Old Nov 24, 2010, 08:17 AM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
No its not intended too fit.But im sure with a saw and 600 grams of Epoxy and some red duct tape it well Jam it in there some how lmao..J/kin,in the vid Steve says there not designed too fit,but im sure theres a way.not sure how it well look but...
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Nov 24, 2010, 08:40 AM
v9climber is offline
Find More Posts by v9climber
Joined Nov 2010
Well seems like the questions are being answered over in this thread, so here goes:
I am having an issue setting up Crow on the Pro using the DX6i. I have followed the instructions to the letter: http://www.horizonhobby.com/ProdInfo...DX6i_setup.pdf All that happens when I throw the flaps switch is I see the ailerons deflect in opposite direction. So I am getting 65% left up and 65% right down. All other control surfaces are functioning correctly. I am just wondering as I saw on the pg before there was an issue with the DX7i instructions, maybe there is something wrong with the DX6i instructions. Any help would be greatly appreciated.
v9climber is offline Find More Posts by v9climber
Old Nov 24, 2010, 08:47 AM
minirips2 is offline
Find More Posts by minirips2
Chicago Northwest subs
Joined Jan 2007
Did you try reversing the servo channel on the aileron? If that's not doing it, then try a negative % mix on the naughty channel. I wish I could help more, but I don't use a DX6i.
MR2
minirips2 is offline Find More Posts by minirips2
Old Nov 24, 2010, 09:15 AM
Joined Nov 2010
MR2
Yes I have tried both reversing the servos and my mix has always been negative even tried positive and tried both mixes on the down side just to see if the ailerons would both travel down together. They are always split.. one up one down. Anyone else use a DX6i?
Old Nov 24, 2010, 09:34 AM
Joined Jan 2007
Question for someone who has received theirs-Are the servo output shafts all pointing towards the wingtips, or arranged to avoid reversing y-harnesses? Also, has anyone set up a PNP for AR7000 on a JR X9503? I'm looking to go big with all flight modes available on the Tx and throttle on one of the side levers. If not, then I'm sure the programming will be half the fun!
MR2
Old Nov 24, 2010, 09:40 AM
Metman is offline
Find More Posts by Metman
Canada, BC, Victoria
Joined Jul 2009
Yes.. But no Pro yet. Am following this with interest!
Metman is offline Find More Posts by Metman
Old Nov 24, 2010, 10:01 AM
tking2097 is offline
Find More Posts by tking2097
'Sky' King
tking2097's Avatar
Watauga, Texas
Joined Jul 2007
MR2
Aileron servo shafts each point out to the wingtip.
Flap servo shafts both point towards the right wingtip.
FWIW, the BNF Radian Pro comes with an AR600 receiver configured with a standard Y-harness (not reversing!) for flaps and ailerons:
Left + Right Flaps -> Y-harness -> Gear input
Left + Right Ailerons -> Y-harness -> ALE input
To use Full-House features with the AR600 that comes in the BNF Radian Pro, the aileron Y-harness must be removed and the right wing aileron servo plugged into the ALE input, and the left wing aileron servo plugged into the AUX 1 input.
I don't have any AR7000 receivers or the JR X9503, so perhaps someone with these will join in your adventure of programming for this transmitter and receiver.
Tom
tking2097 is offline Find More Posts by tking2097
Last edited by tking2097; Nov 24, 2010 at 11:29 AM. Reason: added aileron configuration info.
Old Nov 24, 2010, 10:54 AM
tbird911 is offline
Find More Posts by tbird911
I added lift to my stable!
tbird911's Avatar
Knoxville, TN
Joined Feb 2007
Model Masters (local hobby store) . . .period :)
Originally Posted by Energy View Post
Thanks guys, I hear you can use crayon paint from walmart. Does the vylne tape stick to the foam and stay on pretty well.?
E
edit* oh, maybe a saw krylon and thought it said crayon.
Model Masters (not their laquer based) covers in one coat and holds up really well. I've tried others and had problems ranging from it eating the foam to flaking and requiring multiple coats. Model Masters is the goods!
tbird911 is offline Find More Posts by tbird911
Old Nov 24, 2010, 11:06 AM
Joined Nov 2010
Still looking for someone that has successfully setup their DX6i? Anyone
Old Nov 24, 2010, 11:21 AM
MS_in_NY is offline
Find More Posts by MS_in_NY
MS_in_NY's Avatar
Joined Oct 2009
The DX6i instructions 'look' ok to me.
