Old Aug 22, 2012, 10:31 PM
walter3rd is online now
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
my mods are - 3 blade prop, home made spinner, upgraded canopy, arresting hook, scale landing gear. 87 flights to date. still in one piece. love her! not concerned with speed as much as looks overall. still a great flyer.
walter3rd is online now Find More Posts by walter3rd
Old Aug 23, 2012, 05:54 AM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
That is a fantastic Looking model! What prop did you use? The one for the UM Corsair? Did you build your own landing gear?
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Aug 23, 2012, 06:50 AM
walter3rd's Avatar
Joined Aug 2012
yes the prop is the um corsair. the gear are small straws for the struts and some thin mil. white sheet plastic i found laying around. everything is as light as possible so it shouldnt slow her down too much. the straws are about 3 times as thick as the wire and make the legs look more scale. thanks for the kind words. walt
Old Aug 23, 2012, 04:37 PM
walter3rd's Avatar
Joined Aug 2012
just got back from 8 flights at the field with the new landinggear doors. flew great! really couldnttell any diffeence. it ws too windy to get perfect comparison but very happy.
Old Aug 23, 2012, 09:14 PM
walter3rd's Avatar
Joined Aug 2012
mt father pointed out i didnt have the inner rear doors on the plane. i do now!
Old Aug 23, 2012, 10:44 PM
Matt Ls Thumbs is offline
Find More Posts by Matt Ls Thumbs
Joined Aug 2012
Two Aileron Servos
Dual aileron servos, using parts from the mCX2.
Carbon strip under the wing. I made a form from some foam packing material, to clamp the carbon strip to the wing while the glue set, holding the wing shape.
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Old Aug 24, 2012, 10:48 AM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
You can just plug right into the brick to do that?
Did the brick need some programming to reverse one vs the other?
CNY_Dave is offline Find More Posts by CNY_Dave
Old Aug 24, 2012, 11:24 AM
walter3rd's Avatar
Joined Aug 2012
mattls thumbs, is that one carbon fiber rod or 2? trying to figure out exactly how you get those installed. can you walk me through the process? thanks for the help. walt.
Old Aug 24, 2012, 12:31 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
If you use "dual Ailerons" on the TX, you can just plug the servos into the brick and they will work (though you may need to reverse one of the servos in the TX).
With a RTF TX, you'd need to switch the brick to Channel 2/Reverse Channel 2 mode.
UNGN is offline Find More Posts by UNGN
Old Aug 24, 2012, 06:40 PM
Joined Aug 2012
Dave, using the "dual ailerons" mode allows flaperons or spoilerons (pretty useless with the UM T28) but also allows differential, which would give a more scale appearance in flight.
I haven't set differential yet, but aim to try it out soon enough. Unfortunately, the T28 doesn't get much flight time these days.
Walter, that is a single carbon fiber strip. I don't recall the dimensions, but I'll take a measurement and get back.
I removed the wing from the plane and separated the belly pan. Made a form out of foam to hold the wing shape while the epoxy set, and glued the strip to the wing, clamping with the form for a few hours. Otherwise the carbon fiber strip will try to remove all dihedral. Some dihedral was removed with this mod.
Old Aug 24, 2012, 06:50 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Matt, I am not understanding why you glued a carbon strip? Is this to reduce flex? I haven't seen mine have a problem, so I'm wondering.
Old Aug 24, 2012, 07:07 PM
Joined Aug 2012
It does reduce wing flex. It's not a problem in that it will fly with the wing flexing, but it's not ideal.
When on the ground, run your aileron stick from one side to the other, and watch the wing. Ideally, only the control surfaces move, but that is far from the case with the stock wing.
It hardly flexes at all now, and the aileron control is more crisp. I did the dual-servo mod first, and the carbon strip after a few flights, and the carbon strip does help.
What I do not like about this plane now, is the very slow response on the elevator and rudder, compared to the AR6400L in the su26xp and 4-site.
Old Aug 24, 2012, 07:10 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Have you increased the throws to max?
Old Aug 24, 2012, 07:14 PM
Joined Aug 2012
Indeed I did.
The full-deflection on the (my?) T28 is very slow compared to the su26xp or 4-site, even though these latter planes have a longer throw.
Old Aug 24, 2012, 07:25 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
You could, of course, change out to the 6400L. I have a 6400bl that I'm considering as a replacement. It's easier than the wing brace you did! I'm impressed with the dual ailerons and will definitely copy what you did.
Discussion ParkZone Ultra Micro T-28!!! THE Owners Thread!!!! RM_Sparks Micro Ready-to-Fly 10739 Jul 18, 2016 12:27 PM
Discussion Parkzone Ultra Micro T-28 Trojan tonebone Scratchbuilt Indoor and Micro Models 206 Jun 16, 2011 09:17 PM
Discussion Micro T-28 owners and mods thread! Bowerz Micro Ready-to-Fly 22 Nov 13, 2010 05:48 PM
Alert SOLD For sale Brand new Parkzone MIcro T-28 rudyhal Atlanta Area RC 12 Sep 24, 2010 10:51 AM
Discussion Parkzone T-28 Flaps Mods Question captaintomo Parkflyers 26 Feb 17, 2010 04:25 PM
