Old Sep 17, 2010, 06:50 AM
John Rood is offline
Find More Posts by John Rood
Delusional Wanna-Be
John Rood's Avatar
Boston, Massachusetts USA
Joined Mar 2004
Build Log
MiG-15 in 1/10th scale for PSS: A Scratch-Build
This is a re-cap on a MiG-15 slope-soaring glider, a 1/10th scale home-design & scratch-build that I began with a lot of fanfare in 2006 but never finished. I got lost in unnecessary complexities when what was needed was to keep things simple; eventually I set the whole thing aside.
Modifications to "scale" outlines: Slight area increase for wings and horizontal stab, stretching the span and chord, and a very slight decrease in LE sweep. Very slight stretch to the fuselage to maintain some "it looks near-scale" proportionality with the enlarged wing & stab. An art, not a science? Yes!
Airfoil: MH-32 <~~~efficient for slope-soaring model gliders
In the above sketch, purple shows proposed modifications to scale outline for the wings and tail.
Controls: Ailerons and elevator; no landing gear.
Construction: Foam wings and tail with spruce and balsa stiffeners, fiberglass fuselage from a carved foam plug.
Above: Laying fiberglass on the fuselage plug.
Wings plug-in for easier transpo.
John Rood is offline Find More Posts by John Rood
Old Sep 17, 2010, 07:21 AM
Delusional Wanna-Be
John Rood's Avatar
Joined Mar 2004
Where We Left Off
To recap: I tried making a fiberglass fuselage via the "lost foam" approach: shaping a foam "core", glassing it, and then dissolving the foam core. Well, my glassing job turned out wayyy too HEAVY , I decided not to dissolve the foam and miraculously I was able to reclaim the fragile pink foam core without wrecking it, so I can try that approach again, and hopefully do a better job glassing it this time.
But my buddies here challenged me to instead consider fine-tuning the heavy fiberglass shells into a quality plug, so I could then make a female mold around it and then lay up fiberglass fuselage shells inside the mold.
If I go that route I'll add a vertical fin, canopy and tailcone to the plug. And of those, really I should've added at least the vertical fin from the get-go.
So what you see here is as far as I got with the fuselage.
The wing became its own fiasco by me being lazy: Instead of cutting foam cores like everybody else does, I figured I'd just slam-bang a ready-made EPP foam wing (RG-14 airfoil section from L.E.G.) into shape for the MiG. So, you can see all my fussing there with spars and plug-in CF tubes, and I now have a strange bird that's not sure whether it is a EPP "foamie" or a fiberglassed "crunchy"!
I had begun the horizontal stab & elevator: plan was for a foam core with 1/64 ply sheeting, then add a hard balsa LE and TE.
Old Sep 17, 2010, 08:56 AM
JosePain is offline
Find More Posts by JosePain
JosePain's Avatar
Fort Lauderdale
Joined Jan 2010
Niceeeee ...! i love PSS stuff ...
JosePain is offline Find More Posts by JosePain
Old Sep 17, 2010, 12:46 PM
Delusional Wanna-Be
John Rood's Avatar
Joined Mar 2004
Jose, I just saw all your PSS builds on your blog here! Excelente! And who'd a thunk you could fly slope down in Florida! Very cool planes, man.
Old Sep 17, 2010, 08:41 PM
JosePain is offline
JosePain's Avatar
Fort Lauderdale
Joined Jan 2010
Thank you John , i'm very lucky to have a local slope which is actually a landfill and we can fly always upwind . Your project looks great too ..!
Jose
Discussion 5.5 inch span MiG 15. Worlds first 1/72 Scale EDF Jet? -Video added Joe Malinchak Micro EDF Jets and Power Systems 32 Jul 18, 2012 09:03 AM
Build Log Scratch Built Curtiss P-40 1/4 scale PSS - Maidened finally soargasm Slope 97 Feb 28, 2011 09:18 PM
Discussion 5.5 inch span MiG 15. Worlds first 1/72 Scale EDF Jet? -Video added Joe Malinchak Scratchbuilt Indoor and Micro Models 43 Aug 31, 2010 09:02 AM
Wanted Wii for a 1/8th electric or nice 1/10th scale interplanet Cars - Cars and Parts (FS/W) 0 Apr 12, 2010 10:37 PM
Sold 1/10th scale 1/8 scale scale jrplane Cars - Trucks and Parts (FS/W) 1 Feb 27, 2010 03:50 PM
