Old Sep 16, 2010, 10:29 PM
lamafever is offline
Find More Posts by lamafever
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Jun 2007
Help!
How fix a broken tail boom ?
Hi
I've got a Binary 900 which need a tail fix. It broke in between the fuse and the elevator, some where right at the center :P
How and what is the best method to fix it properly? Thanks.
lamafever is offline Find More Posts by lamafever
Old Sep 16, 2010, 10:55 PM
floquet is offline
Find More Posts by floquet
Hugh Blackburn
floquet's Avatar
Melbourne, Australia
Joined Jun 2005
See this post:
http://www.rcgroups.com/forums/showthread.php?t=749124
Hugh
floquet is offline Find More Posts by floquet
Old Sep 17, 2010, 02:41 AM
Joined Jun 2007
Thanks buddy. At least i can read up and prepare myself before getting my hands dirty
Old Sep 17, 2010, 06:31 AM
lebenj is online now
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
hi...
i broke 2 times the boom of one of my DEX.
the first time i tryed reparing it only with carbon tow and kevlar tow.
i wet the tows with epoxy then aply them.
the i instead of video tape (looks a good idea) i use directly normal tape, used in the ofice!
the result was good and the tape easy to take of!
the second time, i used a piece of carbon fiber cloth and also carbo tow.
maybe a little bit heavier, but looks really better now.
still using tape around the fix when curing the epoxy.
the result is good
the fix weight was really low. and my boom was broken near the pod, so quite nothing to add in the noise!
lebenj is online now Find More Posts by lebenj
Old Sep 17, 2010, 02:09 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
I've fixed many booms but have decided to just replace the boom. It's difficult to get the boom absolutely straight most of the time, and that means you have to deal with trim problems.
Just seems easier and quicker to put a new boom into the plane.
Opinions will vary.
Gary
GaryO is offline Find More Posts by GaryO
Old Sep 17, 2010, 05:03 PM
bbbp is online now
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
To fix my boom. I used similar techniqes as above, cloth, tow, wrap with tape.
I used a simple jig I cut from a piece of 2x4 on a table saw. The 2x4 needs to be as long as possible to hold the boom. First I cut both edges flat, then I set the blade at 45^ and cut a groove centered down one long edge. Then I cut a clearance notch out from the notched edge to not quite half way thru the 2x4, a bit longer than the repair area needed to be.
The notch also has to be aligned with the damaged area. Hold the boom along the edge and mark the area to be notched.
The VEE groove holds the boom in alignment, when it is attached firmly to the 2x4. The notch lets you work material around the boom.
\----v---\ ........ |____[""""""""]____|
thin edge ......... side of 2x4 bottom edge is grooved
bbbp is online now Find More Posts by bbbp
Help! how to fix a broken composite fuse seaspb Multi Task F3X 11 Aug 23, 2010 02:28 PM
Mini-HowTo Honey Bee FP/Walkera #4, etc. tail boom fix zen@lanset.com Micro Helis 0 Mar 11, 2010 01:13 AM
How I fix broken carbon Boom treehog Hand Launch 3 Mar 06, 2005 03:52 PM
Suggestions on how to fix a broken CF boom? KurtMc Hand Launch 9 Sep 19, 2004 07:00 AM
