Old Sep 16, 2010, 10:06 AM
jimbo-69 is offline
Find More Posts by jimbo-69
Android app for calculating Roll Out and Final Drvie Ratios
Just wanted to let a few folks know about a new android app I just placed on the Android Market. It is named "Gears!". It is a simple rollout and final drive calculator.
It is version 1.3.1. It is a free app right now, so try it out and let me know what you think. You can post here for any questions or problems you might have.
I hope it is self-explanatory, but if not, here is a quick start...
When app first opens, you need to enter your cars Internal Drive Ratio. For pan cars/direct drive axles, you would enter 1.0. For all other cars enter the correct value, like 1.83 for a Losi JRX-S Type R touring car...
Next pick your tire type, foam or rubber. This determines if you are gonna calculate Roll Out or Final Drive Ratio. For Foam it will use tire diameter to calculate a Roll Out value. For Rubber, it will calculate Final Drive Ratio.
Next, you must enter values for all but 1 of the remaining fields. Then hit the calculate button. If you left a field blank, then that field will be calculated. If you have values in all the fields, then the Final Drive Ratio or Roll Out will be recalculated based upon the other values.
That is it. Nothing to fancy, but useful (at least to me). I am interested in fixing any errors you might find, and adding other features in the future, so feel free to post anything here (be nice ).
jimbo-69 is offline Find More Posts by jimbo-69
Old Sep 16, 2010, 01:14 PM
Redfisher is offline
Find More Posts by Redfisher
Nice day for RC'ing
Redfisher's Avatar
Palmerston On. Canada
Joined Jul 2010
I will have to take a look at this when I have time. I use one that has alot of the popular rcs pre-set into it.
Redfisher is offline Find More Posts by Redfisher
Old Sep 16, 2010, 08:22 PM
dialed is offline
Find More Posts by dialed
rc racer
dialed's Avatar
Pa.
Joined May 2010
Nice I will check it out too.
dialed is offline Find More Posts by dialed
Old Sep 18, 2010, 02:23 PM
2sicMiniT is offline
Find More Posts by 2sicMiniT
Under Warranty!
2sicMiniT's Avatar
Washington State
Joined Feb 2006
Could you name that app please? Thank you sir!
2sicMiniT is offline Find More Posts by 2sicMiniT
Old Sep 19, 2010, 09:37 AM
Nice day for RC'ing
Redfisher's Avatar
Joined Jul 2010
Check this one out, Has a few different calculators like top speed etc.
http://www.scriptasylum.com/rc_speed/_lipo.html
Old Oct 19, 2010, 04:18 PM
jimbo-69 is offline
Just wanted to introduce the next version of a new app I just placed on the AndroidMarket. It is named "RC Gears". It is a simple rollout and final drive calculator.
It is version 2.0 and now costs $0.99. The original version was named "Gears!". I renamed this version because of name clashes with a toolkit that Google used to develop by the same name. RC Gears is more appropriate for this app anyway. I have added the ability to store up to 5 sets of calculations by model name. This makes it easier to use when racing multiple cars on the same day.
When app first opens, you can type in a model name for the first page of settings you will define.
Next you need to enter your cars Internal Drive Ratio. For pan cars/direct drive axles, you would enter 1.0. For all other cars enter the correct value, like 1.83 for a Losi JRX-S Type R touring car...
Next pick you tire type, foam or rubber. This determines if you are gonna calculate Roll Out or Final Drive Ratio. For Foam it will use tire diameter to calculate a Roll Out value. For Rubber, it will calculate Final Drive Ratio.
Next to the Calculate button are two arrow buttons. They allow you to quickly navigate to the other pages for storage. You settings are remembered as you leave one page and go to another. This version will allow 5 different models to be stored.
That is it.
:tire::tire::tire:
Suggestion Android App Mauilvr Site Suggestions / Complaints 6 Aug 20, 2010 02:19 PM
Suggestion Android App. rockom Site Suggestions / Complaints 5 Aug 11, 2010 01:41 PM
Discussion Flying Wing ROLL RATES ( Aspect Ratios??? flyingwing12 Flying Wings 8 Dec 07, 2008 03:50 PM
Is there a prescribed method for figuring out gearbox ratios kit basher Electric Plane Talk 2 Sep 28, 2001 09:11 AM
