Old Sep 15, 2010, 10:45 PM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
My first Hydro build!
After 9 Vee's, I have made the plunge with what I consider to be a beautiful hull. Its a brand spankin' new Miss Elam that i got for $155! This is one large hull.............its 14" wide! It is beyond gorgeous to me, and looks to be very well made. I am very excited and am planning this all out very methodically and carefully. It will be juiced by the robust Neu 1515 in the pics, powered by 8s thru a turnigy 80HV ESC (thats what its for Bill) I am using what i consider to be higher quality components and am cutting no corners here! Wish me luck............and throw out lots of ideas and input!
scorpion1 is offline Find More Posts by scorpion1
Old Sep 15, 2010, 10:48 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Add. pics:
Old Sep 16, 2010, 01:29 AM
nick 30
nick30head's Avatar
Joined May 2009
the miss elam is a beautiful looking hull scorp, just one question though
where's the batt's going ???
nick30head is offline Find More Posts by nick30head
Old Sep 16, 2010, 02:30 AM
CornelP's Avatar
Bucharest, RO
Joined May 2009
No battery... just a loooooooooooooooooooooong wire plugged in the car battery...
CornelP is offline Find More Posts by CornelP
Old Sep 16, 2010, 03:11 AM
nick 30
nick30head's Avatar
Joined May 2009
what, about a mile long (LOL)
be a guided torpedo then would'nt it ??? hahahaha
hey scorp, those turnigy, flightmax and quantum stickers look familiar, not from hobby king are they ???
Old Sep 16, 2010, 05:13 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
If you can find a place to put the batteries it should fly on 8s. Plugged in and watching.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Hobby King "SIX" hexa
Old Sep 16, 2010, 07:07 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
What length is the hull? ~32"? 8s sounds like WAY too much weight in battery for a 1/12 scale hydro to me.
wparsons is offline Find More Posts by wparsons
Old Sep 16, 2010, 07:31 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Thanks guys, i was thinking of duct taping the batteries to the top of the canopy.................... There is enough room in the rear compartment to fit them in my estimation............but i may put two in the cockpit in front of the motor as they will fit there. What should the cog be on a hydro? Its 28" long and wider than heck.......... The 8s has been my plan for some time. I always like to do something a bit different and i believe i have started with a good foundation in the Elam hull.........the 1515 should push the bit of extra weight with no issue...............its an 1100kv, so 8s would put it in the sweet spot! Of course this is a "build".........plans change at times when you go thru it, but i really want the 8s, and am glad to hear all the input as i go!
Old Sep 16, 2010, 07:38 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Yikes! 28" is a 4s boat, with the right parts you'll run over 50mph easily on 4s. The UL-1 is the same rough dimensions, and most hydro's are at least 50% as wide as they are long.
More weight means more damage if it flips or hits anything.
Old Sep 16, 2010, 07:39 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
CG on a hydro is way forward to what it is on a V. Probably about 1" behind the trailing edge of the sponsons. I saw the room for packs in the back but it would make it bad tail heavy.
Old Sep 16, 2010, 07:42 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Yeah, but the motor i have is 1100kv............6s and larger prop would be an option down the road, but im trying this first.
Old Sep 16, 2010, 07:45 AM
syncronized's Avatar
Canada EH?!?
Joined Sep 2007
I'm actually building up a hydro as well!!! I always wanted to get the Miss Elam, but timing and money was a factor so I settled on a converted Miss Vegas hydro. I think it's a little bigger than the Elam at 32". But I love the colour scheme of the Miss Elam, I might try and replicate it with my Vegas hull. But....
8S?? Whoa...I wanna see vids
syncronized is offline Find More Posts by syncronized
Old Sep 16, 2010, 07:50 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Originally Posted by syncronized View Post
i'm actually building up a hydro as well!!! i always wanted to get the miss elam, but timing and money was a factor so i settled on a converted miss vegas hydro. I think it's a little bigger than the elam at 32". But i love the colour scheme of the miss elam, i might try and replicate it with my vegas hull. But....
8s?? Whoa...i wanna see vids
Old Sep 16, 2010, 07:59 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
hey scorp,you need to run cg about 0-10% from the rear edge of the sponson to the transom,so your batts in front should be ok the only thing i would worry about is the weight of the 2 x 4s packs may make run wet or even want to make it nose dive.so it would be a case of running steady to start with and see what happens.
But good luck with build and keep us posted,and 8s in that little hull should move it quickly in deed if you can set it up right.
F1 madness is offline Find More Posts by F1 madness
Old Sep 16, 2010, 08:11 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Thanks F1..........the packs were purchased with weight in mind. They are Turnigy 2s 3300 30c batts(x4).............fairly light and supply 99 amps continuous, 50% more than the 50-60 amps the Neu will pull...........and with the efficency of the Neu, i should get decent run times..........not looking for more than about 4-5 minutes anyways. The packs only weigh 200g each x 4 = 800 grams, whereas two 5000 30c 2s Turnigy's weigh 300g each x 2 = 600 grams. So we are talking about and additional 200 grams in batt weight from 4s to 8s...........7 ounces.
Discussion My first scratch build, EP trainer build/advice thread. WLJayne The Builders Workshop 25 Oct 05, 2010 03:05 PM
Build Log my first attempt to plan and build - Grasshopper insomaniac45 Foamies (Scratchbuilt) 9 Sep 10, 2010 07:35 PM
Discussion want to build my first micro boat ? taffy047 Micro and Sub-Micro Boats 12 Aug 16, 2010 11:43 PM
