Old Feb 27, 2013, 12:31 AM
kchen95 is online now
Find More Posts by kchen95
Taiwan, 北市
Joined Dec 2008
Hi all, I want to try using crow for the first time in landing, just to experiment. My understanding from reading various posts is that if use crow, I can maintain the same amount of down elevator that I use when I land with just flaps and no crow - in other words the elevator position does not need to change according to whether I use flaps only or flaps plus crow. Is this correct?
Kevin
kchen95 is online now Find More Posts by kchen95
Old Feb 27, 2013, 03:53 AM
jamnbec is offline
Find More Posts by jamnbec
Jamie
alaska
Joined Sep 2006
jamnbec is offline Find More Posts by jamnbec
Old Feb 27, 2013, 04:34 AM
Taiwan, 北市
Joined Dec 2008
Just to clarify my question with an example - if, say, I mix 2mm down elevator when I land with flaps only and no crow, if I add crow to land, do I still maintain the 2mm down elevator, or should the amount of down elevator increase/decrease? Thanks!
Kevin
Old Feb 27, 2013, 06:24 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
The elevator position shuld not change.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Feb 27, 2013, 08:20 AM
Snowflake6515 is offline
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
Elevator Position
+1
That has been my experience across about a half-dozen models; set the down elevator mix for the flaps and it seems that the ailerons do not cause a noticeable difference in pitch (sink rate, heck yes.) :-)
Michael
Snowflake6515 is offline Find More Posts by Snowflake6515
Old Feb 27, 2013, 09:38 AM
Taiwan, 北市
Joined Dec 2008
Tks for the confirmation! Appreciate it.
Kevin
Old Feb 28, 2013, 02:48 AM
Quandry is offline
Find More Posts by Quandry
Ireland, Co. Dublin, Dublin
Joined Feb 2012
When you activate Crow it will make the Habu balloon up in to the air on a mostly level attitude, it also adds a good bit of drag so you may want to keep a little bit of power on so that it doesn't just fall out of the air then as your sink rate increases due to reducing air speed.
Quandry is offline Find More Posts by Quandry
Old Feb 28, 2013, 10:46 AM
STEVEAIR2 is online now
Find More Posts by STEVEAIR2
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
Hi Geoff
Do you have a file I could import into a DX18 For the Habu?
Cheers
Steve.
STEVEAIR2 is online now Find More Posts by STEVEAIR2
Old Feb 28, 2013, 09:31 PM
Tealc is offline
Find More Posts by Tealc
United States, OR, Portland
Joined Aug 2011
Got the new fuselage today so I can move on with the build. It looks much better then the first one. No globs of paint,cracks, and a much smoother finish. Thanks, Horizon. Todd
Tealc is offline Find More Posts by Tealc
Old Mar 01, 2013, 03:41 PM
YF-22 117 is offline
Find More Posts by YF-22 117
Joined Mar 2009
Hey all im back... with yet another question =D. with the eflite retracts being so pricey has anybody ordered good quality retracts from anywhere else? seen a thread about a guy buying retracts from hobbyking but he never went on to post of pictures to how well they fit into this plane and how good the quality was. any help is appreciated
YF-22 117 is offline Find More Posts by YF-22 117
Old Mar 01, 2013, 04:07 PM
Angrykid23 is offline
Find More Posts by Angrykid23
United Kingdom, England, Oldham
Joined Feb 2013
Well don't know the answer to that but someone in my club said they heard eflite retracts and hobbyking retracts are made in same warehouse thus the same. Speculation I'm sure.
I'm useing tamjets retracts on mine with the metal trunion.
Im saying you get what you pay for.
Angrykid23 is offline Find More Posts by Angrykid23
Old Mar 01, 2013, 05:34 PM
Tealc is offline
Joined Aug 2011
I have yet to order Tamjets struts but have the Eflites on hand. If I were you I would stick with Eflites knowing that they will go right in. I have not personally seen nor tried the retracts offered by Shulman Aviation so don't know how they compare to Eflite with Tamjets. Hopeing to get the Tamjets ordered soon so thay I can finish installing the retracts. That is my 2 cents for the day. Might tried ebay or RC Groups and see if you can find a set of Eflite's there.
Old Mar 03, 2013, 01:31 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Like it has been mentioned, the eflite ones are a drop in fit with low hassle. If you want cheaper alternatives, check out HK, but compare the specs to the elfite ones to see if they will fit/work. As for struts, Tams are the way to go, again because they have the metal trunions and the machine quality of the hardware is top notch. I havent heard much good about thr shulmans except they are overpriced and almost exactly the same as hobby king varieties.
Jetnfast is offline Find More Posts by Jetnfast
Old Mar 03, 2013, 09:22 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
TJ80 12 blade testing at the Willow
8s and 9s setups worked very well today
Tam will be offering a 12blade TJ80 and TJ90 setups very soon
TJ 80 12 blade rotor on 8s 3300 (3 min 11 sec)
TJ80 12blade 9s 3300 (3 min 51 sec)
jcdfrd is offline Find More Posts by jcdfrd
Old Mar 03, 2013, 09:43 PM
keithtsr is offline
Find More Posts by keithtsr
Keith Thomas
keithtsr's Avatar
United States, NM, Portales
Joined Feb 2010
Nice flight Tam, I enjoy watching you fly....time to dust off a Habu and get back in the game.
Any idea what kind of speed? Sorry I had to ask, old habit.
keithtsr is offline Find More Posts by keithtsr
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
