Old Feb 14, 2013, 09:41 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Here is mine YF-22
Came out nice...http://www.rcgroups.com/forums/showp...postcount=9166
fh64_lucky is offline Find More Posts by fh64_lucky
Old Feb 14, 2013, 10:24 PM
YF-22 117 is offline
Find More Posts by YF-22 117
Joined Mar 2009
Originally Posted by fh64_lucky View Post
very nice, but I still want to be able to see throught the canopy. Thanks for the help.
YF-22 117 is offline Find More Posts by YF-22 117
Old Feb 15, 2013, 12:59 PM
Tealc is offline
Find More Posts by Tealc
United States, OR, Portland
Joined Aug 2011
Putting the Habu together. Just installed one of the wing spars in place. The instructions said to mix up 15ml of epoxy, which I did. But there was no way 15ml was going to fit. I am not sure how much I got into the pocket with the spar. Probably couple of ml would be my guess. Anyway I has a bunch left over. Did any of you get all 15ml in the pocket with the spar? I am thinking of only mixing about 4ml the next time when I do the other spar. One thing I don't like is waist and I waited a lot of epoxy.
Tealc is offline Find More Posts by Tealc
Old Feb 15, 2013, 01:02 PM
dennisjm is offline
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
The instructions also point out that a ton will squeeze out don't they? You're right it won't all fit in there.
dennisjm is offline Find More Posts by dennisjm
Old Feb 15, 2013, 01:44 PM
Angrykid23 is offline
Find More Posts by Angrykid23
United Kingdom, England, Oldham
Joined Feb 2013
heres my habu darkened canopy . running on 6s lipo for now !.
tamjet retracts to handle the grass strips of the uk
Description:
Angrykid23 is offline Find More Posts by Angrykid23
Old Feb 15, 2013, 05:42 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Looks nice!
Jetnfast is offline Find More Posts by Jetnfast
Old Feb 16, 2013, 06:42 AM
FOX ONE! is offline
Find More Posts by FOX ONE!
Houston. .we have a problem.
FOX ONE!'s Avatar
Joined Aug 2008
Did you find any translucent gold in a "ready to spray" can?
If you have an airbrush, it shouldn't be too difficult, as most metallics are actually translucent. It's the density of the particles that gives the appearance that they aren't. If you thin the paint, you should get to your required level of translucency. The problem is going to be the thin paint will have a tendancy to run. . .
FOX ONE! is offline Find More Posts by FOX ONE!
Old Feb 16, 2013, 12:41 PM
gr8taz nitro is offline
Find More Posts by gr8taz nitro
lawndart aerobatic ace!
gr8taz nitro's Avatar
Joplin, Misery
Joined Mar 2007
Any of the pactra metallics or candy paints will go on translucent. Just build them up in very thin layers, the first couple of coats spraying so light it almost doesn't look like your adding any color at all and you'll be fine.
gr8taz nitro is offline Find More Posts by gr8taz nitro
Old Feb 16, 2013, 01:10 PM
Joined Feb 2013
Well weather holding in UK so gonna try and get out tomorrow morning all batts charged
Will try and get some pictures done if anyone else turns up to take them for me LOL
Old Feb 16, 2013, 04:00 PM
FOX ONE! is offline
FOX ONE!'s Avatar
Joined Aug 2008
There's an article on gold tinting canopies here: http://beyondthesprues.com/Forum/index.php?topic=1710.0
and here:http://cs.finescale.com/fsm/modeling...2/t/33293.aspx
Old Feb 18, 2013, 04:30 PM
pollster is offline
Find More Posts by pollster
pollster's Avatar
United Kingdom
Joined Aug 2011
Hello all
Does anyone feel the need to reinforce the intake ducting when using higher power setups. Iam using a 10s setup with mach alloy 80mm 1680kv motor.
pollster is offline Find More Posts by pollster
Old Feb 18, 2013, 04:39 PM
efflux RC is online now
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by pollster View Post
Hello all
Hi pollster,
Not at all. This jet is constucted rather robustly, and requires no airframe or ducting mods with that setup flying it at 161mph. (10s)
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Feb 18, 2013, 05:25 PM
pollster is offline
pollster's Avatar
United Kingdom
Joined Aug 2011
LooksDoo
Originally Posted by efflux RC View Post
Hi pollster,
Thankyou for the info efflux rc.
By the way I really like the mach alloy fan unit, well made. Looks good, balanced, plenty of thrust, and sounds awesome! Happy days.
Old Feb 18, 2013, 10:57 PM
Tealc is offline
Joined Aug 2011
Just need to vent. Ok, so I just finished the wing spars and moved on to the tail servo. I decided to do a detailed inspection of the fuselage. I was not impressed with the quality when I first pulled it out of the packaging. Numerous small little dents that I would not have expected it to be there. My Marvel Craft Agusta fuse is much better quality. Probably because it cost a couple hundred more and is much larger but I thought that it would be better than this. Blemish in red paint above the wing. Looks like a paint clot, hair, or fiberglass fiber about 1cm in the length. As I was looking at the small dents, blemishes in the nose, I discovered a crack in the fuselage about 2" in length. I have contacted Horizon Hobby but since I don't have the receipt for proof of purchase and purchase date I am not expecting much. I am angry that I did not inspect the plane when I got it. I have had it in the box for the last 6-8 months while gathering bits and trying to get funds for Tam struts and fan upgrades. I should have inspected it months ago. My bad. Live and learn. Needless to say, I should never have open the box and found a fuselage with this many problems. Don't get me started with all the flaws in both wings. I know not a BVM but come on. I have put foamies together that look better than this. Thanks for reading. Todd
Old Feb 19, 2013, 12:45 AM
SmokeDogg is offline
Find More Posts by SmokeDogg
"Fly Low, Fly Fast, Turn Left"
SmokeDogg's Avatar
United States, CA, Red Bluff
Joined Jul 2009
There is no reason you should be having those issues. That really sucks man
Mine looked great out of the box for the most part. The wings are a little loose like a bunch of others but otherwise turned out great!
Hope HH takes care of you
SmokeDogg is offline Find More Posts by SmokeDogg
Latest blog entry: Miss Foxy Lady eBuild
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
