Espritmodel.com Heli Air
Old Sep 29, 2010, 06:36 AM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Originally Posted by ChuckTseeker View Post
Pre ordered my Radian Pro PnP for $229 Aud which i thought was again reasonable, if i could have afforded it i would of bought the BnF at $309 again a good price seeing as you get a batt and AR600 for $80 more than the PnP
cheers chuck
Was that the pre-order shown on ModelFlight?
scirocco is offline Find More Posts by scirocco
Old Sep 29, 2010, 06:50 AM
AKA - The "Flywheel"
StevenatorLTFO's Avatar
SOAR Chicago!!!
Joined Jan 2005
Originally Posted by 7AC View Post
It sure would have been nice if the guy who got it "mistakenly" had flown it. I am really curious how it will fly without the graceful dihedral arc of the Radian. I've flown an Easy Glider with ailerons and it is a totally different animal. I also wonder whether they have retained the original Radian airfoil? I think that thick airfoil allows the slow flight that makes the Radian such a great thermal hunter.
I along with about 39 of my closest friends, got to fly one on Saturday evening. Flies just as well as the R/E Radian, but the roll rate is a little better, and the flaps will really help put it down on a spot. The R/E Radian really will float in ground effect!
It was really windy Saturday evening, but thermalling speed looked to be about the same as the R/E bird.
For setup, the flaps and ailerons are on a Y cable, but there is still a slot left in the receiver, so I think it would be pretty easy to put each aileron on a separate channel and perform a little more advanced programming. The one I flew was bound to my 9303 transmitter, and the only extra mixes that we put in was a little flap to elevator compensation, and some aileron to rudder mixing because we didn't have any aileron differential (because of the Y harness).
Climb rate seemed just about as good as the R/E Radian, but you are hauling around just a little more weight (I suspect an ounce or so)
The other changes I did notice, is that there is a positive locking device for the wings, and the elevator has a different connector now.
I will be ordering up one for sure, just as soon as the minister of finances says that its ok!
StevenatorLTFO is offline Find More Posts by StevenatorLTFO
Old Sep 29, 2010, 06:59 AM
Justaflier's Avatar
Central Ga.
Joined Jun 2004
Originally Posted by aeajr View Post
I would suggest that you do the entire Spektrum and JR line.
DX6i - whatever would be recommended with that
DX7 - we presume it can do more.
DX8 - should be able to do more or at least do easier
JR9303/9503 - Can do anything your little heart desires.
Don't forget the 11X. The manual leaves something to be desired anyway so a little help form Horizon would be most appreciated. I plan on using an AR7600 rx since it's not much bigger than the 6ch receivers.
Justaflier is offline Find More Posts by Justaflier
Old Sep 29, 2010, 07:24 AM
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
yep pre ordered on the Model Flight site
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Sep 29, 2010, 07:59 AM
LI, New York, USA
Joined Mar 2003
Based on pricing, the PnP models, receiver ready models, are best for 72 MHz pilots or people who have plenty of batteries and chargers.
If you are a 2.4 pilot and wouldn't mind getting another battery and charger, the BnF is a better deal.
Same can be said for the original Radian. The RTF is a better deal for the 2.4 GHz pilot even if you throw the radio away.
aeajr is offline Find More Posts by aeajr
Old Sep 29, 2010, 08:16 AM
Turtle_Flyer's Avatar
Joined Oct 2007
IMHO I think Fred Midgett needs to give Parkzone some lessons on marketing. Some PZG's are needed. Note the comparison below. I want the Radian Pro....I NEED the Higher Plane productions video NOW. Marketing it's all that matters!!!
Originally Posted by Doushiyou12 View Post
Personally, its not a good way to advertise the aircraft, let snap shot the plane on its own.
Turtle_Flyer is offline Find More Posts by Turtle_Flyer
Old Sep 29, 2010, 10:14 AM
Wallington, New Jersey, USA
Joined Apr 2010
Originally Posted by Mattfly View Post
We will have radio setups on the product page for the Radian Pro by the time it ships. We will try to cover as many radio setups as possible.
Matt Andren
Parkzone/Hobbyzone Product Development
Horizon Hobby
That's great! With regards to the chapter about thermals in the Radian manual, do you think there will be a write up somewhere tailored to the Radian Pro? For newbies like me? :-)
hugofly is offline Find More Posts by hugofly
Old Sep 29, 2010, 11:56 AM
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
True that!
The thought process that runs through my head:
"if i get the plane, maybe i'll get the girl too least have a similarly as good looking girl come up to me whilst i'm flying and put her hand on MY shoulder "
Bowerz is offline Find More Posts by Bowerz
Old Sep 29, 2010, 01:28 PM
Just do it.
FlyFisch's Avatar
Stroudsburg, PA
Joined Nov 2009
When I ordered from Horizon it said "backorder" not preorder. Same thing right?
FlyFisch is offline Find More Posts by FlyFisch
Old Sep 29, 2010, 02:53 PM
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Yes...
Aeronca
aeronca is offline Find More Posts by aeronca
Old Sep 29, 2010, 06:41 PM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
I've mainly been flying flat foamies and Ultra Micros but was interested in the Radian for some time and especially now with the pro.
My main question is how much wind will the Radian take and still fly relatively well and stable? Like to have something that I can fly with some wind unlik the foamies and UM that like none.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Sep 29, 2010, 06:46 PM
Joined Apr 2010
The Radian can definitely handle wind much better than flat foamies and UMs, simply due to it's large wing span. Also, by the nature of how you fly the Radian, it's not going to be in as much turbulence, because you typically fly it higher up, where the wind is "cleaner", because it's blowing undisturbed by buildings, trees, etc.
Old Sep 29, 2010, 06:48 PM
Joined Apr 2010
If the Radian Pro thermals as well as the Radian and can be flown with rudder only when it's really high up (like I fly my Radian) and it's dihedral is enough to keep the wings level automatically, I'll probably neglect my Radian. I could also see my Radian stay my calm condition sail plane and the Radian Pro be my windy day sail plane. I'll see!
Old Sep 29, 2010, 06:51 PM
LI, New York, USA
Joined Mar 2003
Rudder only? Probably not.
As self leveling at the Radian? Probably not.
Old Sep 29, 2010, 07:00 PM
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I would have to jump on this speculation bandwagon and agree completely. I don't think the Pro is going to level off like the Radian does due to the flatter wing. If they want the ailerons to have any authority, the self stabilization is going to be lacking. Again, having not flown one, we could be wrong, but I would think it will require a lot more input to keep level. I am anxious to see myself.
Diggs
Diggs is offline Find More Posts by Diggs
Discussion Radian Pro, rumours, leaks and new info! Bowerz Electric Sailplanes 27 Nov 23, 2010 02:18 PM
For Sale Parkzone Radian PNP like new with batt $125 jzanutto Aircraft - Electric - Airplanes (FS/W) 5 Sep 28, 2010 02:25 PM
Discussion ParkZone's P-51 Gunfighter Discussion Thread [NOT the PZ P-51 Complaints Thread] dabesq Electric Warbirds 184 Jan 19, 2010 10:21 AM
Discussion Thread Thread Starter Forum Replies Last Post Discussion Large Cabin Cruser buil Jolly Roger 1 Scale Boats 0 Jan 06, 2010 11:43 AM
Wanted Multiplex EasyGlider Pro/Cularis PNP/BNF or Parkzone Radian Sid3ways Aircraft - Sailplanes (FS/W) 6 Jul 21, 2009 08:36 PM
