Old Sep 16, 2010, 07:27 AM
kennyfly is offline
Find More Posts by kennyfly
Joined Sep 2010
Low flying a quad with another one above as a video relay station?
Hi, reading like crazy in these forums and trying to learn. The quality of all-round knowledge is definitely the highest in this thread.. amazing.
Could anyone tell me if this idea is feasable or not?
If you use a quad for FPV you better keep flying low. The bottleneck on distance seems to be the video connection because you will lose the Line of Sight easily when going <3m.
Just want to understand if it would be possible to have another quad flying high above, receiving the video signal and transmitting it (on another freq?) to the base. The mikrokopter has a follow-me feature that could keep another mikrokopter flying above at say 100 meter at all time. So there is always LOS as long as you don't enter anywhere.. Demonstrated here:
http://www.rcmovie.de/video/adf097f5...zeitig-steuern
Would that work? Could it even relay the r/c signal? Receive PPM and send it on to the low quad?
If I understand this then I will have read enough for a while! Until my fatshark stuff comes in.. I am not worried about it being risky or expensive, it's more the theory that I would like to understand.
kennyfly is offline Find More Posts by kennyfly
Old Sep 16, 2010, 08:33 AM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Should work. On the relay station I would have a receiver on 900mhz and then transmit to the ground on 1.3mhz. You do not have to use these frequencies but I think it would be best to have good separation.
motorhead is offline Find More Posts by motorhead
Old Sep 16, 2010, 08:41 AM
kennyfly is offline
Joined Sep 2010
There would be a lot of frequencies in the air..
Is there a way to relay the r/c signal, can that be done? I could imagine feeding a ppm signal to another transmitter that is bound to the receiver on the low flying quad? Might that all be on 2.4ghz as long as it is the FHSS etc?
Old Sep 16, 2010, 08:44 AM
ommadawn is online now
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
I reckon having another quad as a relay is overkill. How about using a balloon, blimp type of thing as a relay station. No one needs to be flying it.
ommadawn is online now Find More Posts by ommadawn
Old Sep 16, 2010, 08:47 AM
StealthWorkx is offline
Find More Posts by StealthWorkx
What was that...
StealthWorkx's Avatar
UK
Joined Nov 2009
Had the same sort of idea with my Zephyr and Easystar,
On the Easystar ther'd be a 2.4ghz VRX that then re-transmits the Zephyrs signal.
quality may be not so good but as long as it's flyable it should work. I wouldn't relay the RC link as im on Scherrer UHF and on the high power setting that should be ok.
I was think of having the relay link on say 1.2ghz and the other 2 links (zeph and easystar primary FPV link) on 2.4ghz but that was only as i had a spare 1.2 unit.
Id use it just for a bit of Fun, might be cool to give it a go some time
StealthWorkx is offline Find More Posts by StealthWorkx
Old Sep 16, 2010, 10:22 AM
kennyfly is offline
Joined Sep 2010
Have a look at this video Ommadawn, nobody is flying the high quad, it just follows the first one at a fixed height, connected by a radio link from the low quad that sends the GPS coordinates to the high quad.
A blimp wouldn't be able to keep up with the low quad. You want to be straight above as much as possible so the low quad can get into narrow streets and behind any number of walls, houses, mountains..
I am sure even the Sherrer UHF would get in trouble after lots of walls, so it could benefit from a relay up above. Then use sherrer's system to link the high quad to the base.
What remains, can you relay the PPM signal? Can a sherrer receiver bind to two transmitters, or would they only bother each other, so you would need two r/c frequencies.
It should be able to put the quad FPV'ing bottleneck back to the battery, not the LOS...
Old Sep 16, 2010, 11:17 AM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
The Scherrer UHF receiver output the PPM train on ch12, so one could plug in a second Tx unit to relay signal. Since each one have different code and don't interfere, I believe it will work.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Sep 16, 2010, 01:20 PM
kennyfly is offline
Joined Sep 2010
But to be safe you would want the low quad to listen to the base station as well as the high flying quad, so you wouldn't be totally dependent on the high flying one. So they would transmit the same r/c signal, with the same 'binding code'. The high flying quad would give redundancy at the edge of the base's reach.
Would that be possible with the UHF system or am I misunderstanding something?
Old Sep 16, 2010, 03:32 PM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
That won't be possible, two Tx with the same Id code will produce serious multipath issue (two signal not coming at the same time to the receiver.)
-Hugo
Old Sep 22, 2010, 06:55 AM
adbo is offline
Find More Posts by adbo
Joined Jul 2010
Well there is a ready-made video solution:
http://www.ixbay.com/en/wireless-1-2...-repeater.html
adbo is offline Find More Posts by adbo
Old Sep 22, 2010, 07:12 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
You can get into trouble real quick flying a Quad low FPV. They can fly in directions that the camera can't see. So it is real easy to fly into something.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Discussion Another One Wing Landing Video ? Chophop Electric Plane Talk 11 Jul 26, 2010 07:43 PM
Suggestion Moving Aerial Photogrphy and video piloting above one another rcbif Site Suggestions / Complaints 1 Jan 05, 2010 02:14 PM
Discussion flying above cloud !--VIDEO-- ggtronic Aerial Photography 13 Sep 15, 2009 03:09 PM
Mini-HowTo I made a Servo as a Power Switch using a 5v Relay: my how-to guide with video + pics! HoaRC DIY Electronics 2 Jun 30, 2009 11:08 AM
Discussion blimp as rc relay station rektide Blimps 1 Aug 25, 2008 08:53 PM
