Old Dec 16, 2010, 06:42 PM
NCHeliHead is offline
Find More Posts by NCHeliHead
NCHeliHead's Avatar
United States, NC, Wilmington
Joined Nov 2010
Originally Posted by Gohmer View Post
Motor stuff is boring. Can you post a pic of the pies?
I think it would be better if you started a "Pies" thread for that.
NCHeliHead is offline Find More Posts by NCHeliHead
Old Dec 16, 2010, 07:00 PM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
Originally Posted by rahtware View Post
Hey guys, the replacement motor/prop arrived and I am in the middle of gathering data. the replacement motor is the one with the smaller, plastic and metal bell. The replacement prop (part # PKZ1017), and the kit prop have the same markings, "9.75X7.5_1".
I plan on making 4 different tests, kit motor/kit prop, kit motor/new prop, new motor/kit prop, new motor/new prop.
Notes, I am:
using my Eagle Tree eLogger V3 to gather the data.
making 1 1/2 minute runs at full throttle to let the motor and Battery stabilize.
using the stock 1300mah battery that came with the BNF kit.
using my Supermate DC6 charger to recharge the battery between tests, and letting the battery rest for an hour after each charge.
All this while I bake two pumpkin pies!
Oh, I can take pics and attach data spreadsheets if anyone is all that interested.
That sounds like a great series of tests...can't wait to see your results.
-mike-
boiko is offline Find More Posts by boiko
Old Dec 16, 2010, 07:02 PM
Duncandiver is offline
Find More Posts by Duncandiver
R/C is a SICKNESS
Duncandiver's Avatar
Vancouver, BC, Canada
Joined Oct 2009
MMMMMMMMMMMMMMMMMMMM....pie
Id like to see the motor/power results too
Duncandiver is offline Find More Posts by Duncandiver
Old Dec 16, 2010, 08:16 PM
rahtware is offline
Find More Posts by rahtware
rahtware's Avatar
NorCal
Joined Oct 2002
First test delayed while I ran into town (4mi and 52 turns away) to get aluminum foil for the pie shells. After 20 sec the stock motor and prop settled down to (around) 11.83 Amps / 212.9 Watts.
Gohmer, et all, Sorry, suffered a pie delay, more to come....
rahtware is offline Find More Posts by rahtware
Old Dec 16, 2010, 09:02 PM
rahtware is offline
rahtware's Avatar
NorCal
Joined Oct 2002
Pies in the oven, battery charged and resting.
I had a chance to work with the ET 2D chart and came up with these results for the minute in the middle of the "stable" run time.
V: Min 10.86, Max 11.10, Avg 10.99
A: Min 11.65, Max 12.11, Avg 11.83
W: Min 126.52, Max 133.06 Avg 130.05
Old Dec 16, 2010, 10:05 PM
rahtware is offline
rahtware's Avatar
NorCal
Joined Oct 2002
Kit motor / Replacement prop:
V: Min 10.86, Max 10.93, Avg 10.89
A: Min 13.12, Max 13.67, Avg 13.43
W: Min 142.48, Max 149.14, Avg 146.27
Old Dec 16, 2010, 10:14 PM
MS_in_NY is offline
Find More Posts by MS_in_NY
MS_in_NY's Avatar
Joined Oct 2009
Uhhh, that watt reading has to be wrong. Unless you were running the motor on 18 volts.
112.9 watts right? That would be 9.5 volts.
......Mike
MS_in_NY is offline Find More Posts by MS_in_NY
Old Dec 16, 2010, 10:15 PM
rahtware is offline
rahtware's Avatar
NorCal
Joined Oct 2002
Pulled the Kit motor, but before I installed the replacement motor I took some pictures.
I didn't have an original Radian so don't know what the motor that came with it looked like.
I'm not too sure about the plastic bell on the replacement motor.
Old Dec 16, 2010, 11:23 PM
rahtware is offline
rahtware's Avatar
NorCal
Joined Oct 2002
New motor / Kit prop:
V: Min 10.92, Max 11.15, Avg 11.04
A: Min 12.02, Max 12.47, Avg 12.17
W: Min 131.26, Max 137,42, Avg 134.37
I don't see much of an improvement from the motor that came with the kit...
