Old Mar 11, 2011, 02:33 PM
AddictedToRC is offline
Find More Posts by AddictedToRC
Airplane Dope
AddictedToRC's Avatar
USA, WI, Rio
Joined Nov 2009
Originally Posted by UNGN View Post
That is the signal wire. Servo wires are +, - and Signal.
The diode is any 1N4004, 1N4005, etc diode.
OK thanks!
AddictedToRC is offline Find More Posts by AddictedToRC
Old May 01, 2011, 01:20 PM
flyingfred is offline
Find More Posts by flyingfred
flyingfred's Avatar
Joined Jun 2004
Hi Guys,
i make the Aileronmod and put the rod in the inner hole, but a make a few movement and the aileron servo sucks in end position. I disconnect an reconnect the Lipo and no aileron movement. I put the rod in the outer position and all be ok after i reconnect the lipo i read in a thread about it, but i cant find it.
flyingfred is offline Find More Posts by flyingfred
Old May 26, 2011, 08:18 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by flyingfred View Post
Hi Guys,
There is a lot of resistance in the bellcrank slots towards the ends of travel.
Swapping the short throw servo for an AS2000L works better.
You can reduce the throw in the TX to reduce sticking at full throw.
UNGN is offline Find More Posts by UNGN
Old May 27, 2011, 03:33 AM
super2012 is offline
Find More Posts by super2012
Joined Jan 2011
Looks nice... can it fly ourdoor?
super2012 is offline Find More Posts by super2012
Old May 27, 2011, 09:03 AM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
Are you asking if the t28 can fly outdoors or maladroits yellow t28? Either way the answer is yes to both. The t28 is a great outdoor flyer as long as the winds are low. I try to fly it with 5mph or less winds. You can fly it in heavier winds, but for me I just find it's not that enjoyable to be "fighting" the wind when your flying.
Super2012 are you new to rc flying? If so do you have any models yet or is there anything we can do to help you on deciding the right model for you?
jlcamp7 is offline Find More Posts by jlcamp7
Old May 27, 2011, 11:07 AM
Airplane Dope
USA, WI, Rio
Joined Nov 2009
If you are new to RC flying, my first piece of advice would be Get a sim. I learned a lot on just free sim and $20 sim TX. Here's a link: http://www.hobbypartz.com/60p-dyu-1002.html
Old Jul 01, 2011, 10:23 PM
RCSwitz18 is offline
Find More Posts by RCSwitz18
RCSwitz18's Avatar
USA, CA, Livermore
Joined May 2010
Hi guys
Thinking of totally modding my T-28. Where is everybody?!?!?!
RCSwitz18 is offline Find More Posts by RCSwitz18
Old Jul 05, 2011, 03:52 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Too busy flying or going on vacation
CNY_Dave is offline Find More Posts by CNY_Dave
Old Jul 09, 2011, 07:59 AM
bart70 is offline
Find More Posts by bart70
Australia, New South Wales
Joined Feb 2011
I am too busy flying to go on vacation....
bart70 is offline Find More Posts by bart70
Old Jul 09, 2011, 08:37 PM
LtColSpit is offline
Find More Posts by LtColSpit
"I'd rather be flying..."
LtColSpit's Avatar
United States, SC, Beaufort
Joined Mar 2004
Ultra micro light kits
SF Design Solutions micro lighting kits are designed for the ParkZone and E-Flite ultra-micro (UMx) F-4U Corsair, T-28 Trojan, P-51 Mustang and Mosquito. Kits are also available for the UMx Beast.
The 1S (3.7-4.2 volt) micro light kit weighs 2.5 grams and and consists of red/green wing-tip navigation lights, blue tail light and white landing light. A red flashing LED tail light is available upon request. The 5-light micro kits (Mosquito and Beast) have an additional (white) landing light. The lights run full time and are powered by the stock 1S battery pack (or 2S for the Beast) . Flight tests have demonstrated 6 to 8 minute flight times at normal power. Installation involves opening the fuselage, routing the wiring harness and taping it to the airframe. The wiring harness plugs directly into the AR6400 X-port and sip power at approximately 10mA per 6 minute flight.
**The Nano-JST plug is only compatible with the AR6400 series combination board and is not compatible with the AR6300**
Prices are $15 shipped for the 4 light kits (F-4U, P-51, T-28) and $18 shipped for the 5 light kits (Beast and Mosquito). Visit www.sf-design-solutions.com for more information. You can also follow a thread on HorizonRcFlyers.com. LCS
LtColSpit is offline Find More Posts by LtColSpit
Old Jul 10, 2011, 08:52 PM
Nova5 is offline
Find More Posts by Nova5
Joined Dec 2006
Originally Posted by rcplanekid View Post
OK. So I have to stay with 1S to use same guts? Guess i'm stuck getting only AP03 or 2g motors. I was asking is because on one 5g motor at HK it said it doesn't really run on 1S.
If it can take it weight wise, get a 5pack of the MiniJST extentions from hobby king or some place, you will need to sacrifice one. cut one in half. cut another one very close to the battery end. Now with the two halves and the one long one strip about 1/2" of each wire. twist all three reds together, twist all three blacks together. now put some electrical tape on the exposed wires. You can now run two cells together or one(just don't use the Y). You don't double the voltage this way, you split the current draw between the two. doubling flight time.
We just wired it in parallel. Voltage is the same, current/load is shared equally between the sources. if you wire it in series you make current the same and the voltage doubles for two cells.
I have some extensions and other stuff coming and might wire up a Y.
Nova5 is offline Find More Posts by Nova5
Old Aug 17, 2011, 02:55 PM
flyingfred's Avatar
Joined Jun 2004
I try the GWS 5x3 and the 5x4,3 yesterday and i am disappointed
the 5x3 ist slower than original and the 5x4,3 take to much amp and decrease the flighttime. OK it gives the T-28 a little more Power and it flys faster.
Old Aug 17, 2011, 02:57 PM
flyingfred's Avatar
Joined Jun 2004
Nova
thats a great idea on a windy day u can added weight and have a little more Power and longer flytime
Old Aug 17, 2011, 04:25 PM
CNY_Dave is offline
Joined Sep 2010
Stock motor and LiPo?
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10763 Sep 13, 2016 07:08 AM
Discussion Parkzone Ultra Micro T-28 Trojan tonebone Scratchbuilt Indoor and Micro Models 206 Jun 16, 2011 09:17 PM
Discussion Micro T-28 owners and mods thread! Bowerz Micro Ready-to-Fly 22 Nov 13, 2010 05:48 PM
Alert SOLD For sale Brand new Parkzone MIcro T-28 rudyhal Atlanta Area RC 12 Sep 24, 2010 10:51 AM
Discussion Parkzone T-28 Flaps Mods Question captaintomo Parkflyers 26 Feb 17, 2010 04:25 PM
