/3 sub A cells. A few weeks back >at SEFF in GA, I had a chance to fly a number of models back to back using >the KAN 950s (10 cell pack) and the 3s Thunder Power 2100s. > >Using the same motor/prop and a whattmeter, the TP packs delivered a tad >more voltage under a 20 amp load than the 10 cell KANs - this also meant a >few more watts at a few less amps. In flight, the 3s LiPo packs only >weighed 4.5 ounces vs the 10 cell KANs at 7.8 ounces so there was a >noticeable increase in performance on the 20 ounce airplane. Reducing weight while keeping the power the same has an excellent effect on the flight envelope. The stall speed decreases, the rate of climb increases, and the angle of attack decreases. In addition, reducing the weight usually increases the roll rate, pitch rate, and yaw rate. Consequently, you can go through the same acrobatic routine with substantially reduced power. I am not sure, but I believe that a 15% weight reduction results in performing the same acrobatic routine with 28% less power (weight^2). Less power results in less current from the battery, that in turn results in a higher battery voltage, so that the current can be further reduced. In this case, we have a desirable self-reinforcing situation, so the flight times under acrobatics increase substantially. In fact, with the weight reduction, the increase in flight time will be substantially more than predicted by just the mAh rating increase alone. >This was the case in a number of airplanes this size I flew that >weekend. Less weight, the same or even a tad more power with twice the >duration - it excited everyone who flew em! Even the manufacturer was >suprised by the results as he had conservatively rated the 2100s for 10 >amps continuous and 16 amps burst. This has now changed to 12.6 amps >continuous and 22 amps short term burst! Im flying these same packs in a >Mini Laser 3D with a Hacker B20-15L motor. Many guys saw me fly this >airplane at SEFF. Full throttle current draw with a 9x6 prop on the 3s >packs was 23 amps - needless to say with 250 watts the vertical on this >airplane was unlimited! With throttle managment, flights averaged 20 >minutes...so no, I did not abuse them at 23 amps for a large part of the >flight - only in vertical. Still, the performance boost over 10 cell >HeCells was amazing! The 20 minute flight time for acrobatics is frequently reported in Li-Poly discussions. This is about a 3C average discharge. What is the cycle life at 3C average discharge? Most acrobatic routines with NiCd and NiMH batteries consume about 8C to 12C average current, and result in battery life of 100 to 200 cycles. Note, I work at University of California San Diego (UCSD), and I am doing Li-Poly battery testing with a student for wireless sensor networks. Another colleague is doing Li-Poly battery testing for a small electric UAV. Most of my testing is with high rate pulsed discharge with a goal of optimizing charge recovery effects. Thank you for your information. Don Kimball > Jason > >*** Any complaints or problems? Send an email to monitor@ezonemag.com >*** For help with list commands go to >http://www.ezonemag.com/pages/mailhelp.htm >*** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
| Thread Tools | |
| iRate 2600 (original, wide cell) Discharge Graphs | RD Blakeslee | Batteries and Chargers | 1 | Feb 28, 2005 07:03 AM |
| *** Lithium polymer cell for my Ultrafly *** | very-short | Batteries and Chargers | 5 | Oct 01, 2004 06:56 PM |
| Lithium Polymer Cell Imbalance: A Mitigating Solution | Awakened | Batteries and Chargers | 25 | Jan 29, 2004 01:23 PM |
| FS: E-Tech 1200mA Lithium Polymer Cell | WeatherB | Aircraft - Electric - Airplanes (FS/W) | 3 | Jul 01, 2003 03:49 PM |
| 135mAh Lithium Polymer Cell Tests | Gordon Johnson | Indoor and Micro Models | 89 | Jun 09, 2002 02:07 PM |
