Old Sep 16, 2010, 06:48 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
Build Log
submarine build log
Due to problems at HQ the steam boat has be put on hold. Our new orders have been recieved. construction will commence imedetly on a new top secret vessel known simply project X.
you will be informed as more information is declassified.
nemo
nemoskull is offline Find More Posts by nemoskull
Old Sep 17, 2010, 04:09 PM
nemoskull's Avatar
Joined Sep 2009
Update....
Hull is divided into 3 sections. Fore, Mid, Aft. Fore section is done, mid is not started and aft is partially finished. motors installed. add pics.
Old Sep 17, 2010, 08:49 PM
nemoskull's Avatar
Joined Sep 2009
mid hull details....
details of the mid hull:
this part will seperate for access of radio gear. by now you are probly wondering how i am going to cover and make water tight this hull.
paper and laquer sealer.
anyways, i am using magnets to keep the hull in place. i am planning to use rubber cement to seal the hull halfs.
Old Sep 17, 2010, 09:35 PM
nemoskull's Avatar
Joined Sep 2009
oops, just realized that i didnt leave access room for the controls. hmmm....
Old Sep 18, 2010, 02:51 AM
Amp Abuser is offline
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Wooot Looking good all the same; can you fudge in a way to access the controls?
Amp Abuser is offline Find More Posts by Amp Abuser
Old Sep 18, 2010, 12:03 PM
nemoskull's Avatar
Joined Sep 2009
was going to use electomagnets, Actuators. bought some 40 somthing gauge wire, 800 feet, i have a transmitter and receiver set on 27Mhz, i am planning to use just the circuitry and make/programme a custom encoder/decoder chip, so my channels are basically limited by the chip size. if i am using actuators, then i just need two line per channel, and i have 12, so i have a possible 6 channels. the problem is going to be the the driver circuitry. i need 4 transistors and 4 resistors for each channel. unless i go SMD, its going to get real big. probly going to go SMD one day, the hull is almost done, the rest is electonics.
the sub will run off of 2.4 V, and will be using a 85MAh lipo for the RX decoder (Attiny44). i am hoping that i get enough thrust to dive the sub dynamic style.
Old Sep 18, 2010, 12:09 PM
nemoskull's Avatar
Joined Sep 2009
update.....
battery test fit pics. not much will get done today, but i will have 5 hours stuck in a car to work on the code needed ( thats the hardest part, the typing and thinking).
nemo
Old Sep 19, 2010, 06:18 PM
nemoskull's Avatar
Joined Sep 2009
hull is almost complete. just need a little bit of the aft end and the superstructure. waiting on 40 gauge green magnet wire and still working on control board.
pics: preliminary PCB image. print at 300dpi
nemo
Old Sep 19, 2010, 07:25 PM
Amp Abuser's Avatar
Joined Dec 2007
Have you ever constructed a voltage booster for 1S to put 5v to the rx?
Old Sep 20, 2010, 10:19 AM
nemoskull's Avatar
Joined Sep 2009
voltage booster
hmm. . . never lookd into it. but 5v is common. i think there is a solid state IC for voltage boost. . . amp abuser: how much current would u need?
anyways just realizd i am over thinking this. . . the rc car radio wil work jurt fine with 2.5 channels. . . just need throtle. planning to use a motor bike style thing. push the stick up twice for more speed. pull back 3 times for reverse.
Old Sep 20, 2010, 11:38 AM
nemoskull's Avatar
Joined Sep 2009
new pics....
new pictures. finished the hull and superstructure. hull is mostly sealed. i need another can of sealant.... or maybe just go to my friend who has the full setup for free.....Hmmmm.
Old Sep 20, 2010, 11:47 AM
nemoskull's Avatar
Joined Sep 2009
Amp abuser: http://www.maxim-ic.com/datasheet/index.mvp/id/5127
dc to dc step up chip. 2.5v to 4.2 input, 3V to 5V output, 1 amp current. only problem, 3mm by 3mm SMD chip. but i hear with a 15 watt soldering iron that is not that hard........
nemo
Old Sep 20, 2010, 04:42 PM
nemoskull's Avatar
Joined Sep 2009
painting started...
Paint started. base coat of grey ( used .97 cent acryllic from wally world, thined with 70 isopropol alchol and createx black)
going to start electronics next, using running lights for night time navagation, and flood lights for nite as well. still waiting on my wire for the actuators.......
should be here tomarrow.
nemo
Old Sep 20, 2010, 07:29 PM
Amp Abuser's Avatar
Joined Dec 2007
The paint sure made the frame pop and show the work.. air gun put things in perspective in more ways then one. Thank you for the tips.
Old Sep 20, 2010, 11:34 PM
nemoskull's Avatar
Joined Sep 2009
yeah, went round and round with that in my head. a plus is that the acrylic paint dries in minuites instead of hours.
writing code right now for the trottle. going to be using a paddle shifter style throttle, electronic of course. 4 forward speeds, one neutral, and 4 reverse speeds.
i might post this i an instrucable when it works flawlessly. if it ever does.
Discussion Off Topic: Micro Boat Forum, Official Poll has begun boredom.is.me Micro Cars 9 Oct 21, 2010 08:25 PM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
Build Log Project X Build Log - Belated Kmot Dock Talk 43 Dec 01, 2008 05:30 PM
