Old Sep 18, 2010, 04:48 PM
Air Vaca is offline
Find More Posts by Air Vaca
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
Hi Bob,
me too
yeah, I think Dan tried A/B blades...said it made the heli twitchy. You might try Q blades, also.
Good to hear the stock L esc will run an HP motor...
I was starting to worry about that. I remember trying to piece a BL set up together for the 4#3.....
regards,
Bill
Air Vaca is offline Find More Posts by Air Vaca
Old Sep 18, 2010, 05:19 PM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
V100D01 with the HP06-2 pictures posted
Pictures are up of the HP06-2 motor with a custom 14T pinion I
put on it so it would work with the stock tail motor.
RPM is 4,110 RPM.
The HP06-2 runs so well with the stock L ESC and plugs that
I will leave it like this. Maybe later on I'll install my CB100 L2 ESC
and solder the motor wires to it.
The pictures are in my review.
http://www.rcgroups.com/forums/showp...1&postcount=51
Tom
Tom Z is offline Find More Posts by Tom Z
Old Sep 18, 2010, 05:29 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Motor Information
A lot of motor information has just been added to my review if you
want to check it out. I tried different main motors, pinions, and tail motors.
It is in the notes section.
Tom
Old Sep 18, 2010, 08:00 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
Tom
Thanks Tom another thorough and clear review
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Sep 18, 2010, 08:32 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Regards David
Your welcome David!
Tom
Old Sep 18, 2010, 08:40 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
ESC update
Ok now that I found out my HP06-2 didn't want to start with
esc's before this was due to the pinion gear on the motor
had some bad teeth on it and it couldn't turn the main gear
smooth at all. This was enough to not let the HP06-2 start.
So I put a new pinion on it and now the stock L esc, L2 esc, and
L3 esc all start and run the HP06-2 perfect! No cogging at all either.
So at least we have some choices on what esc to use.
I then tried my XP-7A-2 EBAY BL ESC again. The main motor will
still not arm but the tail motor will. Looks like the RX doesn't like
the esc for some reason. It works perfect on my CB100.
Tom
Old Sep 18, 2010, 08:53 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
RX problems reported to Walkera
Both my and your findings about the delayed throttle response and
motor not stopping right away when you cutoff the throttle in a crash has been reported to Walkera.
I sent and email to wow and wow sent it to Walkera.
It sounds like they should address this issue.
Due to Dkfuji is not doing the review there is a chance Walkera
will give me a re-flashed RX to test out once they correct the issues.
This is just what I think might happen not what wow said.
I will keep you all updated with any response on this issue.
Tom
Old Sep 19, 2010, 12:01 AM
Dan203 is offline
Find More Posts by Dan203
Dan203's Avatar
Joined Mar 2007
Tell them you have a partner and need 2, then send the other one to me.
Dan
Dan203 is offline Find More Posts by Dan203
Old Sep 19, 2010, 12:19 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Dan
Will pass that on. Two opinions would be better than one.
Do you still want a 003 w /14T?
If so I'll sell you mine cheap if you want as I won't be using it anymore.
Tom
Old Sep 19, 2010, 01:19 AM
vronny is offline
Find More Posts by vronny
los angeles,ca
Joined May 2010
Tom
So Tom HP06 & 14T sound like good choice. Good job on the review
Thankyou for all the hard work.
vronny is offline Find More Posts by vronny
Old Sep 19, 2010, 02:02 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Your welcome.
I really like the HP06 w/14T and the stock tail motor.
Second best is the 003 w/14T and the stock tail motor.
Then for wicked power the 003 w/16T and 2.9G tail motor!
I flew some more indoors today. It's a very strong helicopter now.
Glad I was able to do the review. Not sure what else to add...
Tom
Old Sep 19, 2010, 02:21 AM
Hellraser's Avatar
UK
Joined Jul 2007
Tom
Maybe a picture showing optimum settings for the four pots on the Rx
Regards David
Old Sep 19, 2010, 10:10 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Tom
Regards David
Sounds good David, I will do that then. Should be able to post them today.
Tom
Old Sep 19, 2010, 10:16 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
"Yosi had several flights with walkera stock 600mah battery without canopy. Average flight time is 5 - 7 minutes for hovering and circular flight at altitude of 1m."
http://www.rcgroups.com/forums/showp...&postcount=329
That is nowhere near the 10-12 minutes that is claimed.
Glad he timed it as I didn't get a chance to with all the other
stuff I was doing for the review...
Tom
Old Sep 19, 2010, 10:29 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Tom
You have to remember that flight time is figured box to box. It is 10 - 12 minutes from the time you take it out of the box to fly it till it's back in the box after the flight..
livonia bob is offline Find More Posts by livonia bob
Discussion Walkera V100D01 NOW SHIPPING at www.WowHobbies.com wowhobbies Micro Helis 91 Sep 13, 2010 02:32 AM
Discussion New Walkera v100d01 ehirobo Micro Helis 9 Sep 08, 2010 09:49 PM
Mini-Review Walkera CB100 Review with pictures and video coming soon Tom Z Micro Helis 46 Jul 24, 2010 10:42 AM
For Sale RTF!!! Hirobo Lepton with Battery 500 shipped! (VIDEO & PICTURES) Eco8gator Aircraft - Electric - Helis (FS/W) 1 Oct 19, 2009 07:45 PM
