Old Aug 24, 2012, 08:34 PM
Joined Aug 2012
Those links are straight from an mCX2. I cut two of the balls off of a swash plate, and carefully drilled holes through the remaining shafts and almost through the end of the ball (using a bit that matched the wire size). I glued the balls to the aileron linkage wires with epoxy.
There is probably a better way to make those linkages. I just happened to see those parts in my stash, and envision them on the plane.
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Old Aug 24, 2012, 08:44 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Matt, you are a genius. Dubro makes some parts like that, but yours weigh less and look great.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Aug 26, 2012, 07:50 PM
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
matt ls thumbs, did you see a noticable change in speed adding that carbon strip to the wings? i ask because my plane already has the extra weight of full time gear and the drag that goes with it.
walter3rd is offline Find More Posts by walter3rd
Old Aug 28, 2012, 11:52 AM
Łódź, Poland, Europe
sherman77's Avatar
Poland, Lodzkie, Lodz
Joined Apr 2012
Hi guys. I`m reading this thread for a few weeks, now is the moment to say "hello" My name is Jack, I`m from Poland...
I`ve done mod with carbon fibre 4x1mm, through whole wings, from tip to tip (glued with thin layer of epoxy). Now it weights 6g. more, but: dihedral is a lot smaller, roll rate is much faster. Whole plane is little bit nervous, but i like it. Climb rate is maybe 25% smaller, but I`m waiting for GWS 5030 - it should help.
Anybody know diameter of hole in GWS?
Sorry for my english...
sherman77 is offline Find More Posts by sherman77
Old Aug 28, 2012, 01:55 PM
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
Your English seems fine to me.
skarface is offline Find More Posts by skarface
Old Aug 28, 2012, 02:47 PM
Newbe learning everyday!
dbdukeboy's Avatar
United States, OH, Parma Heights
Joined Aug 2012
what a great thread I love my t-28 just the way it is.I fly it fearlessly like I do my champ! only one new fuselage so far!
dbdukeboy is offline Find More Posts by dbdukeboy
Old Aug 28, 2012, 04:15 PM
walter3rd's Avatar
Joined Aug 2012
added a cf strip to her today. a good bit of dihedral is gone so her maiden flight should be interesting. wondering about the added weight and cg possible change. only one way to find out. as long as she is more responsive and trims out ok i dont mind working harder. its been pretty easy up till now.
Old Aug 28, 2012, 07:41 PM
dbdukeboy's Avatar
Joined Aug 2012
Well I went on my maiden flight tonight with my ill t-28 and it's new fuselage. Did not go well just could not get it to trim.it used to fly so nice. I have no down elevator and it just seemed to sound louder. It is a new motor and gear box as well. The prop would just stop when I throttled down. On the bright side I flew my um p-51 for the first time, AWESOME!!!!,
Old Aug 28, 2012, 07:50 PM
Joined Aug 2012
Your CF strip is right about at the desired CG. The closer to CG it is, the less it affects CG. If it's dead-on, it will not affect CG at all. I think you'll be OK.
Old Aug 28, 2012, 08:27 PM
UMs & parkflyers... for now.
davidterrell80's Avatar
United States, VA, Herndon
Joined Apr 2012
I believe GWS props are 4mm... http://www.microflight.com/Prop-EP-5043
There are adapters for other diameters... http://www.microflight.com/Online-Ca...dapter-Set-4mm
davidterrell80 is offline Find More Posts by davidterrell80
Old Aug 29, 2012, 01:55 PM
sherman77's Avatar
Joined Apr 2012
Walter, right like on my t-28 . Battery goes about 10mm back with that setup, but nothing to worry. Smaller dihedral will afect way it fly... Like I said, more roll rate, almost none self centering effect. But it fly more scale now
Old Aug 29, 2012, 05:13 PM
walter3rd's Avatar
Joined Aug 2012
so after the post cf strip install flights i realized i actually had to move my battery a little bit forward and do some trimming but she still flys great. it requires more focus as she is not as forgiving but im ok with it. still love her.
Old Aug 29, 2012, 07:47 PM
Joined Aug 2012
That pulled a lot of dihedral out of your wing. Mine is not flattened nearly that much.
I used epoxy with a form to enhance the dihedral of the final assembly, but of course that is quite a bit more work. I was putting on a new fuselage at the time though, so it wasn't so much extra.
Please correct me if I'm wrong here: I am under the impression that dihedral helps if you turn the plane with only the rudder, or only the ailerons. With less dihedral, you need to ensure that you're using both ailerons and rudders in turns, perhaps some up elevator too.
Not a problem; just a bit different from what you were used to.
Old Aug 29, 2012, 09:55 PM
walter3rd's Avatar
Joined Aug 2012
i flew her the same way i have been which is without rudder but she does handle differently in the turns. i will need some more time with this new set up to get it in muscle memory. i ran 8 batteries through her today and really enjoyed her. just different. she will drop a wing in the wind easier now so no looking away. i had about 115 flights on her stock set up so im due for a change. once i get a calm day i will be able to see better her flight characteristics. today was first day with cf strip and it was pretty windy. didnt help with trimming but i got it sorted pretty good. just happy she still flys with the extra weight too. wasa bit worried.
Old Aug 30, 2012, 05:02 AM
sherman77's Avatar
Joined Apr 2012
With cf stripe I feel she`s more aerobatic, do You? More sensitive and less forgiving. But the fighters are just like that
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! dkintx Micro RTF 9182 Yesterday 12:55 PM
Discussion Parkzone Ultra Micro T-28 Trojan tonebone Indoor and Micro Models 206 Jun 16, 2011 09:17 PM
Discussion Micro T-28 owners and mods thread! Bowerz Micro RTF 22 Nov 13, 2010 05:48 PM
Alert SOLD For sale Brand new Parkzone MIcro T-28 rudyhal Atlanta Area RC 12 Sep 24, 2010 10:51 AM
Discussion Parkzone T-28 Flaps Mods Question captaintomo Parkflyers 26 Feb 17, 2010 04:25 PM
