Old Jul 04, 2003, 12:39 AM
John Webb is offline
Find More Posts by John Webb
San Francisco Bay Area
Joined May 2001
LiPo's - what rate to charge at?
I'm all set to try out my new LiPo's... a 2s4p configuration comprised of four packs of the Kokam 2s 1200HC cells. I gather that I should charge them at 1C, but I'm not sure what that means in terms of amps. I am using a Triton charger. Any input would be greatly appreciated!
John Webb
John Webb is offline Find More Posts by John Webb
Old Jul 04, 2003, 02:10 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
You have 4x1200mAh in parallell = 4,8Ah at 1C
Haldor is offline Find More Posts by Haldor
Old Jul 04, 2003, 08:38 AM
Joined May 2001
Thanks Haldor -
The max charge rate on the Triton is 2.5V, so I assume I can't go wrong using that rate.
The max volts charging rate on the Triton is 14.8v... Can anyone advise me if I am safe to use that with my 2s4p configuration?
Happy 4th to all
John Webb
Old Jul 04, 2003, 09:05 AM
jms336 is offline
Find More Posts by jms336
Deland FL
Joined Jan 2003
Set it for Li-ion charge, 7.4 v, 2.5 A. Should charge in about 2-3 hrs from a discharged (3.0 v per cell) condition. It would be instructive for you to watch the screen while charging - you will figure out what it is doing.
With li-pos you can get about 70% charge at 1c in 1 hr. (since the triton is limited to 2.5A for li-ion (5A for other chemistries), this is true for packs up to 2500 mah. Yours are bigger, so will take longer with this particular charger.
BTW the triton will charge up to 24 cells (Nimh or Nicad), somewhere around 30 volts when needed. But for your lipos, it will top out at 8.40 volts exactly. It will do up to 4s packs (14.8v) on li-ion).
Another interesting limitation with the triton is it is only a 90 watt charger or 20 watt discharger. So you might put in to discharge a 10 volt pack at 3A, but it will only do it at about 2A (10x2 = 20 watts).
John
jms336 is offline Find More Posts by jms336
Old Jul 04, 2003, 09:24 AM
herbs is offline
Find More Posts by herbs
Ventura, California, United States
Joined Jan 2001
John, I think you may have Amps (I) and Volts (V) a little mixed up in your post.
First, It isn't safe to try to charge a 2S4P Li-Ion up to 14.8V. This is the chargers capability for a 4S configuration. For a 2S pack it would be 1/2 that amount. I don't know if you can override the Tritons default constant current charge termination voltage but if you can don't set it to 14.8V for a 2S pack.
In general a Li-Ion charge termination voltage should set to the number of cells in series times somewhere between 4 to 4.3 volts. So for a 2S configuration it should be between 8 and 8.4V. Check the manufactures web site for their recommendations.
Just checking the Tritons manual (I just got one but it's unused so far) it appears they use 3.6V as the basis for setting up the charger times the number of series cells in the pack. So for a 2S configuration you should be setting the charger to 7.2V. I assume the charger uses this as the mid-point for the charge termination voltage but as I said, my charger is still in the box and I haven't got any Li-Ion cells to charge, yet.
What these chargers do is operate in a CCCV (constant current constant voltage) mode. They charge at a constant current until they reach a preset voltage and then provide a constant voltage so they don't overcharge the cells. There is much written in other posts here and on the web regarding Li-Ion safety so I would encourage you to check these before charging/experimenting. Herb
herbs is offline Find More Posts by herbs
Old Jul 04, 2003, 03:47 PM
Joined May 2001
Herb -
You are right, I meant to say 2.5 amps for the max Triton charge rate, not volts.
I'll proceed with 2.5A; 7.4 volts. Tomorrow I'll finally find out if this LiPo mania is worth it!
thanks for the input.
John
Old Jul 04, 2003, 05:40 PM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Let us know, I'm curious too.
J Morgan is offline Find More Posts by J Morgan
Discussion Super hotliner on lipo's... what to buy? _>>>> S14 on 3KW!!! Rodebaron51 High Performance 297 Oct 06, 2007 01:45 AM
Discussion What's the best rate to charge lipos at? grampi Batteries and Chargers 21 Feb 16, 2007 10:20 AM
what rate to charge 3s 2100mah TP 11.1v packs ? McDanger Batteries and Chargers 4 Nov 16, 2005 06:12 PM
Alert Help! What amp to charge at?!?!?! tripxrcer Batteries and Chargers 1 Oct 29, 2003 08:21 PM
What rate to charge lipoly cells? Cubby Boy Batteries and Chargers 14 Jun 30, 2003 12:56 PM
