Wicked Powered J-power 50mm F-35
Here is the build thread for my 50mm F-35. The F-35 is a nice looking kit and has some room for a bigger lipo than some of the other kits in the 50mm series. So I decided that I wanted to use this F-35 as a test bed for a new 55mm EDF unit I have. I did a quick test and ona 3S1800 25C lipo inthe new fan the Wicked 4800 motor was drawing about 30-32 amps and in the 320-350 watt range which is comparable to the Wicked 6000 in the Wemotec 50mm fan.
Here goes the build! EDIT: Here is the new 55 mm fan unit: http://www.donsrc.com/cart/index.php...&productId=102 |
Actually I am going to start the L-39 build in the next day or so here. I am putting the Wicked 6000/wemo in the L-39, in fact I just assembled and balanced the motor fan combo for the L-39. The F-35 is going to be the testbed for a new 55mm fan unit I am playing around with.
Latest blog entry: Wicked Powered Tech One Neptune EDF!
The first thing I did was use my foam cutter and started to melt some foam away. The difference between the two fans is about 5mm so you need to cut away half of that which is 2.5mm or about .1" of foma away so not much is being removed.
Several melting cuts were made to the fuselage to remove the foam that was needed to get the housing to fit. Once you have that done you also need to blend the foam in front and right behind of the fan housing. To do this I used a combination of my Dremel tool with a ball stone, the hot cutter, and an Xacto with a brand new blade. With all of these tools I sculpted the foam a little so the air coming into the fan and going out the fan has a smoother transition since we have a bigger fan unit. It is really not that difficult and in a matter of about 5 minutes it was modified. The same needs to be done to the EDF hatch cover. Cut away foam then smooth it with the Dremel and Xacto if needed. The one benefit of the 55mm fan is that the stock out et is 80% FSA so no nip and tuck needed on this jet! More to come! Don
Personally I think the L-39 looks much nicer than the F-35
This is not a GWS fan. Is has a mounting plug similar to the EDO 64mm fan I sell.
Don |
Here are some more photos of the build. Trying to install the ESC is a pain in the rear so I cut an access hatch on the bottom so I could solder the ESC to the motor. Once that was done I hot melt glued the fan unit into the fuselage (make sure the EDF motor is centered on the exhaust). Mow here is where I messed up, I glued the wings on before installing the tail servos, and had no place to route the servo wires. It seems there are molded channels that you can not access if you glue the wings on first. So I had to improvise and run the tail servos as seen in the photos. Before I glued the wings onto the fuselage I did take some 320 sandpaper and sanded off some of the paint so the glue has a better place to adhere to. Next on to the tail installation.
Here are the rest of the assy photos I took. The tailerons were hinged with regular CA hinges. I did this for two reason. One they are very tough and two I wanted slightly stiff movement since they are full flying tailerons. The ailerons were both pinned like I usually do. The foam in the cockpit had to be removed to get a 3S1800 mah lipo to fit but it does fit perfectly.
Don |
Does not seem to be an issue. Here is some video form my test flights yesterday.
Don
| Thread Tools | |
| Discussion Wicked Powered Banana Hobby JPower 50mm F-18 | The Don | Don's RC | 83 | Sep 16, 2012 09:45 PM |
| Build Log Wicked Powered Banana Hobby JPower 50mm F-16 | The Don | Don's RC | 180 | Dec 01, 2011 09:19 PM |
| Build Log Wicked Powered Banana Hobby JPower 50mm F-86 | The Don | Don's RC | 126 | Aug 11, 2011 09:05 PM |
| Build Log Wicked Powered J-Power A-7 Corsair II | The Don | Don's RC | 30 | Dec 09, 2010 10:18 AM |
| Sold 50mm J-Power F-86---- OBO | teha99 | Aircraft - Electric - Jets (FS/W) | 2 | Sep 06, 2010 02:00 AM |
