Old Sep 17, 2010, 08:58 AM
rplunkett87 is offline
Find More Posts by rplunkett87
Joined Sep 2010
syma s107 top blade not working
I just got this yesterday. I've had a few good flights.. girlfriend picks it up and breaks it!! fail. She didn't even crash hard, the top blade is not spinning, the gear is not spinning for the top blade, the bottom blade seems to be spinning at full speed. Any suggestions? I'm new to heli RC so hopefully there is an easy fix.
rplunkett87 is offline Find More Posts by rplunkett87
Old Sep 17, 2010, 09:50 AM
jtravel is offline
Find More Posts by jtravel
Rather Be flying or Tinkering
jtravel's Avatar
Arizona
Joined Aug 2010
I had alot of problems with the motors in my MCX2 slipping in the frame so that they would not engage the gear or engage the wrong gear.
I did not spend much time on the S107 so I'm not sure if they suffer the same issue.
Take it apart and make inspect the motor pinion and gears as you turn the blades by hand.
jtravel is offline Find More Posts by jtravel
Old Sep 17, 2010, 09:52 AM
Joined Sep 2010
lamens terms?? lol im new at this.
Old Sep 17, 2010, 09:57 AM
jtravel is offline
jtravel's Avatar
Arizona
Joined Aug 2010
The teeth on the motor need to mesh with the teeth on the gears to make the blade spin. make sure this is happening by looking at the motor and gears as you turn the blade by hand
Old Sep 17, 2010, 10:06 AM
Joined Sep 2010
ok it's not turning the gears when i manually move the blade.
Old Sep 17, 2010, 11:59 AM
jtravel is offline
jtravel's Avatar
Arizona
Joined Aug 2010
check to see if the screw holding the gear to the shaft is missing or loose.
Old Sep 17, 2010, 03:45 PM
Joined Sep 2010
I'm not sure what the problem was, but luckily the dude at the mall that i got it from knew how to fix it. He had to soder something on.. not sure.
Old Sep 17, 2010, 09:26 PM
jtravel is offline
jtravel's Avatar
Arizona
Joined Aug 2010
now that it's fixed keep it away from the girlfriend
Cool Blade mSR with Syma s107 Blades - SWEET! FR4-Pilot Micro Helis 22 Mar 16, 2011 05:54 AM
Discussion Syma S107 TX question ferret dad Coaxial Helicopters 16 Feb 05, 2011 04:50 PM
Discussion New Syma S107 ferret dad Coaxial Helicopters 11 Aug 15, 2010 06:45 AM
