This thread is privately moderated by svonavja, who may elect to delete unwanted replies.
Old Sep 16, 2010, 04:01 PM
svonavja is offline
Find More Posts by svonavja
I'm a pilot... I can fly
svonavja's Avatar
United States, OH, Hiram
Joined Jun 2010
Mini-HowTo
*Upgrade* Your Parkzone P51 Mustang
Follwing these instructions will increase the planes FUN factor! A++ Without taking away for the look and feel of the stock plane.
What to Buy:
First thing you need to do is purchase your hop-ups...for a grand total of $31.70..minus the batteries..
http://www.hobbypartz.com/monsterpow...ess-motor.html
http://www.hobbypartz.com/30a-electr...o-series-.html
Dis-Assembly/Assembly:
Ok after you have the parts your going to take everything apart in the front end of your mustang...Just a note...you'll use all of your stock mustang parts, only using the Exceed Brushless and ESC.
The only modification you need to do is on the Exceed motor, the shaft currently sticks out the rear and needs to be pressed or hammered gently to the opposite side, don't forget to loosen the set screws on both sides of the motor before adjusting the shaft....i have done the hard work calculating the distance of the shaft needed to attach the stock prop adapter in order to meet up with the front cowl correctly, see pics attached.
All Done, just put it back together, you'll only be able to use 2 screws on the motor mount unless you drill it (flew fine with only 2).
Oh and Line up the notches on the nose cone or you'll lose it...
I will add a video once I get time to take one...It flys like a dream and I should have done this right after I bought it....Enjoy
Video:
Parkzone P51 Mustang Upgrade.3gp (3 min 10 sec)
-Svonavja
svonavja is offline Find More Posts by svonavja
Old Sep 16, 2010, 06:07 PM
Skiscola is offline
Find More Posts by Skiscola
You cant crash if you dont fly
Skiscola's Avatar
Norfolk VA
Joined Aug 2010
Lets see the vid
Skiscola is offline Find More Posts by Skiscola
Sold Turbo charge your PKZ Trojan, Corsair, or P51 Mustang cutty01 Aircraft - Electric - Power Systems (FS/W) 2 May 20, 2010 11:35 PM
New Product Parkzone Sukhoi P51 4site UPGRADE 180mAh 15c battery indoor_fr Scratchbuilt Indoor and Micro Models 8 Jan 23, 2010 05:36 PM
Wanted WTB: Parkzone micro p51 mustang RTF rsos1 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Dec 05, 2009 11:54 PM
Sold parkzone mustang p51 micro RajSharma Aircraft - Electric - Airplanes (FS/W) 5 Nov 03, 2009 04:37 PM
What are your thoughts on the parkzone p51 mustang peiviper Parkflyers 2 Aug 12, 2005 09:07 PM