Old Dec 17, 2010, 01:47 AM
rahtware is offline
rahtware's Avatar
NorCal
Joined Oct 2002
Finally!
New motor / new prop
V: Min 10.87, max 10.97, Avg 10.91
A: Min 13.94, Max 14.58, Avg 14.29
W: Min 151.10, Max 158.09, Avg 155.26
Condensed version of data:
Kit motor/kit prop: Average Amps = 11.83; Average Watts = 130.05
kit motor/new prop: Avg Amps = 13.43; Avg Watts = 146.27
new motor/kit prop: Avg Amps = 12.17; Avg Watts = 134.37
new motor/new prop: Avg Amps = 14.29; Avg Watts = 155.26
Seems like the new prop makes up for most of the increase in power... Might just keep the old motor (with the all metal bell), but go with the new prop.
Biggest problem with my data is I don't have a thrust meter. I thought I could feel a difference in "pull", but no way to prove it. And, as Dr Kiwi and others have proved, an increase in power consumed does not always translate to an increase in thrust.
The chart is just a "Print Screen" pic as it is late and I am too tired to figure out how to upload it directly from the Eagle Tree program.
The four separate sections are the different motor/prop combination in the order as listed above in "condensed version..."
Old Dec 17, 2010, 01:52 AM
rahtware is offline
rahtware's Avatar
NorCal
Joined Oct 2002
......Mike
Mike, my bad. I think it was 121.9, but I can hardly focus on the screen now so going to bed and will check it in the morning...zzz
Old Dec 17, 2010, 01:53 AM
rahtware is offline
rahtware's Avatar
NorCal
Joined Oct 2002
Oh, almost forgot.
Old Dec 17, 2010, 02:08 AM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
http://www.horizonhobby.com/content/...ast_100710.mp3
Heres a good listen of a little more in dept talk about the Pro.Its starts around 2-3 mins into the Clip
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Dec 17, 2010, 02:17 AM
MS_in_NY is offline
MS_in_NY's Avatar
Joined Oct 2009
Don't bother checking that's probably it. That would be 10.3 volts. Not important.
Thanks for doing and posting those tests. There does seem to be 'something' about the props on the Pro that's 'funny'. But the thing that really surprises me is I thought the 'replacement' motor, i.e. the original Radian 480, would pull a lot more amps. I expected 17-18 at least.
.......Mike
Old Dec 17, 2010, 06:25 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Finally!
snip:
Rahtware
That is an EXCELLENT series of tests. And the fact that you took your radings at 20 seconds gives us much truer numbers than an instant or peak test. You have shown that the issue is both the motor and the prop.
We know that not all props of the same specs have the same characteristics. You can have two props that are 9.75X7.75 that have different characteristics based on the airfoil of the blade. (yes, prop have aifroils. They are spinning wings.)
So, it seems they have a motor that is lower performance than the original AND a prop that does not pull as hard as the original. So both need to be changed which yields about a 20% improvement overall. That is significant.
I look forward to hearing your flight reports and a comparison of the climb performance.
aeajr is offline Find More Posts by aeajr
Discussion Radian Pro, rumours, leaks and new info! Bowerz Electric Sailplanes 27 Nov 23, 2010 02:18 PM
For Sale Parkzone Radian PNP like new with batt $125 jzanutto Aircraft - Electric - Airplanes (FS/W) 5 Sep 28, 2010 02:25 PM
Discussion ParkZone's P-51 Gunfighter Discussion Thread [NOT the PZ P-51 Complaints Thread] dabesq Electric Warbirds 184 Jan 19, 2010 10:21 AM
Discussion Thread Thread Starter Forum Replies Last Post Discussion Large Cabin Cruser buil Jolly Roger 1 Scale Boats 0 Jan 06, 2010 11:43 AM
Wanted Multiplex EasyGlider Pro/Cularis PNP/BNF or Parkzone Radian Sid3ways Aircraft - Sailplanes (FS/W) 6 Jul 21, 2009 08:36 PM
