Anyway, use the setup posted here: http://www.rc-soar.com/spektrum/index.htm You *will* need a 7 channel RX to do these setups. And you will have to make some trade-offs between CROW and flap/aileron mixing. IMHO, you are better off with CROW vice flap/aileron mixing. Also, move those control horn positions. You guys should be able to get 50+ degrees on the flaps. The Radian dropping at 1500 feet per minute while slowing down is a thing of beauty. Now if I could just get her to climb at 1500 f/m.
Xptical: I am totally confused; I dont want to be a PITA; just need some correction from a pro. As you stated in post 1606:
"Anyway, use the setup posted here:"http://www.rc-soar.com/spektrum/index.htm "STEP 2: Connect the Servos" The table below shows the servo assignments. The wing servos are shown in purple - chs 2 and 6 are assigned to the inner surfaces ('flaps'), while chs 5 and 7 are assigned to the outer surfaces ('ailerons'). Rx Channel Connect this Servo 1 THRO Throttle 2 AILE Right Inner (flap) 3 ELE Elevator 4 RUDD Rudder 5 GEAR Left Outer (aileron) 6 FLAP Left Inner (flap) 7 AUX2 Right Outer (aileron) Note that on my DX7 the screen when you press the select button for servo plug connections, the sequence is: 1. Thro 2. Aileron (I assume right side?) 3. Elev 4. Rudd 5. Gear ( I think this is for FLAP which the r-c.com reference above STATES left AIL) I dont know if this is right or left FLAP.......or AIL ??? 6. Flap ( Same as indicated in the r-c.com reference above); Is this right or left? 7. Aux 2 ( r-c.com indicates above that this position is right aileron...should this be right or left aileron???? My AR7000 rx has these positions printed above each connection: 1. Thro 2. Ail 3. Elev 4. Rudd 5. Gear 6. Aux 1 7. Aux 2 This has me completely confused. On top of that, Horizon told me that GEAR is right wing flap, AUX 1 is the left wing flap and AUX 2 is the left wing aileron. If anyone has correctly completed these connections and they work as they should, could you label the correct connections (left or right) for the AR7000 rx above. I sincerely appreciate your kind assistance....... |
The throttle channel should be labeled CH1 and that goes on down the line through CH7. Hey, Spektrum/JR: DON'T EVER LABEL A RX WITH GOSH-DARN SURFACE NAMES! It just confuses people. Anyway, just completely abandon the stuff from JR/Spektrum and go solely on the link I provided. CH1 is *usually* labeled THRO down through AUX2 which is CH7. Just to show you how meaningless the RX names are, on my 9303 and 11x, you use THRO and AILE for the two outboard ailerons. The actual ESC plugs into GEAR or AUX3. Now, where's my Sharpie so I can correct Spektrum/JR's dumbness? |
Oh, in answer to your question, it seems they RC Soar has this:
2 AILE Right FLAP 5 GEAR Left AILERON 6 FLAP Left FLAP 7 AUX2 Right AILERON I'll grab my buddies' DX7 this afternoon and confirm that it works as RC-Soar says it does. But at this point, I have no reason to doubt RC-Soar and every reason to doubt anything JR/Spektrum says. |
LI, New York, USA
Joined Mar 2003
I would doubt this would be the case but I don't have a Spektrum radio or a JR radio. But I think you are incorrect. I would not want new glider pilots confused by this. Can anyone who has one of these radios comment on this? I don't think this is true. Normally the master is an input device. We may speak of ailerons as master, but what we really mean is the maser is the aileron input device which controls a channel. The right stick channel is master and the slave is the channel that has the rudder. So master is a device, not a surface. So aileron-rudder mixing is driven from the right stick only. It is actually channel slaved to channel, not surface to surface. In Crow, ailerons are not master, they are slaved to a master input device, in this case a switch. The switch has a number of slave channels including the 2 aileron channels and the flaps and perhaps the elevator too. If the ailerons are the slave, as they would be in crow, then the rudder channel should not be affected at all. Can someone verify this is how it works on the Spektrum radios? BTW, I do use A-R mixing on my full house sailplanes and I do have it on a switch, but that is so I can turn it on and off for convenience. Normally I have A-R mxing on when I am cruising. But I sometimes like to turn it off when I am working a thermal so I can have better control of the rudder rather than having it working at a fixed %. And I have never had to turn it off in order to activate crow. |
As you stated, the slave happens off the stick input, not the channel output. So, there is really no need to disable A>R mixing when you enter CROW. |
Joined Feb 2008
aeajr:
It is nice to have a streamer like the 72 mhz radios had. It is useful to see wind direction and in detecting thermals. Now that I have 2.4 radios, what would be a good way to put a streamer on the radio? A 72 mhz antenna or a CF rod could be taped or velcroed on to the side of the radio, but maybe that would interfere with the signal. Do others use a wood dowel or plastic rod? How do they fasten it to the radio? I see other at the AMA field looking around to see the wind sock, but it seemed a lot better with the streamer on the antenna. No need to take the eyes off the model to see the streamer. egull |
By looking at the streamers, you can visualize thermal activity. |
LI, New York, USA
Joined Mar 2003
For those 72 MHz guys who converted, tape the antenna to the side or back of the radio but out of the "view" of the 2.4 antenna. Stretch it up and put on the streamer. Your 2.4 GHz antenna should be turned flat so the side of it faces the plane. That is your best signal configuration. The 72 MHz antenna, or dowel or whatever, will be in the blind spot at the bottom of the 2.4 antennna and shouldn't bother anything. |
Latest blog entry: Getting into FPV while KISS
I like a windsock or two placed around the field so I can see what the wind is doing 'over there'. But I can't believe people are actually comtemplating ADDING a long antenna to their 2.4 TXs just for a wind streamer. I can sense the direction of wind flowing past my body without any visual aids. A streamer on the TX isn't gonna give you any more info than that.
To each their own of course. ![]() ........Mike |
| Thread Tools | |
| Discussion Radian Pro, rumours, leaks and new info! | Bowerz | Electric Sailplanes | 27 | Nov 23, 2010 02:18 PM |
| For Sale Parkzone Radian PNP like new with batt $125 | jzanutto | Aircraft - Electric - Airplanes (FS/W) | 5 | Sep 28, 2010 02:25 PM |
| Discussion ParkZone's P-51 Gunfighter Discussion Thread [NOT the PZ P-51 Complaints Thread] | dabesq | Electric Warbirds | 184 | Jan 19, 2010 10:21 AM |
| Discussion Thread Thread Starter Forum Replies Last Post Discussion Large Cabin Cruser buil | Jolly Roger 1 | Scale Boats | 0 | Jan 06, 2010 11:43 AM |
| Wanted Multiplex EasyGlider Pro/Cularis PNP/BNF or Parkzone Radian | Sid3ways | Aircraft - Sailplanes (FS/W) | 6 | Jul 21, 2009 08:36 PM |
