Old Jan 14, 2011, 10:04 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
There were reports earlier about the canopy conversion changing the traits of the t28. Some thought it was putting more weight higher above the wing and raising the center of gravity vertically.
bobly is offline Find More Posts by bobly
Old Jan 14, 2011, 10:30 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Mine had the canopy conversion on it when I bought it.
On the maden, I just put a battery in it and flew it. I found it super easy to fly and way more forgiving than a Mustang. I landed and took out all of the expo and dual rates I had put in for the maiden.
The Canopy can't do too much to the flight characteristics, because I can't imagine a low wing 4-channel plane being easier to fly.
UNGN is offline Find More Posts by UNGN
Old Jan 15, 2011, 03:04 AM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Here are some of the pics transformed to be more circular, better centered and remove the prop. I printed between 1.22-1.25" wide depending on how you trim them. They look great.
I do worry about motor getting hot. Does anyone know if it gets hot? Small brushed motors don't last long. I wouldn't think heat would help any. I don't understand why HH doesn't use brushless. A few more bucks would be worth it.
Steve
Floater73 is offline Find More Posts by Floater73
Old Jan 15, 2011, 04:07 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Steve
Someone has done a brushless conversion. Hobbycity has a 1S brushless motor and ESC. The AR6400 has an option to connect a brushless ESC to the brushless motor plug. I haven't one the conversion myself but it is mentioned in the UM t-28 thread (the big one). I think the motor and ESC are about $15. Don't know the the weights are.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jan 15, 2011, 09:57 AM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Glen
Would you have the link to the 1s motor? I did a search for what you mention up here, but I don't know enough to know which motor that could be. How do you determine that the kv is adequate?
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Jan 15, 2011, 11:06 AM
USA, GA, Marietta
Joined Aug 2005
I knew I should have taken more time on my other post but it was early and I was half asleep. But here they are.
Motor: http://www.hobbycity.com/hobbycity/s...idProduct=9663
ESC's (2):
http://www.hobbycity.com/hobbycity/s...idProduct=7184
http://www.hobbycity.com/hobbycity/s...idProduct=9667
Glen
Old Jan 15, 2011, 12:20 PM
MinneFlyer is offline
Find More Posts by MinneFlyer
MinneFlyer's Avatar
Joined Oct 2007
Very cool Glen, thanks for posting the links!
If anyone attempts the brushless conversion, please post pics and procedures for the project!
MinneFlyer is offline Find More Posts by MinneFlyer
Old Jan 15, 2011, 02:42 PM
USA, GA, Marietta
Joined Aug 2005
The users guide for the AR6400L is at:
http://www.horizonhobby.com/ProdInfo...0-L-Manual.pdf
Refer to page 7 (middle of the page) for instructions on connecting a brushless ESC.
There is also an AR6400LBL which is a brushless Rx/ESC/ Servo combination. It costs about $70. Saves the cost and weight of an additional ESC. However this unit requires a 2S LiPo. I would guess this is the unit that goes into the Beast.
Glen
Last edited by ggcrandall1; Jan 15, 2011 at 02:52 PM. Reason: added additional information.
Old Jan 16, 2011, 11:28 AM
enemyace19 is offline
Find More Posts by enemyace19
caveo hun in sol solis
enemyace19's Avatar
USA, NY, Levittown
Joined Jul 2010
Originally Posted by airlinerlover View Post
I was thinking about that canopy. Heard that it added weight but never really heard how much weight. Did it change your flight times enemyace? If so how much? And Just out of pure curiosity, could it be the same canopy out of guillow's balsa T-28 kit? I believe the guillows model and the parkzone model are similar in size. Just curious. Could buy guillows kit for ten bucks at my LHS and not have to wait for it.
Havent flown it yet.It will be my first time with the plane lol I dont think it adds much weight.I think its worth it for the detail.
enemyace19 is offline Find More Posts by enemyace19
Old Jan 16, 2011, 05:51 PM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
subscrd. Havn't gotten this bird (yet ) but I will be and if you don't stay on top of these threads you can miss alot!
kenstogie is offline Find More Posts by kenstogie
Old Jan 16, 2011, 06:19 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Glen
That is correct. It seems like that the foam could be trimmed to use a 2S. Might be actually feasible to up the whole motor/esc & battery.
Old Jan 16, 2011, 09:03 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Don't know if y'all have seen this... but....
Parkzone UM T-28 Trojan Tail Hook Mod (0 min 54 sec)
Park_aviator is offline Find More Posts by Park_aviator
Old Jan 17, 2011, 05:59 AM
sparks is offline
Find More Posts by sparks
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
About the canopy
The canopy I make for this model is original. I did the tooling directly from the Parkzone fuselage.
That is why it fits as well as it does.
Yes It does add a small amount of weight but is reduced when you remove the foam canopy .
I tried to measure the difference but my scale wouldn't pick it up.
If you use some common sense and don't go overboard with the epoxy and paint you will not notice a difference in the way it flies.
I have no idea how much glue the guys are using That have reported problems but that is the only thing I can think of that would cause it.
I only wish they would have let me know so we could look into it.
sparks is offline Find More Posts by sparks
Old Jan 17, 2011, 11:59 AM
AddictedToRC is offline
Find More Posts by AddictedToRC
Airplane Dope
AddictedToRC's Avatar
USA, WI, Rio
Joined Nov 2009
My mods are: Removable Canopy(It has Notches and a rubberband to hold it on.), and insulation for battery on bottom. I'm planning on converting it to brushless, and I want to keep it cheap. Would these work?
Motor http://hobbyking.com/hobbyking/store...idProduct=7230
ESC http://hobbyking.com/hobbyking/store...dProduct=10573
EDIT: Most Importantly, I changed the location of the battery to inside the plane, so I can open the canopy to put it in and take it out, so I don't have to insulate the battery place, and so hopefully it will have longer flight times.
AddictedToRC is offline Find More Posts by AddictedToRC
Old Jan 17, 2011, 01:42 PM
USA, GA, Marietta
Joined Aug 2005
Originally Posted by rcplanekid View Post
My mods are: Removable Canopy(complete with notches and super-simple but not so good latch.), and insulation for battery on bottom. I'm planning on converting it to brushless, and I want to keep it cheap. Would these work?
The motor might be OK but the ESC is way to big. Refer back in this thread for a better choice of ESC.
Glen
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10706 Today 02:34 AM
Discussion Parkzone Ultra Micro T-28 Trojan tonebone Scratchbuilt Indoor and Micro Models 206 Jun 16, 2011 09:17 PM
Discussion Micro T-28 owners and mods thread! Bowerz Micro Ready-to-Fly 22 Nov 13, 2010 05:48 PM
Alert SOLD For sale Brand new Parkzone MIcro T-28 rudyhal Atlanta Area RC 12 Sep 24, 2010 10:51 AM
Discussion Parkzone T-28 Flaps Mods Question captaintomo Parkflyers 26 Feb 17, 2010 04:25 PM