It sounds like you either...
A) have the ailerons plugged into the y-harness (should be right aileron to 'ail' and left aileron to 'aux 1' on the rx, no y-harness needed) or,
B) you don't have 'Dualaile' set to 'act' in 'wing tail type'.
......Mike
MS_in_NY is offline Find More Posts by MS_in_NY
Old Nov 24, 2010, 11:32 AM
ColinB is offline
Find More Posts by ColinB
Joined Mar 2004
Originally Posted by rcbrust View Post
Here's a pic of the left wing. The right is warped too, but not as bad as this one. Starting from the root, everything is lined up and you can see where the tip of the aileron ends up.
It's hard to see in the picture but the aileron trailing edge actually has an arc to it. Very disappointing to have something unflyable, right out of the box.
Randy
What would happen if you just centered it as best you could? Probably cause extra drag and induce a turn?
Things like this make me wonder how the Radian or Radian Pro would stack up against a balsa built up glider such as the Chrysalis or Renny? (Granted, they probably would cost more and they take more building.) But for gliding ability and long term use...
But then I go back to the videos of new pilots nosing in their Radians, picking them up, and tossing them again. The balsa planes I have are pretty tough, but I don't think they'd survive that well.
Keep those flight reports and comparisons coming! For us snow-bound armchair pilots, reading and wondering about flying is as close as we get.
Colin
ColinB is offline Find More Posts by ColinB
Old Nov 24, 2010, 12:04 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Originally Posted by Raften View Post
Diggs, on those Rhino 1050 lipo's you use. Do they have the DX60 connectors on them and will the Radian EC3 plug into those connectors?
Yes they have the XT60 connectors, but I have no idea if they will mate to an EC3.
Diggs
Diggs is offline Find More Posts by Diggs
Old Nov 24, 2010, 12:22 PM
Joined Nov 2010
......Mike
Thx Mike that got me 1/2 there. I did not have the left aileron plugged into the aux1. OK now with this setting (On the Rate, leave the Down at 0% and change the Up to -65%.) the ailerons deflect down instead of up. If you put + 65% for up.. they both now go up. But nothing happens when the Flaps switch is thrown to the down position, or should I say the ailerons go back to neutral position and flaps go down like normal. Thanks in adavance for all the help.
Old Nov 24, 2010, 12:51 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
Diggs
The reason I ask is someone on another thread said they do. So you must change the Radian connection that comes with it to a XT60????
Raften is offline Find More Posts by Raften
Old Nov 24, 2010, 01:16 PM
MS_in_NY is offline
MS_in_NY's Avatar
Joined Oct 2009
Ok, this is what I've got from playing with the servo 'monitor' screen. I don't have a model on the 6i with both ails and flaps.
I believe the 'Mix 1' instructions in that Horizon pdf are wrong. I 'think' the mix should be 'FLAP>GEAR' not gear>flap as instructed.
You also have to go to the 'setup menu', select 'FLAP', put the flap switch in its bottom position (LAND in the setup menu) and set the up travel there. (you should also be able to add elevator compensation there instead of using the second mix).
I hope I'm not totally leading you into a programming black hole. Doing this without a plane to watch is pretty confusing.
......Mike
Discussion Radian Pro, rumours, leaks and new info! Bowerz Electric Sailplanes 27 Nov 23, 2010 02:18 PM
For Sale Parkzone Radian PNP like new with batt $125 jzanutto Aircraft - Electric - Airplanes (FS/W) 5 Sep 28, 2010 02:25 PM
Discussion ParkZone's P-51 Gunfighter Discussion Thread [NOT the PZ P-51 Complaints Thread] dabesq Electric Warbirds 184 Jan 19, 2010 10:21 AM
Discussion Thread Thread Starter Forum Replies Last Post Discussion Large Cabin Cruser buil Jolly Roger 1 Scale Boats 0 Jan 06, 2010 11:43 AM
Wanted Multiplex EasyGlider Pro/Cularis PNP/BNF or Parkzone Radian Sid3ways Aircraft - Sailplanes (FS/W) 6 Jul 21, 2009 08:36 PM
